Question about Toshiba Tecra 8200 Notebook
SCREEN DOESN'T DESPRAY
HELLO I HAVE A PROBLEM WITH MY LAPTOP IT INDICATES THAT IT CAN BOOT AND ALL THE LED ARE LIGHTING BUT THE SCREEN DOESN'T SHOW ANY THING AT ALL I HAVE TRIED TO PLACE FN BUTTON BUT NOTHING. AT FIRST IT WAS WORKING VERY WELL BUT I AN PLAGUED IT OUT OF POWER IT INDICATED DISC ERROR BUT NOW SCREEN. WHAT CAN I DO.
  • jrlopez2001 Sep 17, 2008
    password error in star laptop
  • 125 Answers
Try plugging in an exteriior monitor that will at least tell you if it is the video card or the LCD
Posted on Jul 27, 2009
On acer aspire laptop screen is grey at startup
1. When you press the power button to turn it on, do you see any thing on screen, It probably should show an ACER logo?
2. Can you see a faint image of your desktop (try to see it in dark place with flash light). If you do see a faint image it could mean your back light is broken.
3. When you press the power button do you get different LED's lighting up on the laptop? IE power LED, hard drive LED?
4. Does your computer give you any random beeps when it starts up?
Please answer these questions and I would be more than happy to work through this with your.
Thanks RCCT
Jan 16, 2014 | Acer Aspire Computers & Internet
Laptop won't boot - Compaq
Do you see anything on the screen? Does the HDD LED blink? You can start by removing the HDD and testing it or have it tested.
Jun 06, 2013 | Compaq Computers & Internet
Black screen of death
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :-
http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Apr 30, 2013 | Acer Aspire 5100 Notebook
Hello my emachine n450 doesn't boot. After I power on, only blank screen appear... What's should I do?
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Feb 26, 2013 | Acer eMachines 3502074 Netbook
How can I tell if a power surge hit my laptop and ruined it? I can't even get it to boot up
It could either be that the motherboard is fried or the Hard drive has just gotten slightly corrupted. If you have the Windows install disk that came with it you could boot that up and then go into repair mode (press R) and then run "chkdsk /r" this would fix a hard drive issue. However if your laptop will not turn on at all when you press the power button then it is likely dead.
Nov 07, 2012 | Computers & Internet
How do you get laptop screen to show on the tv by a hdmi cord
Connect the HDMI cord to both. Switch to the HDMI input on the TV. Boot the laptop. If you're using Windows and the TV doesn't show the laptop's screen, right click anywhere on the desktop that doesn't have an icon, then select properties. In the tab to the right of the resulting window, you should be able to enable screen mirroring, expansion, or switching.
Some laptops also have a function key set that you press to switch monitor outputs. Look for keys with secondary, alternate color commands on them. It will normally take a set of key presses.
Jul 04, 2011 | Mitsubishi WS-65809 65" Rear Projection...
Nothing appear on screen. But the power button is lighting on and i can hear the fan at the back of the laptop. i tried removing the battery and tried again but still nothing appear on screen.
If the Hard drive LED is active and it appears that the computer is going through the boot up process then your screen if faulty, probably due to a faulty backlight controller. Try shining a small torch near the screen and see if you can make out any details on the screen. If so then the backlight needs to be repaired.
Feb 24, 2011 | HEWLETT-PACKARD PAVILION DV6870US LAPTOP...
My laptop does not start
Try plugging it in, battery could be flat, check on the charger that the LED is on or it could be the charger is not working.
Are the LED's on the laptop lighting up? Does the screen come on? Or is this a boot up problem?
Aug 07, 2010 | Computers & Internet
The led of harddrive is keep on lighting, no screen signal (laptop model lw40 of lg)
Does the laptop appear to boot up but the screen remains blank?
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out, this is the most likely case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site :-
www.lcdparts.net
Sep 30, 2009 | Computers & Internet
Toshiba Tecra 8200 Notebook Logo
75 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
