Question about Cuisinart Grind and Brew 10 Cup Coffee Maker
Cuisinart Craft How do I clean inside the craft?
  • Anonymous Mar 23, 2014
    need to clean inside
    lid
  • 2,071 Answers
A clean coffee maker is essential to good coffee. Residue of stale coffee oils will interfere the brewing that caused 2-3 cups only produced. It is suggest regular cleaning of your coffee maker according to manufacturer recommendation.
I took everything out, got a small piece of fine sandpaper, held the plunger in with a pencil, turned on the grinder and sanded the round top portion of the grind basket driver. It takes a few times to get a good snug fit that’s still easy to remove.
The instruction manual that came with the pot will tell you to use one cup (measuring cup) of "white vinegar" and fill the rest of the reservoir with regular water. Turn it on and let it perk the mixture through the system. Then perk a couple of pots of plain water to flush out the rest of the vinegar.
The books say to do this once a month to keep things clean and the coffee tasting great.
A professional machine that is plumbed into a water supply must be thoroughly disassembled, and each part soaked in acid, and manually cleaned. Unless your water is exceptionally hard (you should have a water softener inline with the machine in hard water areas) this should only need to be done every 5 years or so. Heads and screens and filters should be soaked every day in a cleaning solution available from any professional machine supplier. A machine that is not plumbed should have a small amount of Puly brand cleaner added to its tank, and run through several cycles every 3 months. Puly is available thru machine suppliers, but there are also several other brands that do the same. Visit your local coffee machine shop for a good cleaner.
Hope this may help;
Regards,
VOTIT
don't forget to rate;
Posted on Aug 10, 2008
My memory craft 350e won't keep the tension tight. What can I do to fix this? Please help.
Balancing Thread Tension - Janome MEMORY CRAFT ...
www.manualslib.com > ... > MEMORY CRAFT 4900 QC > User manual
Janome MEMORY CRAFT 4900 QC Manual Online: Balancing Thread ... Auto-threadtension When the thread tension dial is set at AUTO for ... to increase the threadtension. ... Sewing Machine Janome Memory Craft 350e Instruction Book.
Sep 19, 2015 | Sewing Machines
I'm doing a rubber stamping project. Should I buy a craft knife?
Yes, you should. craft knives are really useful in rubber stamping. A basic craft knife is all you need. You use the knife to carve the design you want.
Jan 17, 2013 | Office Equipment & Supplies
I have a Janome Memory Craft 3000 sewing machine. It suddenly started skipping stitches. Now, after cleaning out the lint as well as I could, the machine will not pull the bobbin thread up. Any ideas?
Good day!!!
please apply a some oil on the motor and other moving parts inside you sewing machine..
After that reboot the machine and used it....first try is persisted but when you used it continuously for at least 10 minutes your machine is OK...
Jun 28, 2011 | Janome Memory Craft 3000
Where can i buy craft supplies online?
There are some great websites online for craft supplies like Crafts Etc., BJ's Craft Supplies, All Craft Supplies, JoAnn and many others. You can find more information here: http://www.bjcraftsupplies.com/
Aug 16, 2010 | Blitz Crafts & Hobbies
Espressione Mirage
please contact service center:
Electra-Craft
41 Woodbine St
Bergenfield NJ 07621
phone 201-439-1700
fax 201-439-1701
info@electra-craft.com
www.electra-craft.com
Aug 31, 2008 | Espressione Caf? Dolce Aroma
Dualit vapor lost
if you are loosing our steam you have a seal problem you have to open the machine and activate it look were the steam come out remove the piece clean and ghange seal good luck cheers
Jan 30, 2008 | Dualit 84022 Coffee Maker
Janome/New Home Memory Craft 8000
I have a memory craft 8000 that gets a message stating "Stepping Motor Error". What can I do to try to fix it?
Oct 01, 2007 | Sewing Machines
Coffee brews and then immediately shuts off Cuisinart DCC-1200
To program the Variable Auto Off: 1. Turn the FUNCTION KNOB to the ?Auto Off? position. Press and hold the ?Hour? button for 2 seconds. The clock display will start blinking. 2. Program the coffeemaker to shut off from zero to four hours after brew cycle is finished by using the ?Hour? and ?Minute? push-buttons. (see ?To set the time?)
May 20, 2007 | Cuisinart DCC-1200 Coffee Maker
Cuisinart Grind and Brew 10 Cup Coffee Maker Logo
105 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
