Question about Clarion CDC1235 CD Changer
CDC 1205 compatibility - Connections
Clarions website of past models is skimpy to put it lightly. I recently got a boat with a Clarion CDC1205 12 disc changer and a blank spot where the head unit was. I have figured out that it is C-Bus and have the cable from the changer to where the head unit will go. Can anyone tell me if any other cables need to go to changer (power cable?) and how I can tell if a head unit will control the changer?
Thanks in advance
3 Suggested Answers
  • 497 Answers
SOURCE: getting error #9 on clarion
Check the antenna cable or antenna is connected properly to the back of the unit, and check the cable all the way along to the antenna - these are prone to internal corrosion when they get a bit old. Easiest way to check is to get a new antenna and cable (they are cheap) and plug it in directly to the back of the unit.
Check the ground connection of the unit is good - any terminals might need a clean up - disconnect the battery first.
These guys have a service manual for sale;
http://www.manualscenter.com/allprod-42-217.html
here's the LINK for a free download of the owner's manual (it says is for the 635, but is also for the 634);
Good Luck!!!!!!!!!!!!!!
Posted on Sep 11, 2009
gabz81
  • 32 Answers
SOURCE: Clarion 12 Disc CD Changer Model # CDC 1255z What
out of focus.
if all of your discs have the same error code 6, it is optical lens problem. have it checked to the nearest service center.
Posted on Jul 01, 2010
Yes we have a cruiser boat with clarion radio. It will be working then suddenly shut off with the display reading 'ACCS' It almost acts like a loose wire- does it with discs also.
It's a wire fault. Check your connections are secure and are not bouncing as you travel the water. If wiring is OK then the problem could be internally. If that is the case, it is less expensive to replace the radio.
Jan 06, 2011 | Clarion Car Audio & Video
out of focus.
Jun 12, 2010 | Clarion CDC1255z 12-Disc CD Changer
Clarion XMD3 No Sound
instead of trying to put a new head unit on it i would get a new wiring harness might have some bad connections in that if that doesnt work a new cd player would be the way to go can get a brand new one at abc warehouse for about 75 bucks
Jun 10, 2010 | Clarion XMD3
I had a Clarion 6 Disc CAA-355 in my car which got wet and is no longer working. Can I buy the same model again. If so where from and for how much or is there another model that will be compatible with my...
Great Clarion Disk Changer, 6 CDs CDC-655Z:
CDC655z Multi-Disc Changer - 6 -disc direct load mechanism. - 1-Bit D/A converter. - 10 sec. read ahead memory to prevent interruptions caused by shock and vibrations. - Non-stop play. - Optical Digital Output. - 0º to +90º mounting angle.
Great Multi-disk player. Works only with Clarion audio source units.
Selling b/c my deck player broke- I can give you the deck- maybe you can fix it. The model is DXZ-535, comes with owner's manual and remote.
Feb 25, 2010 | Clarion Car Audio & Video
I remove My clarion rdx755dz from 89 lincoln,which was install by Best Buy 8 yrs ago. I would like to reinstall in a 2000 Blazer. but unable to find a color code diagram for the radio . The plate said...
did you go to best buy and ask them if they have the wiring harness to adapt it to a 2000 chevy blazer if not write clarion at clarions website and ask them for the color diagram or you could also call your local car audio installation store and ask them as long as you have the model number and stuff im sure there shouldnt be a problem with that
Dec 07, 2009 | Clarion RDX655Dz
I am trying to remove the clarion dxz448r radio/cd player which keys do i need?
There are two types.
The wider version for older Clarions and the slim version for the more modern.
The cheapest  source is Ebay
Put CLARION REMOVAL in the "Search" box
Nov 18, 2009 | Car Audio & Video
Getting error #9 on clarion cdc 1205 . will not turn on.
Sep 11, 2009 | Car Audio & Video
My screen went dim and only the power button works
Most likely an insufficient ground is the culprit. Clarions are VERY dependent on a good ground. Check your connections - again...redo the ground if there's no change. If that doesn't work, take it to your local car stereo installer and ask them NICELY to diagnose the prob (probably free) if they do it FREE, buy the dude lunch $10
Good Luck
Jun 15, 2009 | Clarion MAX385VD Car DVD Player
No back light on display
I know that most Clarions have an "illumination" wire usually orange and or orange/white. If the unit only has one, then most likely it is for a "dimmer circuit" and not atraight illumination. Let me know. If by putting power on tat orange wire does not do it, then you have a bad "bulb" in the faceplate.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jan 28, 2009 | Clarion DRB2475
Peugeot 406 (1999) LX + Clarion PU2293A 6-Disc Changer Problem
Bloody snap! I also have a 406. The button on the head unit is supossed to turn on player.My original unit wore out.I got a second hand unit which is also not recognized by the head unit. At the moment I dont know why,but Im not a man to give up easily and will give you the solution when I have it. I know it was working originally and it looks like the secondhand unit is faulty. thomaashamioton@email.com
Oct 04, 2007 | Clarion DC625 6-Disc CD Changer
Clarion CDC1235 CD Changer Logo
429 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
