Question about Maytag Neptune MAH5500B Front Load Washer
Rockengirl420@yahoo.com My washer shows the code Lr. I can't find my manual, so went online and it say's to do a motor control board diagnostic test first. How ??? please help. maytag neptune digital front loading.
  • 22 Answers
No motor test required , you need to replce the motor and motor control kit I have appliance experince 5years in the field 9 Times out of ten it is the motor and control board.
Posted on Aug 17, 2008
Why is my Maytag washer showing lr code again?
If you live in North Hollywood, CA and need washer repair service call us at (626) 460-0903 or visit our website Washer Repair North Hollywood CA 747 248 4544 Samsung
Sep 03, 2017 | Washing Machines
Error codeLr?
The LR code means "locked rotor" which is just a way of saying the control is not seeing the motor turning.
The image below contains the wiring diagram for this washer as you requested but there are some other things to consider.
Usually when the LR code is displayed the motor has stopped turning for some reason. By definition the LR code means the control has tried to turn the motor but was unable to.
The error code can be caused by to large of load, to much soap/suds in the water or a problem with the spin bearing. The cause of the LR message can be little problem like suds or a major problem like the spin bearing and sometimes it's difficult to pin down. You don't mention in your question if the LR code occurs every load or once a week.
More information on when the error is occurring would be helpful resolving this problem. Try running a rinse and spin cycle empty and see if the washer completes the cycle.
The 2nd image contains the information on how to enter and run a diagnostic cycle which may help pin the source of the problem down. This test completes all functions of the washer is a short time. It will fill, tumble, drain and spin all is a few minutes. At the end of a successful test cycle a PA should display which means "Passed" and is what you want to see.
Feb 14, 2012 | Maytag Washing Machines
I have a Maytag Neptune Washer Model #MAH5500BWW. I am getting an Lr error code. I ran a diagnostic wash and it stopped with the Lr cade and I pushed ^ t continue the diagnostic test. What should my...
Hi
Lr means locked rotor, this issue occurs due to locked rotors, you'll need to check the rotor wiring and motor windings. If the wiring is good and windings are not burnt then you'll need to replace your motor and motor control board. These are sold as one unit, it is a 3 phase motor and one of the phases is bad as a little power surge can damage the boards. Hope this helps...please post back for further assistance.
Daniel
Aug 06, 2011 | Maytag Neptune MAH5500B Front Load Washer
Lr message
THIS WEBSITE IS VERY USEFUL FOR YOUR MACHINE
http://www.applianceaid.com/neptune8.html
HERE IS THE OUTLINE FOR THE CODE LR
Lr Locked Monitor Rotor Based in signal information from motor control board, the machine control board senses the motor is not turning when requested to run 1.Run motor control board diagnostic test. 2.Check motor control board for damaged components.
3.Check wire connections in harness leading from machine control board to motor control board.
4.Replace responsible component.
May 27, 2010 | Maytag Neptune MAH5500B Front Load Washer
LRFD22850french door fridge bottom freezer.
The LR error on your non-spinning Maytag Neptune is usually, though not always, accompanied either by a burn spot or a blown fuse on the Motor Control Board.
Maytag upgraded the motor and motor control board because this problem was so prevalent. Big rash of these a few years back... and insludes replacement instructions with the kit.
The LR code means "locked rotor" - the control is not seeing the motor turning.
Image 1: http://media.fotki.com/1_p,sqwrrqkkqkstsftxgtqsskgwtqkq,vi/kkwrfdskkxkgbffwfww/1/1303472/5961857/image53872img-or.gif
Image 2:http://media.fotki.com/1_p,sqwtrsgdwsqtqsqxgtqsskgwtqkq,vi/kkwrfdskkxkktggsfsw/1/1303472/5961857/image53908img-or.gif
From another source...
"Installing replacement motor, motor control harness, and motor control circut board.
Pretty easy install. On a scale of 1 to 10 I'd call it a 3.5.
If you can use a screwdriver, a wrench, and have played with legos before, you can probably do this job.
It took me about 3 hours to do, but this was with inferior tools, and two smoke breaks included.
Minimum tool requirements: Adjustable-head cresent wrench (8 or smaller handle), phillips head screwdriver, utility knife.
Recommended tool equirements: Small ratchet with socket set, ratcheting screwdriver with phillips head and small socket attachments, brew.
The instructions are pretty clear.
Once you pull the front panel off, there are two braces at 45 degree angles on the lower corners of the washer.
The instructions don't ask you to, but I would remove the brace on the left to make life easier.
This gives your arm more room to work and makes it easier to pull the motor out the front.
They ask you to remove the wiring harness from the motor first and then pull the harness out with the control board.
My wrench was too big to get to the bolt to remove the harness from the motor.
All I did was cut the harness - since they supply a new one - then pull out the control board, then pull out the motor.
As far as getting the pulley off, slip it on and off at the large wheel, this is much easier than taking it off at the small motor drive shaft.
The only other thing of note is to make sure you look at the diagram for the conectors a few times before you snap it together.
There are a few ways you could hook it up wrong so pay attention. There should be no loose ends when you finish.
Also, I couldn't get the flange back on on the rear acess panel when closing it up, but it doesnt seem to serve muc purpose besides asthetics, so I tossed it.
The $200 for the parts and shipping was well worth it. I saved about $150-250 to do it myself...."
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question ^#%#$
May 09, 2010 | Maytag Neptune MAH7500WH Front Load Washer
Neptune washer doesnt finish cycle. hits the Lr code. have had two differnt service techs out. Diagnostic tests show "No problem"
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%RT
Jan 11, 2010 | Maytag MAH6700AWW Neptune Front-Load...
Replaced motor and control washer still shows lr doesn't complete cycle
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question &$^
Dec 11, 2009 | Maytag Neptune MAH5500B Front Load Washer
Code lr ?
hate to interject
but lr stands for locked rotor
your motor control has blown a fuse or heat sync.
you can verify this by removing the door and front panel,
the motor control is on the bottom right front
inspect this board with a flashlight
im almost sure you will find some sort of burning
if you do and would like to repair the unit im including a link
that will show you the part you will need
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=47812
make sure you oder the part that comes with a new motor is actually cheaper AP4010145
Oct 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer stops midcycle with a LR showing on the digital screen
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question $%^
May 07, 2009 | Maytag Neptune MAH5500B Front Load Washer
Getting error code#06 Lr Locked Rotor
You may have an outer tub seal leak and the bearing may be trying to seize up, hence the lr code. Removing the back panel will divulge a brown colored "spray" mark around the cabinet perimeter. This is not a DIY job and is usually around $650.00.
Below is a link that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information. You should be able to find a manual there. If not then try; www.maytag.com
http://www.managemyhome.com/mmh/products/ManualSearchDisplay.action?psid=31378668&sid=MMHSx20070515x00001a
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jun 24, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
184 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
