Power supply my printer will not turn on but the little green lite is lit on the power supply at the back can you help
Unplug the printer from the wall and re-plug it in. The printer will then work fine.
Posted on Dec 04, 2008
How do i fix my dell 2135cn printer
If the power button is lit then there is power going to the printer. However, if there is no display coming on then there could be an issue with the system board on the printer.
We can try doing a manual reset to see if that helps.
Unplug the power cable from the printer.
Press and hold Start button(Green button) and Cancel button(Red cross) while you plug the power cable back in.
Let go of these buttons once the power light is lit and check if the display comes back on.
If the issue remains the same then the printer needs to be replaced. Please let us know if this helped. Thank you.
Oct 12, 2016 | Dell 2135cn All-In-One Laser Printer
Precision T7400 power supply sounding an alarm
Did you open the case on your computer? It may have an open case alarm which is a small switch typically located near the edge of the cover you removed. Make sure the case cover is completely installed, then see if the alarm goes off.
Feb 28, 2013 | Dell POWER SUPPLY Power Supply
X4530 InkJet Printer: printer won't turn on. Don't have ink cartridges i...
The printer should turn on even without the cartridges yet. Try this. Make sure the power cord is plugged in straight to the wall. Bypass any surge device or power strips. Unplug the power supply from the printer. It's the black box behind the printer where the power cord is plugged in. With the power cord still plugged in to the power supply, the LED around the contacts should lit solid green. If not, make sure the power cord is properly secured. If this does not help, you may have a defective power supply. If it does, insert it back in the printer in the correct position. Plug it hard just to make sure. If it does not power on automatically, press the power button. If this does not help either, I strongly suggest you contact Lexmark Technical Support for further assistance. Thanks.
May 18, 2010 | Lexmark X4530 InkJet Printer
I put a new black printer cartridge in and now it doesn't power up at all. I replaced the printer cartridge with the old printer cartridge and it still isn't powering up. I replaced the power cord,...
With the green light lit on the power box or power supply of the printer, that indicates that there is power flowing. But just to make sure it's getting enough to power the printer on, bypass any power strips or extensions, if you're using one, and plug the power cord straight to a known working power outlet. Make sure the power box or the power supply is inserted all the way in the slot and in the correct position behind the printer. Press the power button if needed. Hope this helps. If it's still not powering on, I suggest you contact Lexmark Technical Support for further assistance.
May 04, 2010 | Lexmark X4690 Wireless InkJet Printer
My vaio wont turn on and the green light in the back keeps blinki
The green light blinking in the back indicates that the power supply went bad and is not turning on, go ahead and get the power supply replaced. Normally that light is supposed to be fully lit and green.
Apr 28, 2010 | Sony VAIO VGC-RB53 PC Desktop
Akai lct 2701td comes on then shuts down
Hi
You have power supply problem. Please go to ebay and buy cheaper price:
AKAI LCT2701AD POWER SUUPLY MLT166A
Thanks
GEORGE
Mar 11, 2009 | Akai LCT2715 27 in. LCD Television
Error Message on PIXMA 470
try to reset your printer--
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Turn off the printer.( it must be turn off)
then turn it on again. this works. thanks.
Mar 09, 2009 | Enlight Intel Xeon 470 WATT EN-470 MP...
Overload
Hi
Your printer was pawered ON during the Lightening if yes then follow the steps, Try with the different power card if it having the same problem then most probably your printer fuse blown open the printer and check the fuse if the fuse are OK then please check with the service centres
Boopathy.T
Aug 16, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Hp 1315 all in one
The all-in-one product does not turn on If the all-in-one product does not turn on at all, try the following actions in order to determine the cause:
  1. Unplug the power supply from the wall outlet.
  2. Unplug the power supply from the back of the printer.
  3. Remove the product cable from any power strips or surge suppressors, and plug it directly into a grounded (three-prong) wall outlet.
  4. Wait at least 20 seconds, then, plug in the supply back into the wall outlet.
  5. Plug in the power supply back into the printer.
  6. Press the power button to turn the printer on.
  7. For models that have an external power supply module, verify that the power supply module is plugged in correctly. Some power supply modules have a green LED built into the connector end or on the power supply module. This LED will be lit if power is present. If the LED is not lit, replace the power supply module.
  8. Plug the power cord into a different electrical outlet. If the all-in-one product has an ADF with an external cable plugged into the back of the product, use the following procedure:
    1. Turn off the unit.
    2. Unplug the power cable from the wall outlet.
    3. Unplug the ADF cable from the back of the product.
    4. Plug the ADF cable to the back of the product.
    5. Plug in the power cable to the wall outlet, and turn on the power.
      1. If no change, the problem is not the ADF.
      2. If the problem clears, turn off the all-in-one, unplug the power cable, and reconnect the ADF.
      3. If the error returns, the ADF is defective. Contact HP Customer Care to get the ADF replaced.
  9. Disconnect the computer parallel cable from the back of the all-in-one product and try to turn on the product again. The computer might be grounding out through the parallel port. If this corrects the issue, check the grounding of the computer and outlet.
Jan 08, 2008 | HP PSC 1315 All-In-One InkJet Printer
k24674
jasbo
jasbo
