Question about Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Can't get analog stations
I have a Sharp Aquos LC 37Gd6u and everything was working fine until one day after hooking up a new DVD player my Input 1 stopped working and I can no longer get analog stations. When I use my surround sound system I can get audio for the analog stations but still no picture. Does this mean I have to wait until Feb of next year for my TV to work again?
  • 927 Answers
Good Day, Jamievass;
Please disconnect the NEW DVD Player, does analog stations come back? What input are you using; RF, Comp, hdmi? If ok try using another input or you may need a main bord that processes the signal.
Good Luck, big IRISH.
Posted on Aug 21, 2008
Tv has blue dots over screen
Check for loose contacts in power outlet, RC cable, jack and socket. Change input device to some other like a DVD player and see.
Aug 05, 2012 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
How do I connect an analog antenna to a 32 inch sharp aquos tv? and do I need a specific input setting?
antennas are not analog or digital, just VHF, UHF and they typically connect to a RF coaxial jack on the TVs rear panel. 75ohm silver round jack. Select in your TVs menus, AIR when you want over-the-air TV stations and do a new channel scan to pick up local channels.
May 06, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos LC-37 is 20 months old and would not power on
it is 99% certain that what needs to be replaced is the power board.
That's the #1 problem across the board with TVs that work for some time and then start behaving like you describe.
If you know what a scredriver is I'd suggest you do it yourself.
You can seek for a new board on eBay or through Google. I'd search for "LC-37GD6U power board".
If you don't find one you'd start searching for other similar TVs and compare the pictures of the board with what you pull out of yours.
Of course you can have a technician do all that for you for a $150 more.
Nov 03, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
TV somehow switched to analog even though it is a new digital TV. How do I switch it back on the remote?
It most likely has the capability to tune analog stations in as well. To get to a digital station you should just have to punch the numbers in on the remote IE: 5-1 or 5.1
Oct 17, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Problem connecting my PS3 to my Sharp Aquos LC-C3237U LCD TV
Your PS3 set itself above the max resolution your LC-C3237U. Most likely the PS3 is doing 1080P, but the highest the Sharp can do is 1080i. So do this:
1. Connect PS3 to TV (you can use the current cable or analog cable)
2. Turn on TV and set input to port PS3 is on.
3. Make sure PS3 is connected via correct cable.
4. Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.
Sep 15, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
SHARP aquos 1080p HDTV: VCR image flickers when playback
I have the same model TV and the following worked for me. I am using A/V cables attached to Input1 on back of the TV.
On your Sharp TV remote control:
1. Select the Input (1-5) that is attached to your VCR.
2. Go to the menu and select options.
3. Change your color system to NTSC.
This should stop your picture frome flashing on and off.
You still may have a issue with the screen colors. I don't know of a way to address this, other than to make the picture monochrome.
Hope this helps.
Jun 26, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
My Sharp Aquos 46" LCD
Digital inputs on Aquos TV's are "always on," usually the HDMI inputs and DVI inputs. As opposed to analog inputs 1, 2, or 3, are only activated once something is plugged in.
Try plugging in another HDMI sources into input4 or 5, if its still not working, the TV needs a new Main Board. Try calling Sharp 1-800-237-4277 and locating a local service center in your area.
Mar 14, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp Aquos
Shine a bright light on the screen, do you see the image (but very very very dark)? If so, its either a bad inverter or lamps, which are only sold with the LCD panel as an assembly, which is very expensive (more than the TV is worth).
Mar 09, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Sharp 46D62U incompatability
Most likely a defective Main Board. I suggest calling Sharp 1-800-237-4277 to locate your local Sharp Authorized Service Center.
Nov 06, 2007 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp Aquos LC-37GD6U 37 in. LCD HDTV Logo
216 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
