Question about Husqvarna Designer I
Embroidery unit When I plug in my embroidery unit the display to clear the hoop comes up. I do it and then the prompt comes up again! I have tried to turn it off, take the embroidery unit off in hopes of recalibration. I have also cleaned it to include the plugs with no resolution. Help please!
  • 201 Answers
Do you have a hoop already on when you first re-calibrate the embroidery arm? You need the embroidery arm ONLY when you first turn on. Don't put the hoop on until you are ready to start embroidering. If this is not the problem, try re-loading the machine operating system. If you did not save your floppy or USB file, go to Husqvarna website and download the latest one, and re-load it. (Be sure to select the correct file for your particular machine i.e. floppy or USB.)
Pamsquilt
Posted on Oct 19, 2008
What is the symptom of a broken hoop
Sounds like you might be having problems with the machine not wanting to start sewing an embroidery pattern or not recognizing the hoop size. If the former, and the embroidery is full size (say 100x100mm), try reducing the embroidery slightly (say 98x98mm). If the latter, your embroidery unit may need slight adjustment to correctly identify the hoop. Its not an elaborate adjustment but you will probably need a profession to accomplish it.
Mar 23, 2014 | Husqvarna Viking 1
Singer Quantum XL 6000 embroidery unit keeps saying the embroidery hoop is loose or not installed. There is some problem with the electronic contacts and the embroidery hoop. Can't get any help.
Try push in and push out your hoop several times into the carriage, then if the problem is still there, most likely the carriage hoop lock sensor is faulty.
Oct 21, 2013 | Singer Quantum XL-6000 Computerized Sewing...
Embroidery unit
This can happen, click back to tools option check whether hoops selection is correct. If this is not the problem, off your machine then put on again. If message remain pull out the embroidery carriage & push in again. Hope it can work.
In jam situation, just exit from your embroidery option, fix the jam by moving the embroidery carriage, work on a different design and see if it work. Sometime a design may not work fully.
Sep 29, 2013 | Singer CE-100 Futura Computerized Sewing...
In the middle of stitching a design - and when I came to a color change, the new color began stitching 1 to 2 inches below where it should. The screen showed the correct place, but the needle was way too...
If the design isn't too big, try rotating it in the hoop and stitch it sideways. If it works in that position, you probably should have the embroidery unit cleaned. I recommend the embroidery unit be serviced every 5 years. It may need it more often depending on your environment.
Dec 11, 2010 | Husqvarna Designer I
I bought a new embroidery unit for my designer 1 when I but it on it makes e terible noise and says to slide of hoop and clear position for i . embroidery position'But it won't go into embroidery...
Don't know for sure what is happening, but you should not put on a hoop until you are actually ready to embroider. The unit goes on while the machine is turned off; turn on the machine; it will make a noise; you should get a pop-up on your screen to Calibrate the unit. Touch this button, and the arm moves into position ready. Load your design and choose the correct hoop then put the hoop and project on the machine. Also be sure that your design will fit in the hoop selected.
Sep 01, 2010 | Husqvarna Designer I
Machine says that I don't have an embroidery hoop attached, but I do.
First turn off and disconnect embroidery unit and hoop from the machine. Plug machine back in and connect the embroidery unit only and turn the machine on. Reattach the hoop and test to make sure it's secure. Your hoop might not have been attached snuggly enough or you might need to put on the small hoop.
Dec 22, 2009 | Bernina Artista 180
Wrong hoop display
If you haven't already done so, download the latest update for the Designer 1 and install it. 2.22 is the latest. Your current software version is in the lower right corner of the display when the machine is first turned on. It only shows for a short time so be ready when you turn it on.
If you have one of the last few versions, the embroidery unit will calibrate by moving the arm to the right and the hoop holder moves away from you, then back part way to the left and the holder will move back toward you and you will then hear a "grunting" sound as the holder moves slightly forward and back to finish verifying its position. If the arm fails to move from side to side or the holder doesn't move forward and back, the embroidery unit may not be fully connected to the machine so turn the machine off, slide the unit 2-3 inches to the left and firmly reconnect it and try again.
You can't bypass the "wrong hoop" display. We just have to convince the machine that you have the correct hoop installed. Let me know how it goes.
Jun 07, 2008 | Husqvarna Designer I
The carriage of the embroidery unit is not move automatically to the embroidering standby position.
Is the need in upright position ?
or have you fitted the embroidery hoop correctly.
If all else fails switch off and start up again - should then automatically go to correct position.
May 16, 2008 | Singer CE-200 Quantum Futura Computerized...
Futura ce 200
I had the same problem and found that the feed dogs must be in the lowered position otherwise nothing will happen,remove the embroidery unit and check the selector and try again,
Mar 24, 2008 | Singer CE-200 Quantum Futura Computerized...
Sewing Machines Logo
268 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
