Question about Canon PowerShot A520 Digital Camera
Powershot A530 My camera won't take a picture when i have the flash turned on. If i turn the flash off it is fine. When it's on and i try to take a picture, the red eye beam comes on and nothing else happens.
    Guru:
  • 1,463 Answers
Hi gandk1
have you check out the support see if they can assit you
riz.
Posted on Aug 12, 2008
How do i turn off the flash on my Canon PowerShot A530
Press cursor-up on the round cursor pad (marked with a lightning bolt) to change the flash modes. To turn the flash off, select the lightning bolt in a circle with a slash through it.
Sep 14, 2010 | Canon PowerShot A530 Digital Camera
How do i turn off the flash on the cannon power shot a530
May 15, 2010 | Canon PowerShot A530 Digital Camera
Press the Flash button (the top part of the circular "joystick" button, marked with a lightning bolt) to cycle through the options. You can choose from Auto with red-eye reduction, Auto, Flash on with red-eye reduction, Flash on, and Flash off. You want the lightning bolt in a circle with a slash through it.
Mar 29, 2010 | Canon PowerShot A530 Digital Camera
Not capturing pictures
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help:
Feb 12, 2010 | Canon PowerShot A530 Digital Camera
Power shot A530 digital camera
hmmmm.
then try this way.
when you are aiming the object press the DISP or DISPLAY button in the camera.
your LCD must turn ON.
Jun 28, 2008 | Canon PowerShot A530 Digital Camera
Won't take picture when flash is turned on
Charging of the flash may be overpowering the batteries that you're using. Are you using alkaline batteries? If so, recommend instead trying rechargeable NiMH batteries rated at least 2500mah to see if the problem still exists.
Feb 27, 2008 | Canon PowerShot A530 Digital Camera
My flash won't work!!!
Check to make sure your camera's not on the A530 recall advisory list. Maybe the flash capacitor isn't getting enough power due to the shorting described in the advisory?:
http://camerarepair.blogspot.com/2007/12/canon-a530-a540-with-short-battery-life.html
Sep 28, 2007 | Canon PowerShot A530 Digital Camera
Problems with the battery and the flash on my canon powershot A530
Hi, On another brand/model of a digicam, a similar problem was fixed by cleaning the battery terminals/contacts. The ends of the terminals that pushes on the battery were partially corroded hence the batteries were not getting full contact. They were cleaned by scraping off the corrosion and applying a strong solvent using cotton buds. Further, they were bend a little to add more pressure to the batteries. If the above does not work, it is possible that the flash charging circuitry is defective and drawing much power than it should normally be. Try operating the digicam with the flash off. If this likewise is a "no joy", perhaps your camera would need the services of a qualified professional. Hope this be of some idea/help. Post back how things turn up or should you need further information. Good luck and kind regards.
Sep 16, 2007 | Canon PowerShot A530 Digital Camera
Canon a530 powershot won't snap a picture
sounds like the flash isn't charging, as the flash icon flashes while the flash is charging before letting you take the photo. Put it in "P" and disable the flash and see if it'll let you take a photo. G>
Sep 03, 2007 | Canon PowerShot A530 Digital Camera
Canon PowerShot A520 Digital Camera Logo
56 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
