Question about Whirlpool Duet GHW9150P Front Load Washer
Pedestal I have an older duet washer & dryer with the pedestal under for storage (I THINK Part Number LAB2700LQ). How do I release the drawer to get something out from behind it? I called my local service shop who installed it, and they don't know.
SOURCE:
reg501
  • 413 Answers
SOURCE: need to remove drawer from
There are two ways this drawer is held in place;
  1. Open the drawer fully. Look at the rear of the support slide is there a small, black plastic lever? If so, on one side push the lever down, the other side pull the lever up. (sorry don't remember which side up or down)
  2. No lever? Remove the small screw on either side of the support slide at the front of the drawer. Lift the drawer and push support slide away from the drawer.
If you need further assistance, let me know
Regards;
reg501
The FixYa Team.....
Posted on Jun 24, 2008
SOURCE: Samsung Pedestal Drawer
If you pull out the drawer (completely) you should find 1 or 2 screws on each side that bolts the slider to the drawer. Remove these, then lift out the drawer. This then gives you full access inside. ...JimS
Posted on Aug 04, 2008
  • 848 Answers
SOURCE: remove washer pedestal drawer
  • Open the drawer fully. Look at the rear of the support slide is there a small, black plastic lever on one side push the lever down, the other side pull the lever up.
  • Remove the small screw on either side of the support slide at the front of the drawer. Lift the drawer and push support slide away from the drawer
Posted on Oct 30, 2008
  • 82 Answers
SOURCE: How can I remove the Whirlpool Duet washer pedestal drawer?
there should be a clip on the top or bottom if not pull it out as far as it will go grab it on both sides and pull sharpley towards you DO NOT GRAB THE FRONT IT WILL BREAK
Posted on Jun 29, 2009
SOURCE: how to remove drawer on pedestal
You need to remove the 2 screws holding the black rails on both sides of the drawer. Took us a while to figure this one out also.
Posted on Jan 31, 2010
How do I remove a pedestal drawer on and electrolux dryer
Hello friend, thanks for your inquiry!
I have researched that information for you and was unable to locate steps on how to remove the drawer from your pedestal. I would suggest seeking assistance from a professional for proper removal of the drawer. Hopefully this helps. -Matt
Sep 28, 2014 | Electrolux Washer/Dryer Laundry Pedestal...
Remove washer pedestal drawer Cannot remove drawer to check behind or underneath, please help.
Oct 30, 2008 | Whirlpool LAB2700ML Pedestal Drawer for...
How do you install whirlpool duet pedestal
Make sure that you get the pedestal designed for your washer. The white pedestal for the GHW9400P would be LAB2700MQ. (There are slight differences in the pedestals for different series washers. The holes in the base of the washer will not line up with the holes in the pedestal for a mismatched combination.)
First if your washer has been installed, uninstall it. You need to turn off the water. Then disconnect the power cord and (carefully) the fill hoses. Loosen the hoses first and then completely remove them. Drain the hoses into a bucket. Disconnect the drain hose from the back of the washer. Use pliers to squeeze the clamp to get the drain hose loose.
Pull the washer away from the wall. Cover the area behind the washer with cardboard and tip the washer onto its back (on the cardboard).
Pull out the drawer of the pedestal. Next snap the spacers into the holes on the top of the pedestal. (These are part of the hardware kit in the drawer of the pedestal.) Remove the shipping spacers from the front of the pedestal (behind the drawer). Remove the Philips head screw from the drawer slides and pull the drawer completely out (save the screws). Push the slides back into the pedestal.
Look at the washer and remove the feet if present. Partially install two of the hex head screws from the pedestal installation kit in the bottom holes of the washer. (These are at the center back of the washer if it is standing up.) Leave the screws about 3/8" from the bottom of the washer. Move the pedestal over to the washer and slide the keyhole openings of the pedestal over the two partially installed screws. Position the pedestal against the top of the washer and insert the remaining two hex head screws. Do not tighten completely.
Align the pedestal with the base of the washer on all sides. When it is lined up, tighten the 4 screws by reaching through the drawer opening of the pedestal. Bring the washer and pedestal back upright. Reinstall the washer (remove the packaging if this was a new install). Level (front to back and side to side) the washer using the pedestal feet (again reach through the drawer opening). Make sure that all 4 feet touch the floor. Tighten all 4 locknuts.
Pull out the drawer slides and reinstall the drawer. Reinstall the Philips screws. Close the drawer.
For pictures of the install, go to the Whirlpool support site http://www.whirlpool.com/owner_center . Search for your pedestal and get the installation manual. The direct link for the LAB2700MQ0 install is http://www.kitchenaid.ca/assets/pdfs/literature/Installation%20Instructions%20-%208537141.pdf .
I hope this helps.
Aug 04, 2011 | Whirlpool GHW9400 Duet Washer
How can I place my dryer/washer In a higher plcae?
I strongly recommend on 15" pedestal for washers or dryers by Samsung (model WE357A7P).The 15" pedestal will allow you to lift your washer or dryer to a more convenient height and will allow more storage with its convenient self closing drawer.
Aug 15, 2010 | Rival Kitchen Appliances - Others
Aug 12, 2010 | Amana Washing Machines
I strongly recommend on 15" pedestal for washers or dryers by Sam sung (model WE357A7P).The 15" pedestal will allow you to lift your washer or dryer to a more convenient height and will allow more storage with its convenient self closing drawer.
Aug 12, 2010 | Washing Machines
How do you remove the washer from the pedestal?
not an easy task---try to remove the drawer. there is a bolt going upwards in each corner (inside)
Dec 10, 2009 | Whirlpool LAB2700ML Pedestal Drawer for...
Need new drawer leveling feet
goto Sears.com .. look under parts.. key model # if you have it..
Jan 21, 2009 | Whirlpool LAB2700ML Pedestal Drawer for...
Whirlpool Duet GHW9150P Front Load Washer Logo
195 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
