Question about Belling Dishwashers
Belling IDW604 dishwasher. Accidentally openned mid cycle, could not reset or switch off. Then had power cut. Dish washer now off and cannot be switched on or activaled at all. Have changed the plug fuse but still will not work.
  • 1 more comment
  • Anonymous Mar 24, 2014
    belling IDW604
  • Anonymous Mar 25, 2014
    How do I reset a belling dishwasher to its factory program settings ?
    Master:
  • 521 Answers
The one link for all the solutions just click the link and solve any type of problem in kitchen ranges.
www.applianceaid.com
the link below is the solution for your problem .where could be the fault ,what coul be the fault.what is necessary for replacing ,how to check the connection with proper diagram and step by step instructions is given in the link below.its absolutely free so please chck it .just click directly on the link do not open any other window for it.click the link directly.
pls do rate the solution
thanks.
regards.
fixya expert team
My dishwasher will not start
Posted on Sep 03, 2008
  • 2,071 Answers
Just click below;
WHAT IS WRONG WITH YOUR DISHWASHER?
Belling IDW604 dishwasher. Accidentally openned - small_9_26.jpg For a detailed Dishwasher illustration, click below.
Built in
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
There's an error code on the digital display
It doesn't work at all
It cleans poorly
There's no water entering the machine
The water doesn't drain from the machine
It's noisy
It leaks
The dry cycle has problems
The door has problems
The cycle doesn't complete
I see an error code
The detergent cup doesn't open
The cycle times are too long
Hope this may help;
Regards,
VOTIT
  • Belling Master
  • 19,396 Answers
Leave the washing machine unplugged for a good hour or so, if it does not reset check the control board behind the panel, probably you need to replace it.
  • Ginko
    Ginko Sep 03, 2008
    Check also the door, as sweetrascal said there is a small switch that prevents the unit from starting when door is opened, check that it is not stuck, try playing with it.
    Guru:
  • 1,894 Answers
Have you tried to start the unit by pressing the door switch with a pen or sharp object?
Posted on Aug 19, 2008
I have a belling IDW604 integrated dishwasher which is not heating the water
An open element will have voltage present and still not operate. Use an ohm meter to test it.
Dec 21, 2015 | Belling Dishwashers
Belling IDW604 wont heat water
Check heater for continuity, thermostat and control timer
May 09, 2012 | Belling 24 in. IDW603 Built-in Dishwasher
E4 is displayed on my belling idw604 dishwasher and it won't operate
unplug machine. remove right hand side panel. check if water has collected in the bottom tray, if so soak up with cloth or kitchen roll until all water has been removed. switch on power and machine should have reser
Feb 07, 2011 | Belling Dishwashers
I have a built in IDW604. It won't start. No power.I have changed the fuse and reset the RCB.
Remove power to the machine. Look for a failed microswitch within the door cavity where the door latch locks. A microswitch should make a distinct 'click' when the button is pressed, but the best test is looking for zero ohms across the switch terminals when the button is pressed. Hope this helps!
Mar 31, 2010 | Belling Dishwashers
I have a belling dishwasher IDW604. I haven't used it in 3 months and now there is no power. It won't switch on. Why?
check your power cord usually under the sink also check all GFCI Outlets in your home for a possible trip
Mar 08, 2010 | Dishwashers
Idw604 error code e4
had same problem. Tilt dishwasher to the left and drain all the water (it will come out on the side). That's E4 solved. Now turn it on, E4 should not light up. If it does, turn it on and as soon as u do this, close the door. This won't activate the Trip Switch but will automatically turn the pump on. Good luck!
Aug 02, 2009 | Belling 24 in. IDW603 Built-in Dishwasher
Belling idw604
The E3 code is normally related to the overheating of the water during a wash. There is a thermal swith that has a manual reset button mounted on it. The button is normally red in colour and is about 3mm in diameter. REMEMBER TO SWITCH OFF THE POWER BFORE ATTEMPTING ANY REPAIRS. The switch is accessed by removing the silver plate mounted beneath the door. The plate is secured by 2 phillips screws. The switch, black in colour, is mounted to the left and is about 10cm in from the front of the machine. Simply press the red button to reset. This should solve the problem but if the problem persists I suggest you call an engineer.
Jun 27, 2008 | Belling 24 in. IDW603 Built-in Dishwasher
BELLING IDW604
i have just fixed my e4 code problem
take off salt cover and remove all water with tea towel or dish cloth you must make sure all water is out switch off at wall then back on if still e4 reapeat getting water out my washer is cleaning as i type
Dec 01, 2007 | Belling 24 in. IDW603 Built-in Dishwasher
Instruction book
need the manual for the belling idw604 dishwasher
Jul 04, 2007 | Belling 24 in. IDW602 Built-in Dishwasher
Dishwashers Logo
489 people viewed this question
Top Belling Dishwashers Experts
Kamil Owsianiecki
Level 1 Expert
Oloyede Monsuru
Are you a Belling Dishwasher Expert? Answer questions, earn points and help others
