Question about Nikon Coolpix L11 Digital Camera
No image data, Can't load pics
While reviewing pics on my Nikon L11, it gets stuck on the same picture every time, so I try to delete that picture, then says "file contains no image data", and now I can't load any pictures to my camera. In the Microsoft Scanner and Camera Wizard, they all load as red x's.
    Scholar:
  • 37 Answers
here is a easier way to view your pictures.....
if your running Windows Xp or Vista great.
select your menu button on the backof the camers , then Shooting menu, then Set up, scroll down to Interface, then USB, select mass storage. press menu to exit.
turn your camera on after you connect the USB cable to your computer and camera.
a new hardware wizard should be active, Xp & vista provides the drivers and a one time deal. your camera turns into a removable hard drive or like a jump drive.
you should click on the camera icon and see the contents of the camera.
Dont forget if you have the photos on the camera's built in chip, you can only delete the photos on the camera with the delete button on the camera.
Or if you have a removable SD card you can delete the photos as viewed on your PC (like a removable hard drive or jump drive).
Posted on Aug 12, 2008
We have a Nikon Coolpix L11 camera and it will suddenly not download/transfer pics - on any program and only 65% on the supplied program. The camera is only used a few times per month and pics are...
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo cataloging program.
May 05, 2011 | Nikon Coolpix L11 Digital Camera
I accidentally deleted a picture from my Nikon Coolpix L11. How do I recover it?
You can often successfully recover deleted files from a PC, phone or camera memory card or USB Memory stick, it just depends on what's happened since the files were deleted.
When you delete files the data itself isn't deleted, just the index entry that says where the data for those files is located. The space containing the deleted files is also now marked as free space so it is available to the system for any new files to be written there instead.
If and when that happens, then it becomes too late to recover your deleted files so it is very, very important to not save any new files or data to the device concerned.
If the deleted files are on a memory card or USB memory stick, just don't save any new files to it.
One of the easiest ways to see if you can recover deleted files is to try some file recovery software. Recommended this data recovery as it saved my life many times.
http://www.asoftech.com/apr/
Dec 06, 2010 | Nikon Coolpix L11 Digital Camera
Pictures stuck in transfer; everything greyed out
Put the card in a card reader and download the pics.
Apr 01, 2010 | Nikon Coolpix L11 Digital Camera
Unfocused Pics
If you use the "macro" setting (the flower symbol on the command dial), and are holding the camera steady, it should work. Try to ensure sufficient light by shooting near a window. You should also disable the flash by using the arrow on the dial to go to the "no flash" setting. The main problem is most likely that you are shooting close to the images, so the macro setting is a must. Good luck.
May 23, 2009 | Nikon Coolpix L11 Digital Camera
Deleting Pictures from Digital Camera
To delete all pics, just format the card. The menu will have a "Format Card" option.
Mar 26, 2009 | Nikon Coolpix L11 Digital Camera
Stuck picture
Ok, can you plug the camera to a pc and try to move it to the pc, or try to delete it via the software.
Feb 19, 2009 | Nikon Coolpix L11 Digital Camera
Sd memory card cannot be used
This happenes when you remove the card while read/write process is still going on. Try some professional service who will retive the data for you from the mem card. Hope this helps.
Dec 27, 2008 | Nikon Coolpix L11 Digital Camera
File Contains No Image!
Does the camera have internal memory? The folder name might not match the folder you or the camera are looking for. REmove mem card and see if the pics are still on the camera, if so, then try again without the card in. try and see the card in "mass media storage" mode on your PC. Reformat the card in the camera after you get the pics off to reset the folder name.
Dec 01, 2008 | Nikon Coolpix L11 Digital Camera
Nikon coolpix L11
well have you got a card reader? if you have then plug the memory card into the wright socket and see what happens
Jan 06, 2008 | Nikon Coolpix L11 Digital Camera
Nikon Coolpix L11 Digital Camera Logo
228 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
