Question about Polaroid FLM-3734B 37 in. LCD HDTV
BUZZING NOISE POLAROID 37IN. FLM-373B
I JUST GOT THIS TV YESTERDAY AND IT IS MAKING THIS BUZZING NOISE. IF WE RAISE THE VOLUME YOU CAN VERLY HEAR IT.AND WENT I PRESS MUTE YOU CAN'T HEAR IT. SHOULD I RETURN IT OR IS IT NOT SUCH A BIG DEAL
  • 2,071 Answers
It is better you return it is still under manufacturers warranty. Anything you may do to the HDTV may void it's warranty. I work at an authorized service center and have seen too many times when people think they can fix something themselves and end up with a voided warranty. You really should take it in or have a authorized service center come to your home and check it out for you. In home service is offered by manufacturers and is normally covered by the warranty.
Anything you may be able to do to get it working this time will most likely happen again since it has happened before. Getting it serviced by an authorized service center may fix the problem permanently.
This may not be the answer you are looking for, but it is the smartest thing you can do. A little hassle now getting it fixed properly will probably save you money and more of a hassle in the future.
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Posted on Aug 10, 2008
SOURCE:
Polaroid flm-373b lcd tv - making a loud buzzing noise. Picture is fine.
Possible that the main power supply unit which is the SMPS- switch mode power supply- has a faulty capacitor or in the INVERTOR board which has changed the value and so the frequency being changed can cause higher huming level- reduced to lower frequency.
so check the board for leaks , if so replace. Also check if the threshold voltages are below level in these circuits. if so the capacitor can be identified. If there is change after the component heats then simulate the circuit board and confirm using a hair dryer.
Sep 23, 2011 | Polaroid FLM-3732 Television
Polaroid FLM-373B lcd t.v. making loud buzzing sound the past couple of days. It usually goes away after a few minutes, but now it won't.
Same problem. Just noticed three days after ATT U-verse was installed. Now doing it all the time. Please help.
Apr 08, 2010 | Televison & Video
Buzzing sound coming from TV Speakers and any external speakers
change your pre-amp ic sure it will work. or maybe cold solder from the board.
May 05, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
Polaroid FLM-3734B 37 in. LCD HDTV Logo
207 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
