Question about Samsung DVD-VR320 DVD Recorder/VCR
Not able to copy entire vhs to dvd
I have been trying to copy VHCS tapes to DVD with my Samsung Recorder. I will not copy entire video. It starts and then somewhere, where ever it decides it stops recording. Any ideas?
  • AWooten Aug 18, 2008
    Thanks I hadn't thought of that. I will check it out.
    A
What is the recording speed of your tapes and DVD? SP SLP, etc. on tape SP SLP XP on DVD? That will determine the length of th recorded tape and the recording time the DVD can hold.
Posted on Aug 18, 2008
SOURCE:
Can DVD DISKS BE COPIED FROM VHS TAPES ON A dual; DECK MACHINE?
There are machines made just for that task such as the Magnavox DVD recorder. There is a VHS tape deck on one side and a DVD recorder on the other side. You can copy a VHS tape to a DVD and copy a DVD onto a VHS tape as well
Jan 21, 2017 | Televison & Video
For some reason I can no longer copy from my VHS tape to my DVD disk in my Toshiba DVR620KU DVD Video Recorder. I have tried some of the same tapes which had copied just fine in the past. I am using the...
How old is Toshiba DVR620KU recorder and how long it started this problem?
Does it playback previously recorded discs correctly?
Did you tried lens cleaning disc in recorder to clean optical lens?
These info will help me to suggest a solution.
Thanks.
Jul 22, 2011 | toshibadirect.com
Is it possible to copy video from a vhs to a dvd?
If the DVD drive is a recorder, yes. If it is a player only, no. If the tape is copy-protected, recording to a DVD recorder is not possible. Assuming the tapes are not copy-protected, and you are using a DVD recorder with the correct format DVDs (DVD-R for example), you shouldn't have any problems transferring old VHS tapes to DVD.
Jul 05, 2011 | GoVideo DVR4000 DVD Player/VCR
TRYING TO COPY VIDEO TO DVD Only records in black and white ????
Store bought tapes with movie release have a copy guard protector imprinted in the tape preventing successful dubbing, especially the more recent movies.
Jan 06, 2011 | Samsung DVD-VR375 DVD Recorder/VCR
Can't dub from Samsung VR8606 to another device
If you have a scart socket on the back of the vcr poss marked av1.Connect a scart lead to this and if the dvd recorder has scart sockets connect to the one marked av2.Then put the vcr on play and the dvd on av2 and you should be able to record,hope this works.Jamie
Jul 07, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
Can NOT copy aN original DVD made from Sony Camcorder DCR-TRV27
Try Finalizing the DVD disc on the Camcorder or the DVD Recorder before trying to copy the DVD on the Computer.
Jun 16, 2009 | Sony Handycam DCR-TRV27 Mini DV Digital...
How do i hook up dvd recorder/vcr to my tv?
Hello.
If its a combined dvd/vcr unit you should be able to record on the dvd input from the vcr with a 3 split cord connected as described below..
VCR -
Video output - yellow.
Audio output - left and right - red & white.
DVD
Video input - yellow.
Audio input - left and right - red & white.
Or you might have to use a standared RF cable from the
antenna out on the video to the antenna in on the DVD.
Additional information....
Just as you can't copy commercially made video tapes to another VCR due to Macrovision anti-copy encoding, the same applies to making copies to DVD. DVD recorders cannot bypass the anti-copy signal on commercial VHS tapes or DVDs. If a DVD recorder detects the anti-copy encoding on a commercial DVD it will not start the recording and display some sort of message either on screen or on its LED front panel display that it detects the anti-copy code or that it is detecting an unusable signal.
A DVD recorder can be used to copy any homemade videos, such as camcorder videos and videos made from TV shows, and can also copy Laserdiscs, and other non-copyprotected video material. Also, remember that a DVD recorder also has a built-tuner for recording TV programming directly. The tuner can be programmed to record a series of programs on different days and times, much like a VCR. However, if you are recording a non-copy protected DVD to a DVD recorder you can record any of the video content, provided you click on the menu and start the video segments running and you have enough time space on the disc. DVD recorders function like VCRs in that they can record incoming video signals -- however, they do not automatically copy all the contents of the DVD - for instance, you cannot copy the interactive menu functions of a non-copy protected commercial DVD. A DVD recorder creates its own menu functions, it will not duplicate the function menu from a another DVD.
Hope this will help you.
/Tech5508
Feb 13, 2009 | Toshiba DVR610 DVD Recorder/VCR
How to record a VHS tape to a DVD disc
Read your manual first to make sure the unit will do this.If it does chances are it won't record unless it has a decoder built in.Most VHS tapes have macrovision protection that prevents you from copying them.It will however,record homemade VHS tapes.There are decoders out there you can buy to enable you to copy VHS tapes.
Dec 30, 2008 | Samsung DVD-V4600 DVD Player/VCR
Copying 8mm tapes to dvd
try taking your audio and video cables from the camcorder and plugging them into the line 1 inputs of the dvd recorder try playing the camcorder and if you can see the video from the camcorder on your tv when it's plugged into the line1 of your burner then hit the record and make sure teh dvd burner is set to accept a signel form the line 1 inputs then it should record. but remembermust selsct the line 1 inputs before you start to record, by defualt they are set to tv/cable.
Dec 27, 2007 | iLO DVDRH04 DVD Recorder
Dubbing vhs to dvd
Easy. Connect RCA lead from video/audio OUT on the VCR to video/audio IN on the DVD recorder. Set DVD recorder source to VIDEO then press play on the VCR and record on the DVD recorder.
Sep 09, 2007 | Aspire Digital AD-8091 DVD Recorder
Samsung DVD-VR320 DVD Recorder/VCR Logo
170 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
