Question about Samsung HLP5067W Television
How do you replace a color wheel on rca hd50lp? thanks bob
HOW DO YOU REPLACE A COLOR WHEEL SAMSUMGTV
Posted on Oct 16, 2008
Hd50lpw166 my tv the sound is good but the picture is not view and wear sound back the tv let me know where is the problem thanks for you helps soon
Sounds like a color wheel.
Color wheel problems are common with the RCA's. Those have been selling for around $125 - 145 from RCA. The lamp will cost you another $170 - 200. So you're looking a spending at least another $300 in parts IF that's really all that's wrong with that model. The lamp is easy enough to replace but the color wheel will require the front cabinet/screen to come off to access it. It's bolted in with 2 screw and is top loaded. The worst part with the RCA wheels is trying to keep the rubber gasket that comes with it aligned as you drop the new wheel assy into place.
As for manuals? There's not much to that model. The power supply board, System board (exchange only), ballast*(exchange) and the engine. Only the power board would be considered serviceable, everything else, including the ballast is replace only.
Oct 02, 2010 | RCA HD50LPW167 50" HDTV
RCA Scenium HD50LPW166XY1 DLP Projection HDTV ''scream''
RCA has discontinued the color wheel for your model and its on nationwide back order, so you cant buy the replacement. You can get your color wheel rebuilt at the following link and the rebuilt color wheels are fully guaranteed.
http://servicemanuals.vstore.ca/product_info.php/pName/rca-color-wheel-267888-rebuild-option/cName/color-wheels
Jun 14, 2009 | Televison & Video
Does any one make a replacement color wheel for my rca #hd50lpw62ayx2 projection tv? And if so, replacement procedure to replace. Thanks
You can find a replacement color wheel for a model # HD50LPW62AYX2 at this following link:
RCA HD50LPW62AYX2 Replacement Part Color Wheel
I'm not sure about how to correctly replace the part. Hopefully a tech whose dealt with this model will post an installation guide.
Dec 15, 2008 | RCA HD61LPW165 61" Projection HDTV
RCA HD50LPW62AYX2 50" - color wheel replacement procedure
REMOVE ALL SCREWS AROUND SCREEN AND REMOVE SCREEN. REMOVE 2 SCREWS HOLDING PLASTIC PIECE IN MIDDLE. GENTLY SLIDE OFF CIRCUIT BOARD (JUST GLUED FROM THE BACK). REMOVE PLASTIC PIECE TO EXPOSE OPTICAL CHASSIS. REMOVE THE LAST REMAINING SCREW FOR LIGHT FIXTURE. REMOVE 3 SCREWS HOLDNIN COLOR WHEEL. REMOVE RIBBON PLUGS AND REERSE THE PROCESS TO INSTALL. JERRY.(ROCKMANJV@COX.NET. LET ME KNOW HOW HAT GOES. i'M WAITING ON THE PART RIGHT NOW. WHERE DID YOU FIND YOUR PART? THEY ALL TELL ME THE PART IS ON BACKORDER. SEE YA!
Oct 23, 2008 | RCA HD61LPW165 61" Projection HDTV
Buzzing noise from lamp area.
if your model is the HDLP50W151 your color wheel is 212.00 at the following link and they provide free instalation instructions and also free tech support to help you with the Indexing when your finished as all color wheels in RCA TVs have to be indexed after instalation. You need color wheel 212184 heres the link
Click on the color wheel catagory on the left column.
Jun 26, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
Replacing color wheel on RCA M50Wh185
I have posted photos of replacing my RCA DLP color wheel on snapfish, here is the link.
The key is not to go through the back, but through the front by dropping the screen. After removing the screws that hold the screen to the chassis, it pivots out allowing you to reach in, remove the light shrouds and then by unscrewing four color wheel screws and disconnecting two connector cables to pull the color wheel out.
http://www1.snapfish.com/share/p=991241224865368552/l=438844205/g=6447808/otsc=SYE/otsi=SALB
May 19, 2008 | RCA D52W19 52" Rear Projection Television
RCA HDLP 50W151 scenium color wheel
They make two different color wheels for the Rca DLP are you positive you got the right one. As usually its a straight forward install no adjusting needed. Post the chassis number off the back of your set and I will try to help you out with it.
Apr 07, 2008 | RCA HD61LPW42 61" Rear Projection HDTV
Rcatv
I have found that this color wheel comes with a set of instructions that includes getting into the service menu and setting the index for the new color wheel. If the instructions were not with the color wheel, you will need the DVD for this model to find the information on entering the service menu and setting up the color wheel.
Jan 04, 2008 | RCA HD50LPW175 50" HDTV
Samsung HLP5067W Television Logo
108 people viewed this question
Henry  Thomas
Henry Thomas
