Question about Whirlpool Duet GHW9150P Front Load Washer
Not spinning Machine is running pump is working but won't spin,reading a code F6
  • pocketmarine Aug 10, 2008
    everything is operating except tub is not spinning and it is showing F6 error
  • 5,911 Answers
The following link explains the "F06" error:
http://www.fixya.com/support/r714929-f06_error_whirlpool_duet_kenmore_elite
It is known as a Motor Speed error. More commonly the motor control unit (MCU) fails. However, you will need to check the drive motor, belt, and Central Control Unit (CCU) to be sure. I hope this helps you.
Posted on Aug 11, 2008
My washer won't spin
HI Rhonda.
If your washer pumps out the water but doesn't spin, check these: The lid switch may be defective. ... The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch.4 May 2012
SOLVED: Why won't my Washing Machine pump but not spin during ...
https://www.ifixit.com/.../Why+won%27t+my+Washing+Machine+pump+but+not+spin+...
What causes a washing machine not to spin?If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drive washing machines do not have belts.) ... 1Check the washing machine's spin cycle. If this works, the motor is operating and the belt is not broken.14 Aug 2014Washer Doesn't Agitate or Spin - HomeTipshttps://www.hometips.com/repair-fix/washing-machine-agitate-spin.htmlSearch for: What causes a washing machine not to spin?
Why is my washer not spinning the water out?If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.16 Mar 2014SOLVED: Why won't my washer spin or drain? - Kenmore 110 Series ...https://www.ifixit.com/Answers/View/.../Why+won%27t+my+washer+spin+or+drainSearch for: Why is my washer not spinning the water out?
What causes a washer not to spin?Over time, the repeated friction of the clutch pads rubbing against the housing can cause the clutch to wear and create a scraping sound. A worn clutch can prevent yourwashing machine from spinning, or may cause a slower spin speed which will leave your clothes wet after a cycle.How to Fix Washer That Won't Spin ' Washing Machine Repairhttps://www.partselect.com/Repair/Washer/Will-Not-Spin/Search for: What causes a washer not to spin?
if you need more help go to this link.
washer won spin Google Search
Nov 23, 2017 | Washing Machines
Tip
Washing Machines will not rinse or spin
If the water won't drain out of your washing machine, either something is stuck in the drain hose or pump, or the pump is broken. Both fixes are simple if you're even just a little bit handy with tools. We're showing the repair on a Maytag washing machine.
What is wrong with a washer that does not spin?
If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drivewashing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle.
How to Drain Washing Machine That Won Drain Family Handyman
Washer Doesnt Agitate or Spin
Error codes in front load washers
Washing Machine Not Rinsing How To Fix
My washing machine stops at Rinse Does not DRAIN or SPIN
What causes a washing machine not to drain and spin?
SOLVED Why won my washer spin or drain Kenmore 110 Series Washing Machine
Maytag Washing Machines will not rinse or spin Google Search
on Dec 12, 2017 | Washing Machines
I have an f6 code and the machine will not operate once it comes up
The F6 error code means that the computer on the control didnt detect that the motor reached a high speed on the spin cycle, sometimes it thinks the washer didnt spin fast enough because of a loose wire connection either on the motor or the control boards (motor &machine control) if you find that the washer did actually spin at high speed (clothes dont come out sopping wet at the end of cycle) the wire connections or the motor control board will be the potential causes of the F6 error code. Try unplugging the machine for five minutes to let the computer reset then try again. Next check the control panel wires. f6 code flashing on display Kenmore Elite HE3 Washing Machine
May 19, 2015 | Washing Machines
F6 error on Hitachi washing machine Sk 120KJS
Jul 09, 2012 | Washing Machines
Washing machine won't drain and spin after rinse
It sounds like you have a blocked pump. I have read that the pump is connected directly to the motor. You will need some tools at hand before you try to disconnect the pump from the motor.
Make sure that you disconnect the machine from the power supply. Tilt the machine back to access the pump from the bottom of the machine. It will be connected to the motor with clips. Have some towels ready to mop up the water.
I hope this works for you.
Jul 27, 2011 | Roper RAS6233KQ Top Load Washer
The washer quit spinning, I can get it to work in wash mode but when it comes time to spin out it won't do anything,
themobilian_2472.jpgIf it won't puthemobilian_2473.jpgmp out the water or spin that is the lid switch. If it pumps out the water but does not spin then that is the motor coupling. How to get into the machine.
How it works: 4 videos and a service manual
Jun 21, 2011 | Whirlpool LSR6334LQ Top Load Washer
Cannot get a spin cycle, washer gets stuck before spin cycle get F6 error code
You will need to access the drain pump first by removing the bottom panel. Open clean-out on pump and check for obstructions. If none, the pump may have a broken rotor, these are the problems related to the F6 code.
Dec 01, 2010 | KitchenAid KHWS01PMT Front Load Washer
Machine won/t spin, on second try wah cycle nothing worked although motor was running
<span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN">Hi,</span><br /> <span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN"> </span><br /> <span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN">Problems with a washing machine not spinning or not draining are often inter related..</span><br /> <span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN"><br />If you are having a problem with your top load washer then check out this tip...<br /><br />Washing Machine does not Pump or Spin<br /><a href="http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin" target="_blank">http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin</a><br /><br />If you are having problems with your front load washing machine then checkout this tip...<br /><br />Front Load Washing machine not draining and or not spinning<br /><a href="http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining" target="_blank">http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining</a><br /><br />heatman101 <br style="mso-special-character: line-break" clear="all" /></span><br />
Aug 27, 2010 | Washing Machines
Whirlpool front load washer getting an error code of "F6"
f 06 is a in issue with the motor control board, check the wiring harness attached to the board.
May 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore elite front loader F6 code
"F6" is a Motor Speed error code. This would be why you're experiencing problems with the drum spinning. The following link explains:
I would begin first by checking all connectors between the drive motor and motor control unit (MCU) to make sure they are still plugged in and don't show any signs of corrosion. I have experienced problems where the connector plugs came loose due to vibration.
You may also attempt to reset the Central Control Unit (CCU) to see if this error code could be erroneous. The CCU is the main computer for the washer. To reset, simply unplug the washer for 30 minutes. If the error code returns following a CCU reset, then you have a legitimate problem.
Read through the link provided and let me know if you have any questions. I hope this information helps you.
Jul 28, 2009 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
249 people viewed this question
Dan Webster
Dan Webster
Sal De
