Question about Honeywell Programmable Thermostat Heater
Honeywell thermostat WE just purchased a honeywell progammable thermostate to replace a bryant thermstat. we have it all wired but it will not start.
  • Galina27 Oct 21, 2008
    I have the same problem
    Problem Solver:
  • 17 Answers
If you have a forced air furnace with an air conditioner attached make sure you have a jumper wire between Rh and Rc. If the Bryant thermostat had a wire hooked up to C you do not want to hook this up to Rc. Just cap it off and put it back in the wall or disconnect that wire down in the furnace.
Posted on Jul 21, 2009
    Guru:
  • 462 Answers
Some programmable thermostats require a comon wire to the transformer side of the 24V transformer. Check and see if this is true. And then look and see if your old thermostat had a "c"terminal used. Also would help if I knew the terminal designations your original thermostat had and the new one has.
If this helped you please rate me accordingly as high as you can and if you need more information please post back.
Posted on Apr 28, 2009
Thermstat light is stuck at 70 will not go up or down
Thermostat has died and needs to be replaced. Not repairable or cost effective to do so.
Nov 11, 2015 | Honeywell Programmable Thermostat Heater
Wires don't match the new thermostat posts. The wires from the furnace are Red,Blue black and white The posts in new thermostat are B O G Y not used R and Rc Can't figure which to put
The wire colors are for the following functions ......red - 24 volts white - heat yellow - AC green/blue - blower (fan) red is connected to the R with a jumper between R and Rc What type of furnace/heat do you have ???? Electric. oil, gas .Forced hot air, baseboard, steam, heat pump, or ?????? Different systems use different connections and need a specific thermostat for that application !!!
Dec 13, 2014 | Heating & Cooling
Our Honeywell programmable thermostat T8132A 1049 1 controls a Gasglo gas central heater. An old battery leaked onto one battery contact; even with new batteries the BATT LO message came up. After...
The T8132A thermstat requires 2 AA alkaline batteries for operation as the T8131 uses the 24VAC souce transformer with battery back up. If new batteries did not fix the problem follow product user manual to reset and program the thermostat. This should clear any errors or problems. If the problem persists then replace the thermostat. If you do not feel confident you can accomplish the task then you should call a licensed HVAC technician to troubleshoot the issue as the wrong settings could potentially cause permanent damage to your system.
Link:
http://s3.pexsupply.com/manuals/1287594709924/40775_PROD_FILE.pdf
May 09, 2011 | Honeywell Programmable Thermostat Heater
I am changing an old thermostat, and converting it in to a honeywell RTH2310B. The original thermostate has 3 wires, in red,black, and white. The new one has white, yellow, and green. How do I proceed?
Hi, the new stat should have rh, and rc, with a jumper wire on it. leave it on, and connect your red to either one. Connect white to W, and the black the must be using for fan, so connect it to G, if it was being used on the other stat. If it wasn't, tape it off. You should be up and running. I take it this is a heat only application.
Sincerely,
Shastalaker7
A/C, & Heating Contractor.
Nov 03, 2010 | Honeywell Programmable Thermostat Heater
Replace three wire thermostat with four wire thermostat
From the two red and two black wires (and the specs in the pdf), your new thermostat sounds like it's designed to directly control the line voltage (120 or 240) to the heater. That's the usual way baseboard heaters are controlled.
Could your wires be red, black, and (old, yellowed) white, the standard colors in a 3-wire power cable? Just the red and black should be enough to control a 120-volt heater so I don't understand what the white would have been used for. If it were my heater I'd take off the cover(s) -- with the power off, of course -- and find out what those wires actually connect to.
Jan 26, 2009 | Honeywell Programmable Thermostat Heater
Wiring diagram to connect programmable Thermo to Heat Pump
I don't know if this will be helpful or not, but I just installed a new Honeywell and the Honeywell customer service guy helped me get the wires done correctly. The number is 800-468-1502.
Jan 05, 2009 | Honeywell Programmable Thermostat Heater
Replacing aging erratic honeywell chronotherm III
Hi, your replacement part can be purchased on amazon, take a look here: Amazon com honeywell chronotherm III thermostat. I hope this was helpful. Cheers
Nov 30, 2008 | Honeywell Programmable Thermostat Heater
Y1 W1 Wire from older Honeywell to new RTH honeywell
Y1 means for cool and W1 means for heat. Connect accordingly.
Aug 11, 2008 | Honeywell Programmable Thermostat Heater
I can't program my thermstat
go to www.honeywell.com. There you will find a search tab. Type in the exact model number of your thermostat. You will be able to download the installation/owners manual.
Nov 29, 2007 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
243 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
