This may be a problem with the speedometer cable. From the back of the gauges there is a thick cable that goes to the transmission. Check if it is loose or there is wear. You may have to unhook it or apply grease to it or replace it. Otherwise it could be the gear inside the transmission which counts the rotation that is faulty or loose.
Step
Action
Yes
No
Schematic Reference: Instrument Cluster Schematics
Did you perform the Diagnostic System Check - Vehicle?
Go to Step 2
Go to Diagnostic System Check - Vehicle in Vehicle DTC Information
Does the VSS parameter match the speedometer display?
Go to Step 3
Go to Step 4
Does the odometer operate properly?
Go to Testing for Intermittent Conditions and Poor Connections in Wiring Systems
Go to Step 4
Replace the instrument panel cluster (IPC). Refer to Control Module References in Computer/Integrating Systems for replacement, setup, and programming.
Did you complete the replacement?
Did you correct the condition?
Go to Step 5
5
System OK
Go to Step 2
How to trouble shoot
speedometer? http://technoanswers.blogspot.com/2012/01/speedometer-runs-backward.html ----------
http://schematicsdiagram.blogspot.com/2011/06/speedometer-not-working.html
-----------speedometer not working?
http://technoanswers.blogspot.com/2012/01/1996-fiat-bravo-speedometer-not-working.html
---------Speedometer runs backward?
Warning lights on and
speedometer died?
http://howtobyme.blogspot.com/2011/08/warning-lights-on-and-speedometer-died.html
--------Odometer works properly but speedometer works
intermittently?
http://technoanswers.blogspot.com/2012/01/odometer-works-properly-but-speedometer.html
----------speedometer is jumping?
http://schematicsdiagram.blogspot.com/2012/01/isuzu-rodeo-speedometer-is-jumping.html
-----------This will help.Thanks.
