Question about Cuisinart Grind and Brew 10 Cup Coffee Maker
Cuisinart coffee maker... How do I clean the inside metal craft?
  • 2,071 Answers
A clean coffee maker is essential to good coffee. Residue of stale coffee oils will interfere the brewing that caused 2-3 cups only produced. It is suggest regular cleaning of your coffee maker according to manufacturer recommendation.
I took everything out, got a small piece of fine sandpaper, held the plunger in with a pencil, turned on the grinder and sanded the round top portion of the grind basket driver. It takes a few times to get a good snug fit that’s still easy to remove.
The instruction manual that came with the pot will tell you to use one cup (measuring cup) of "white vinegar" and fill the rest of the reservoir with regular water. Turn it on and let it perk the mixture through the system. Then perk a couple of pots of plain water to flush out the rest of the vinegar.
The books say to do this once a month to keep things clean and the coffee tasting great.
A professional machine that is plumbed into a water supply must be thoroughly disassembled, and each part soaked in acid, and manually cleaned. Unless your water is exceptionally hard (you should have a water softener inline with the machine in hard water areas) this should only need to be done every 5 years or so. Heads and screens and filters should be soaked every day in a cleaning solution available from any professional machine supplier. A machine that is not plumbed should have a small amount of Puly brand cleaner added to its tank, and run through several cycles every 3 months. Puly is available thru machine suppliers, but there are also several other brands that do the same. Visit your local coffee machine shop for a good cleaner.
Hope this may help;
Regards,
VOTIT
don't forget to rate
Posted on Aug 10, 2008
My coffee pot is black inside & using vinegar does not clean it
Use a coffee pot cleaner such as Dip-IT. Walmart sells a product in the coffee maker area that is for cleaning the coffee maker. It cleans the coffee pots too.
Feb 24, 2011 | Cuisinart DTC-975 Coffee Maker
HELP! NO INSTRUCTIONS WITH COFFEE MAKER!
Try this link http://www.wholelattelove.com/manuals/cuisinart/Cuisinart DCC-2200.pdf
Jan 06, 2010 | Cuisinart DCC-2200 14-Cup Coffee Maker
Discolorization(orange) inside coffee maker.
Try mixing in some vinegar with your water (about a cup) and run it through a cycle, this may clean it out.
Tom
Oct 04, 2009 | Cuisinart Brew Central 12-cup Coffee Maker
Cuisinart coffe maker self clean
I found the manual here http://www.retrevo.com/s/Cuisinart-DCC-1200-Coffee-Makers-review-manual/id/890ci052/t/1-2/
Oct 28, 2008 | Cuisinart DCC-1200 Coffee Maker
The coffee is beginnign to have a metallic taste - how do i clean it? thanks. Rita Herndon
Run 1 tsp lemon juice per 1 cup water to improve taste. Also, change the charcoal water filters inside the unit.
Sep 26, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart Craft
Hope this may help;
Regards,
VOTIT
don't forget to rate;
Aug 10, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Metal Tasting Coffee
vinegar is not the best it remove calcium in little piece descaler produit melt go buy the descaler produit 1part descaler 1 part water put in water container start the machine after a few second turn it off leave it there for 15 minute repeat untill empty rinse very good after that product is corosif 2 or 3 full rinse thanks for using fixya pierre
Feb 12, 2008 | Cuisinart 12 Cup Digital Thermal Coffee...
Cuisinart Coffee Maker DCC 2200
The user manual is a free pdf download from the cuisinart web site.
Dec 26, 2007 | Cuisinart DCC-1200 Coffee Maker
Coffee brews and then immediately shuts off Cuisinart DCC-1200
To program the Variable Auto Off: 1. Turn the FUNCTION KNOB to the ?Auto Off? position. Press and hold the ?Hour? button for 2 seconds. The clock display will start blinking. 2. Program the coffeemaker to shut off from zero to four hours after brew cycle is finished by using the ?Hour? and ?Minute? push-buttons. (see ?To set the time?)
May 20, 2007 | Cuisinart DCC-1200 Coffee Maker
Cuisinart Grind and Brew 10 Cup Coffee Maker Logo
122 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
