Question about RCA R52WH73 Projection Television
I need the diagram schematic the tv rca t19060gy 19 in I desperately need the schematic for a convergence amplifier problem w/a RCA 52" R52WH74...help!!
  • dun1971 Aug 10, 2008
    Thanks Slint that's almost what I needed, however they don't have my exact TV. I contacted them to see if they can help any more. Thanks again!
  • RCA Master
  • 8,617 Answers
You can get the service manual for the ITC222 at the following link emailed to you and they provide free tech support to help you diagnose the problem when you purchase the manual. Heres the link.
http://servicemanuals.vstore.ca/
Posted on Aug 10, 2008
My 52 inch RCA projection tv has a blue line around everything white
The convergence needs correction. If its not able to be cleared up by running the auto convergence feature in the setu menu then you will need to repair the convergence. You can get free technical assistance and parts foor your RCA at www.tvrepairworld.com they are RCA experts with that chassis
Feb 10, 2013 | RCA R52WM24 52" HDTV Projection Television
Hook up a gaming system
I presume you are connecting to the RCA lines in front of the tv. If so you can try
Channel 90 = Video 1 (When using the S-Video Input)
Channel 91 = Video 1 (When using the Composite Video Input)
Channel 92 = Video 2
OR try pushing 00 and then you can channel up or down.
Sep 23, 2012 | RCA T19060GY 19 in. Combo
Need of a Convergence Board for an RCA PROSCAN Model 80690WW1
You can order a replacement Convergence Board or Convergence Amplifier Board for this model (PS8069) from a major RCA parts distributor at the link below:
RCA PS80690 Replacement Part Convergence Board
RCA PS80690 Replacement Part Convergence Amplifier Board (2F27039-502)
Please note, these boards are no longer available from the original manufacturer (RCA) and only appear to be available from PTS.
Apr 08, 2009 | RCA Televison & Video
My RCA projection TV - the picture only shows red green and yellow and the picture is distorted almost concaved. It overlaps and nothing is clear. All 3 bulbs seem to be working. No idea what is wrong.
Sounds like convergence problems. This TV may not have the standard "STK.." modules. These sets are bad to lose voltage feeding the convergence amplifiers.
Mar 31, 2009 | RCA P52926 52" Rear Projection Television
The picture on my tv is warped
Hello jbvail86,
This problem you are having is a convergence problem. The convergence amplifiers are malfunctioning. Both Amplifiers need to be replaced. You will need a schematic, and a multimeter to check the voltages on the pins of the convergence amp ICs. Once you find that the ICs are bad you will need to de-solder them and the biasing resistors and replace the ICs and resistors. The schematic will help you find the proper resistor values.
I hope this helps
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Dec 03, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
19, signal 19, 19, what is it trying to tell me?????
The only error code 19 for the ITC222 chassis listed from RCA/Thomson for 19 is invalid chassis detected. Which doesnt make sense unless you have replaced a PCB with a wrong part number.
Jul 22, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Convergence
This is a sign that the amplifiers are on the verge of going out since it is able to exert partial control over the CRTs. I would suggest that you try manual convergence, follow the direction in the schematic diagram on how to do this. If this does not work then I would suggest either changing out the convergence amplifiers and all of  their biasing resistors, or having a qualified TV repair shop do the job for you.
I hope this helps,
Thank you,
Shuttle83
Jul 08, 2008 | RCA HD52W59 HDTV Projection Television
RCA R52WH73 Projection Television Logo
401 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
