Question about Intertherm P3RA-048K Air Conditioner
How to clean?
I have a Ultraflex Intertherm central unit that came with the Mobile, which is a 1985. What is the best way to clean the (coils)? It has a lot of dust and debri that has built up. I have been leaning a filter on both sides, but it still needs a good cleaning. Help please!
    New Friend:
ANY HELP ON HOW TO CLEAN MY A COIL AND OTHER INSIDE PARTS I WOULD BE THANKFUL.. DONT KNOW WHAT PANEL TO REMOVE. I HAVE NEVER DEALT WITH AN ENTIRE OUTSIDE UNIT,
Posted on Oct 21, 2013
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
Go to a ac supply house and tell them you need a good coil cleanner at about $10:00 a gallon.
Posted on Sep 03, 2008
How do i clean coils inside intertherm unit
Do you mean the inside coil? If so the plenum on the furnace will need to be opened and sprayed with a coil cleaner, preferably one that foams. If you have pets you might need to take the cover on the end of the coil off and take a vacuum cleaner or shop vac and clean the hairs off the coil. You don't need to rinse as it will clean its self when running.
May 11, 2014 | Intertherm Heating & Cooling
Best way to clean indoor airconditioning coils
Open up unit locate evap.coil with small brush clean coil then use evap.coil cleaner its self rinsing but if you can wash with hose without getting water inside home do so.
Apr 02, 2013 | Intertherm P3RA-048K Air Conditioner
My A/C blowing air, but it is not cool. It has started freezing up. We just replaced the air filters and since then it is freezing up. We even gently cleaned the a/c coils before replacing the filters. ...
Hello, sounds like it is either a low charge or lack of airflow, what type of filter are you using? sometimes those filters that claim to be super effecient will actually cut down on your airflow and cause the ac to freeze up.
Jul 15, 2011 | Intertherm Heating & Cooling
1985 intertherm ultraflex needing a filter for the bottom door to the unit its about an inch thick and looks as if its never been cleaned or replaced Where do I purchase a new filter??
intertherm units were used in many mobile homes. you can google mobile home supply
companies and should be able to find the replacement. Hope this helps.
Jul 08, 2011 | Intertherm Heating & Cooling
Hi. I have an Intertherm air handler and central air unit in my mobile home - Model # (E2EB-012HB) air handler, and a (03QA- 036U- B) A Coil.Simply put, When the cooling unit it running, it cools very...
The A coil (Evaporator) is dirty and needs cleaned by a professional. Dirt has clogged the fins in the coil and is blocking most of the airflow through the coil so the air has to go around the coil picking up the water as it does and sending it everywhere.
Has a service tech remove and clean your coil and reinstall it and your problem will be solved.
Jun 20, 2011 | Intertherm Heating & Cooling
Where can I find a manual for my coleman cam II central air conditioner for a mobile home? I recently purchased the mobile home and would like to know what steps to ntake to make it work at its best. ...
Check the website for Coleman/Intertherm for a manual, you will need the model and serial numbers of the unit. The filters for these typically sit on top of the unit, some come with frames, some lay directly on the coil. If you can't find a manual on the website or by contacting the company, check the yellow pages some towns have a mobile home supply house that would be able to help.
Aug 30, 2010 | Coleman Heating & Cooling
Intertherm Air Handler Coil leaking water
replace it it's junk - going to do that this time because this is the fourth year of the same problem on the hottest days this intertherm junk downflow ac unit condensates where it will not and con not be captured by the pan - built by relatives of the guy who designed the titanic -
Apr 07, 2010 | Intertherm P3RA-024K Air Conditioner
Smoke coming from furnace
You may have something (paper,dust, etc.) on the electric coils. There may also be a short in the element.
Mar 24, 2008 | Intertherm P3RA-048K Air Conditioner
Intertherm ultraflex mobile home furnace
Is this a 120v motor, or 220v? If you checked for power, I assume you kind of know your way around a meter. When checking for power, don't check to ground, check the line. You could have power going in, but unless its going back out, completing the circuit, or missing a leg, in 220v case, it still will not work. Also, most heaters have some sort of delay, so after you hook it back up, and the burner heats up wait a few minutes for the fan to come on.
Dec 30, 2007 | Heating & Cooling
Intertherm P3RA-048K Air Conditioner Logo
1,412 people viewed this question
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
Dan Webster
Dan Webster
Bill Long
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
