Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
Problem starting Sometimes will not start at all. Sometimes will do a quick start and stop. Other times it starts and runs fine????
    Novelist:
  • 97 Answers
This can happen if you have an intermittent short in your cord. Try plugging it in and then wiggling the cord around where it goes into the body of the vacuum with the switch set to "on." (If you're not sure whether it's on or off, just click it back and forth occasionally.)
If the motor kicks on there's a short, which usually requires a cord replacement. If that's the case, it's a relatively simple fix for most dyson models.
If not, you could have a short in your switch or somewhere else in the electrical system of the machine.
-R
Posted on Aug 13, 2008
Dyson dc44 making a stop start chugging noise
You should take it to your local vacuum repair shop and have them listen to it. It sounds like it could be your motor burning up.
Aug 28, 2014 | Dyson DC44 Animal Cordless Vacuum
Bikegit
Replace the switch! It shut down when battery get depleted. and then when you start it again the cycle is shorter because the batery regenerate but not as previous cycle.
Jul 16, 2014 | Karcher WV50 Window Vacuum
Kirby doesn't always start when plugged in unless I jiggle the cord and then it often stops when in use.
You need a new power cord! :0) Here is a link to help with replacing it...
Jun 17, 2014 | Kirby Vacuums
Not starting at all
Hi there, it's Jack at Dyson.
The issues with your DC44 Animal sound unusual, and we'd like to take some further details. If a replacement part is needed, we can also confirm if your machine is within our 2-year warranty period.
When your machine is fully charged and easily to hand, please call us on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU). Our experts will be happy to run you through some quick diagnostic checks to help determine the best course of action.
Dec 01, 2013 | Dyson DC44 Animal Cordless Vacuum
Actually ours is a Princess II made by Filter Queen, purchased in 1987. Wondering if motor going bad because when switch on sometimes it starts fine but other times you have to push the switch several...
It sounds like it's probably the switch. It could also be loose wiring connection to the switch, which can result in sparking. This presents a fire and/or shock hazard. Don't use it until you get it repaired. I do recommend having the vacuum checked out for a definite diagnosis. You're right about it possibly needing a new motor.
Mar 30, 2011 | Filter Queen Majestic Canister Vacuum
IRobot 530 charges intermittently
Reset the Roomba: hold down "spot" and "dock/demo" for fifteen seconds, then release and listen for the tune. Then charge the Roomba overnight. The next time you run it, the unit should run longer. If not, call support and let them know you may have a battery problem. 1-877-855-8593 (I strongly encourage you to have the Roomba with you if you call.)
Aug 30, 2009 | iRobot Roomba 530 Robotic Vacuum
DC07 stops after short time using and will not start until it has rested for a while. Is it running out of steam like it's owner?
You could try washing the blue filter. This happened to mine and when I washed the filter according to instructions I found on the Dyson website it was fine!
Jul 07, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Irobot scooba 5800 spins quickly then sets off backwards
Remove and clean all of the wheels, and make sure the cliff sensors under the bumper are clean. Tap the bumper with your hand-- really smack it a couple of times. It sounds like the Scooba believes it's stuck against an obstacle.
May 10, 2009 | iRobot 5800 Scooba Vacuum
Front wheel problem
I would send it to protechrobotics. they will test all your components and let you know what needs to be done. if the repair is more than it's worth--they will help you out too.
http://www.protechrobotics.com/
Apr 07, 2009 | iRobot Roomba 4210 Bagless Robotic Vacuum
Rainbow stops shortly after starting to vacuum
There is a thermal fuse on the motor field that sometimes fails. Sometimes the fuse does what it is supposed to do - prevents motor from overheating.
Causes:
a) Improperly worn motor brushes
b) bad motor bearings (that usually leads to uneven motor brush wear)
c) very dirty cooling air filter
To access filter and the motor - use small flat screwdriver to remove clear side panels. You will see 4 or 6 Phillips screws. Remove screws - cap will come off.
Good Luck,
Rocky
Mar 17, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
78 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
