Question about SmartDisk 160GB FIRELITE PORTABLE FIREWIRE HARD DRIVE 5400 RPM 2.5IN 160 GB FireWire 400
Won't recognize on windows XP(SP3)
I just downloaded Widows XP(SP3) to my laptop- and had numerous problems with my external drives being properly recognized. Still can't get my Smartdisk Firelite USBFLB160 to recognize on my laptop- but it will come up on the desktop running XP(SP2). What is the problem? Are there some setting that need to be adjusted now?
V/R
Jon
  • 1 more comment
  • Anonymous Nov 06, 2008
    Have the same problem. Thanks for the comment, it does work temporarily. Make sure you highlight the drive in the bottom portion of the screen once the disk management application is open, then select choice to make partition in here you'll have the option to assign the drive and then decide if you would like to format too or just assign drive.
    hope it helps
  • joshwitham Dec 03, 2008
    My computer running xp will not recognize my smartdisk firelite
  • ALEISTER Jan 21, 2009
    XP SP3 won't recognize my new SimpleTech S500g external USB hard drive
    New Friend:
  • 21 Answers
Try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use asoftech data recovery program to recover your files.
http://www.asoftech.com/adr/
Posted on Dec 06, 2012
    Scholar:
    New Friend:
  • 27 Answers
Turn the computer off without the external hard drive being plugged in.
plug the external hard drive in a usb port, power up, the systems post boot up will find the drive and inform windows what hardware is installed.
When windows boots up, it will look at all the hardware and find the external hard drive, when windows finishes booting up you should be able to see the drive in my computer.
If you can't access your files,data recovery software can help.I used this one called Tenorshare Data Recovery to retrieve files off crashed HDD and it worked.
If needed,you can download it and scan your hard drive to preview whether your files can be recovered. BTW, you can get it from
Data Recovery for Mac OS X
Data Recovery for Windows OS
Remember: Do not save your recovered data onto the same externalhard drive, otherwise the files you want to recover may be written over.
Posted on Jun 15, 2012
I have the same problem. Go to Programs-Run: diskmgmt.msc. You can assign the drive a letter and then XP SP3 will recognize it. The problem is you still have to do this every time you plug it in.
Posted on Oct 04, 2008
SOURCE:
My usb ports on my laptop only recognizes my phone and mp3 player and not my external hdd, it tells me to format the plug and play external hdd. It does not do this in all my usb ports though
Maybe the external hard drive is to large to be recognized by your computer. Some computers won't recognize real large external drives.
Another problem could be that your external hard drive does not support Windows 7.
May 20, 2012 | Acer Computers & Internet
Fujitsu USB handydrive is asking for a driver upon connection with a deskdtop running XP SP3. Same SP3 on HP and Toshiba notebooks have not problem recognizing the disk. Is there a special driver need. do...
If your external HD works with other notebooks then the XP SP3 operating system may cause that problem. There may be a driver conflict.
To solve that you should change the drive letter name of your external hard disk. To be able to change the drive letter of it, you can install and run the "Tweak UI" software which is downloadable from the windows website. To download Tweak UI software for windows XP, please click here.
1. After installing and running the Tweak UI you will see the screen below.
You can access your system settings using this tool such as disk drives, and you will be able to change the current settings.
Be careful not to change the other settings.
2. Click on "My Computer > Drive" as shown in the picture below.
And assign another drive letter to your external hard disk (for example checking drive letter F:) and click button "Apply".
3. Then restart your computer to see if it works.
This is one of the solutions that I did before. Your problem may need different solution. This is possible then you can ask again. Fixya experts solve every problem.
But I hope this helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Apr 09, 2010 | Fujitsu Computers & Internet
Thumb drives not recognized by xp sp3 ...I haven't been able to find a solid answer why XP pro SP3 won't recognize a thumb drive inserted into a usb port in front or on back of the desk top as well as a...
wgnickless
Most likely there is another device that has the drive letter that the USB drive wants to use already assigned to it. The link below will show you how to change the drive letter in Computer Management.
How to change your drive letter in Windows XP
http://www.fixya.com/support/r4183994-change_drive_letter_in_windows_xp
Let me know if you have any more problems or questions
Issken
Oct 15, 2009 | Microsoft WINDOWS XP PROFESSIONAL SP3...
Hi, I have an external disk connected to an usb port. Sometimes my computer stop to recognize the connection and my external disk doesn´t works anymore, until the next reboot. What can I do to resolve...
The only other solution other than rebooting is to remove the cable from the usb port and reinsert it. Sometimes the computer will recognize the drive and it will work properly.
Aug 13, 2009 | Microsoft Windows XP Professional SP3 Full...
Im using hp dv6700t laptop,i want to install xp on my laptop
Your laptop has a SATA hard drive and windows XP doesn't recognize those drives cause the operating system came out before those drive were made.
Follow these steps I found thru google to get windows xp sp3 to recognize your drive:
http://en.kioskea.net/forum/affich-39282-xp-can-t-recognize-hard-drive-for-os-install
You'll have to use a program to do this but people explain how to do it on that page plus the program is free.
Jun 25, 2009 | HP Pavilion dv6000t 15.4" Notebook Laptop...
Maxtor Basics 320 GB external harddrive cant be recognized
There's a good chance the shop you bought the drive from didn't have SP3 installed. For some reason, SP3 has an issue with USB peripheral devices. Windows has created a patch to rectify the problem. Click on the link below and install the "Fixit" patch to enable your PC to recognize your HD. Best of luck.
Greg
http://support.microsoft.com/kb/925196#fixit4me
Jun 18, 2009 | Maxtor Basics Personal Storage 3200 Hard...
I havea seagate 500gb external hard disk, when i connect it wth the laptop the hard disk is not recognised on my laptop. i have windows xp professional installled in my laptop
Click on the link below and then click on the "Fixit" button. Windows has a patch for all external devices not recognized by PC's including HD's. This is especially an issue for those who've recently installed SP3. Best of luck with your problem.
Greg
May 25, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Laptop Won't Recognize External HD
You can try opening the device manager in Window XP and uninstall the external hard disk (make sure you show unplugged devices).
Then replug the drive again, and it should reinstall the drivers.
Jules
Feb 22, 2009 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
Disk drive not detected
When the drive is not recognized, try going to start->control panel->administrative tools->computer management->disk management and see if the drive is recognized by it, if so try assigning a drive letter then exploring it
Nov 17, 2008 | Dell Latitude D600 Notebook
Open Questions:
SmartDisk 160GB FIRELITE PORTABLE FIREWIRE HARD DRIVE 5400 RPM 2.5IN 160 GB FireWire 400 Logo
1,775 people viewed this question
Top SmartDisk Computers & Internet Experts
Jeffrey Groves
Jeffrey Groves
Duncan Mutch
Kris
Are you a SmartDisk Computer and Internet Expert? Answer questions, earn points and help others
