Question about Sanyo Cameras
I need to buy a cable to link my camcorder to laptop. the cable i require is 3 jack to usb. where can I buy one
  • 155 Answers
Http://www.handhelditems.com/google-3in1-stereo-jack-adapter-p-19223.html
Posted on Nov 20, 2008
    Sergeant:
    Champion:
  • 248 Answers
The cables you need are always available in computer shops or electronic shops go to your local mall or shopping center.
Posted on Aug 10, 2008
How do I connect a camera to my pavilion n5430?
Follow these steps :
Identify the ports you have on your computer and video camera. Typically there will be a small door or flap at the rear or near the bottom that covers the ports. You computer may have ports in the front as well as the rear. You video camera may have more than one of these ports and may not have all of them.
Find the i.LINK port. i.LINK is
version of IEEE-1394 standard (aka) Firewire. It is commonly found on DV (Digital Video) varieties of camcorders. You may find the smaller 4 pin connector on your camera if it is a compact video camera. Typically the larger 6 pin variety is found on computers and larger camcorders. i.LINK transfers both video and audio. For more information click on "How i.LINK Works" in the Resources section.
Find the USB port. USB (Universal Serial Bus) is another connector like i.LINK for transferring digital video and audio. Typically a mini USB connector such as the "Mini-A" will be found on your camcorder than large flat "Type A" connector typically found on computers.
Locate the S-Video jack. The S-Video jack is a round 4 pin analog connector. S-Video is for only video transmission. You will need to connect the red and white audio RCA jacks or use a phono port to transfer the audio to your computer.
5
Find RCA Audio/Video Jacks. These round single pin ports usually are found in a set of three of different colors. Yellow is video, red is for right audio, and white is for left audio. On some Handycam's, there may be a mini-plug that is an all in one Audio/Video jack that you plug in a special cable (as seen in the photo) that connects your camera to standard yellow, red, and white RCA jacks on your computer.
6
Choose a matching pair of ports you have on both your computer and your camcorder.
7
Turn both your computer and camcorder off.
8
Connect your computer and camcorder with the appropriate cable. Turn on both your camcorder and your computer.
Nov 20, 2010 | Computers & Internet
Dcr-pc9e handy cam with no connectors
To transfer video from your camcorder to your computer you will need a firewire cable (IEEE 1394). Only with this cable you will be able to transfer video.
Please note that you will also need a firewire port on your computer. if you don't have one then you can buy a firewire PCI card.
Please see the following link for more info and pictures.
http://en.wikipedia.org/wiki/IEEE_1394_interface
Regards,
nicolasiac
Mar 25, 2010 | Sony Handycam DCR-PC9E Mini DV Digital...
Need audio video cable. what kind do i buy
If you have usb. Then you want usb to rca jacks
If you have rca jacks, then you want rca to rca jacks
If you have HD connection, then you want hdmi to hdmi cable
You can get the a/v cable from amazon.com
Nov 30, 2009 | JVC GR-D22U Camcorder
Can't upload to my laptop!
Option 1:
If you want to use the USB cable to connect the Camera to the Computer to transfer the video to the Computer then:
(Applicable for Vista Operating System Only.)
This Camcorder does not support USB streaming with the VISTA Operating System. Use an i.LINK cable to transfer the video to the Computer. The i.LINK port is also called IEEE 1394 or Firewire port. (An i.LINK is a black D shaped connector with 4 or 6 pins. The type of cable to be used will depend on the i.LINK port of your Computer. The Sony Camcorder will have the 4 pin i.LINK cable and if the computer has the 6 pin i.LINK port, then you may have to use the 4 pin to 6 pin i.LINK Cable).
You can use any video capturing software like Windows Movie Maker to transfer the video from the Computer.
Refer this Link for the instruction to transfer the video to the Computer using i.LINK cable.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C111893
NOTE: As the Camcorder does not support USB streaming with Vista, it is not required to use any Sony Device Driver to transfer the video to the Computer. You do not require any Drivers or Software from Sony to transfer the video from the Camcorder to the Computer using the i.LINK/Firewire interface.
Option 2:
(Applicable for Windows XP Operating System only):
If you are using a Windows XP Operating System then you have to install the USB Streaming Driver in the Computer from the supplied Software disk with the Computer.
Check this Link for the instruction to transfer video to a Computer using USB Streaming.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C222820
If you do not have the supplied Software disk then I suggest that you use the i.LINK cable to transfer the video.
Your Camcorder does not supports a Wireless MIC. However, you can use a MIC with your Camcorder using the available Accessories Shoe port.
Good Luck!!!!!!!!!!!!!!!
Sep 18, 2009 | Sony Handycam DCR-PC110 Mini DV Digital...
Cant transfer videos to pc
Option 1:
Option 2:
Option 3:
If you are using an i.LINK cable then:
The Camcorder will flash the DV IN message as soon as the i.LINK/Firewire cable is connected to the Camcorder.
If you are getting the DV IN message then it indicates that the Camcorder recognize the connection.
If you are not getting the DV IN message as soon as the i.LINK cable is connected with the Camcorder then the issue may be with either the Camcorder or with the i.LINK cable.
Try resetting the Camcorder or try with different i.LINK cable. Locate the RESET button behind the LCD screen of the Camcorder. (You will be able to locate the RESET button by opening the LCD Screen. The Camcorder should be switched ON when you reset the unit. Press the RESET button using a sharp-pointed object).
NOTE: Resetting the Camcorder will reset the settings of the Camcorder to the factory settings including date and time. It will not delete any data saved in the Camcorder.
If the issue still persists after resetting the Camcorder and with different i.LINK cable then your Camcorder requires service to resolve the issue.
Sep 17, 2009 | Sony DCR-TRV285E Digital-8 Digital...
UNABLE TO TRANSFER VIDEO FROM SONY HANDYCAM DCR TRV TO MY LAPTOP
Refer this link for the instruction to transfer the video to the Computer using i.LINK cable.
Good Luck!!!!!!!!!!!!!!!!!!!
Sep 11, 2009 | Sony Handycam DCR-TRV22E Mini DV Digital...
Sony Handycam DCR-HC28
Unfortunately, it's not exactly a trivial process. The basic steps are as follows:
1) connect the camcorder to the computer
2) transfer the video from the dv tape to a file on the computer
3) optionally, edit the video file
4) upload the file from the computer to youtube.com
1) the camcorder has 4-pin 1394 (also called firewire or i-link) jack, and the computer (if equipped) either has 6-pin 1394 jack or 4-pin 1394 jack (on some notebooks). if your computer doesn't have a 1394 jack, you need to buy a 1394 adapter (eg. pricegrabber.com)
2) transfer the video from the dv tape to a file on the computer hard drive using editing software or a software utility designed for doing just that. this software may come with the camcorder or the 1394 adapter.
3) optionally, use editing software to take an excerpt from the file, rearrange parts of the video, add titles, etc., and output a new file
4) upload the file to youtube.com. there are some guides on their website as well (eg. youtube.com)
I hope that helps.
Aug 12, 2008 | Sony Handycam DCR-HC28 Mini DV Digital...
Import videos from handycam to computer
i am unable to import videos from my mini dv digital handycam to my laptop with vista as operating system.is a i-link cable required or usb cable will do? i have the picture motion software and import from handycam software dowloaded through net. can u help me out???
Jul 20, 2008 | Sony Handycam DCR-HC36 Mini DV Digital...
Which cable do I need to conect my camcorder to pc
if you need a visual on it, there is a video on www.HandBookLive.com under Electronics. The example is Belkin IEEE 1394 cable (Firewire and I-Link compatable) and it connects digital camera to a laptop.
May 28, 2008 | Sony Handycam CCD-TRV78E Camcorder
Connecting analong camcorder to computer
The only Analog camcorder that has a USB Connection for transferring pictures or video is the SC-L770. The SC-L770 can transfer video (live or recorded) and still photos through the USB connection. You can also transfer audio using the audio cable provided. After installing the driver and software, you can begin transferring data using the software provided. Connecting to a PC 1. Connect a USB cable to the USB port on the PC. 2. Connect the other end of the USB cable into the proper terminal on the camcorder. (USB jack) 3. Connect the audio cable to the Line input jack of the PC. If the PC has no Line input jack, connect the audio cable to the MIC input jack. In this case, however, a noise may be produced depending on the PC. Notes: * If you disconnect the USB cable from the PC or the camcorder while transferring, the data transmission will stop and the data may be damaged. * If you connect the USB cable to a PC via a USB HUB or simultaneously connect the USB cable along with other USB devices, the camcorder may not work properly. * In this case, remove the other USB devices from the PC and reconnect the camcorder. Some other Analog Camcorders have a snapshot mode which allows you to take a still photo with your camcorder. However, you cannot transfer these to a computer unless you purchase additional hardware such as a capture card. Some capture cards have analog a/v inputs which will allow you to use the a/v outputs on the camcorder to connect to your pc and transfer images and video. You can purchase a capture card at most computer and electronics stores. Samsung does not support capture cards.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Cameras Logo
54 people viewed this question
Top Sanyo Cameras Experts
ray gallant
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
