Question about Maytag PAV2300 Top Load Washer
Overfill maytag won't stop filling when it reaches the correct level. Just keeps filling.
  • jojo1945 Aug 10, 2008
The vacuum line in side of the controls may have came off that is what happen to me it plug behind the switch
Posted on Aug 19, 2008
Water continual running piease help
The Water Inlet Valve on your washing machine is used to fill the tub with cold, warm or hot water for the wash and rinse cycles. The valve is operated by electric solenoids that are controlled by the timer or electronic control board and the water level control/water level selector switch or pressure switch. If your washer continues to fill during a cycle, the water inlet valve could be at fault. To verify that the valve is at fault, unplug the washer when the symptom occurs. If the washer continues to fill, then the water inlet valve is defective. If the washer stops filling, then the problem is related to the electrical circuit that controls the valve. The water level switch is a pressure activated switch that is used to determine the correct water level in the tub. This part is normally located behind the control panel and will have a hose or air dome tube that connects it to the tub. On washers that use an electronic control, this switch may be located at the sump area below the tub. As the water fills in the tub it will compress the air in the tube and push against a diaphragm inside the switch. The switch will control the water inlet valve and turn the valve off at the correct water level. If the tube has a leak or is plugged, not enough pressure may be created to activate the switch and the washer may overfill. If the switch is defective it may also cause the machine to overfill.
To determine if the switch is bad, you should first eliminate the air dome hose as a problem. Look for signs of cracks or worn areas on the hose. Remove the hose and submerge in water. Seal one end and blow air into the other end and look for bubbles. Check for an obstruction in the hose as well. If the air dome hose appears to be ok, then the water level pressure switch may be defective. Inspect the switch for signs of a mechanical defect or debris plugging the hole in the inlet nipple. To test the switch contacts for continuity with a multi-meter, you will need to apply the proper amount of air pressure to the air dome tube and then look for the switch to go open circuit at that level. The easiest way to do this is to start the washer and allow it to fill to the normal level and then remove the power cord. Locate the pressure switch and remove the wires from the correct terminals and then perform the continuity test. There should be infinite resistance or an "open circuit" when the water level is correct. If not, then the switch is defectiv
Jan 11, 2017 | Cars & Trucks
Kleenmaid dishwasher dw271
There should be a float switch that stops filling when the correct level is reached. Sometimnes the float switch sticks, causing a flood. The float part of the switch assembly should be removed and cleaned. If it is damaged or leaky, it should be replaced
Jun 04, 2013 | Dishwashers
Top load maytag performa washer won`t stop flling both on wash and rinse cycles.
The switch the tube connects to shuts the water off. Will it cut off on high medium or low level. You can try blowing on the tube to see if it works. It should cut off when you blow.
Oct 15, 2017 | Maytag Performa PAV2200
Maytag top loadind washer. Won't stop filling up.
Make sure your drain hose to the drain pipe is higher than the water in the tub if not it will keep running and going out the drain.
Also try taking the hose off the level switch and blow in it to be sure it's not stoped up. If is it won't let the level sw cut off. air should go through it. Good luck
When you unpluged the power and it ddn't keep runing the water valve should be ok.
Mar 25, 2010 | Maytag PAV2300 Top Load Washer
Washer won't stop filling with water.
There is a pressure switch with a tube to the water drain. The switch may be faulty or needs adjustment. The tube may be blocked or disconnected.
May 12, 2009 | Maytag LSE7806A Top Load Stacked...
99 passport 4x4 tranny question
There is not a dipstick for the automatic transmission on the 1999 Honda Passport. There are two plugs on the bottom of the transmission - the lowest one is the drain plug and the one located higher is the overfill plug. You should have a fluid temperature gauge as it is recommended that the temperature be between 90* F and 135* F when checking fluid level. (I believe you can order from dealer - I have also heard that running the engine for 10-15 min will put you near the proper temperature - to be certain, the temperature gauge is the right way to do it.) Run engine for a few minutes to reach optimum temperature. The vehicle must be on level ground and at idle to properly check fluid level. With proper temperature reached - and engine running at idle - set parking brake - remove the fill plug and add fluid with a syringe or small pump until it just starts to run out of the opening. Do not open the overfill screw with the engine stopped. Replace the fill plug and shift through gears - then remove and repeat one time to achieve proper level.
Jan 17, 2009 | 1999 Honda Passport
Maytag Atlantis MAV6451 Waterfill keeps filling
hi todd it looks to me that the problem with the water level control or the small level control hose hard water &lint can sometimes clogg this hoe up remove hose from switch and blow into it hard if its clogged you will not be able to blow clean it and try if it does not work after its clean replace water level switch thanks the appliance doc
Aug 09, 2008 | Maytag Atlantis MAV6451 Top Load Washer
When washer is in super wash cycle water will not stop causingthe tub to over fill running onto the floor.
It sounds like you are trying to use the largest water level setting. If this is correct you may have a pressure switch problem.
First turn the timer to spin and get all of the water out, that start a washer cycle with the water level set to the small or low setting and see if the washer fills to this level. if it stops at the low level great Now if it continues to fill and does stop you may need a pressure switch or the hose needs to be replaced that runs from the tub to the pressure switch.
Now set at the medium level and try again. does it stop or over fill?
If it over fills you probably need a pressure switch however before you purchase this, make sure the hose is in good condition one pin hole will cause your overfill condition.
Jul 09, 2008 | Washing Machines
Maytag PAV2300 Top load washer
check your hose from the side of the tub all the way up to the water selector knob. if its loose or has even a pin sized hole in it, it will cause the maching not to sense it has reached the level selected.
Nov 29, 2007 | Maytag PAV2300 Top Load Washer
Maytag washer
Check to make sure your drain hose has a loop at least as high as washer top.  If the drain hose is not looped higher than tub water will continue to drain and it won't stop filling.  If it doesn'y reach the correct fill level it won't agitate.
Oct 29, 2007 | Maytag PAV2300 Top Load Washer
Maytag PAV2300 Top Load Washer Logo
52 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
