Question about Toshiba 36A50 36" TV
No picture only sound, Toshiba 36A 36" TV tube type
My Toshiba 36A 36" TV tube type has no picture. Only a bright white 1/4" line across horizontal with black background. I have sound. I tried unpluging it for 15 minutes no luck. I tooked off the back couple of months ago and carefully blew out the heavy dust. It work great until now. The TV is about 6-7 years old. What part would be causing this.
    Sergeant:
    Champion:
  • 227 Answers
My friend if you open the tv carefully look to see if the tube itself has light, or if you have high voltage i coulbe many different things.wish luck!!
caypianan@yahoo.com
Posted on Sep 30, 2008
Toshiba 36HF12 TV has a horizontal bright line across no picture
Failure of vertical scan output circuit. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
Nov 11, 2015 | Toshiba Televison & Video
My son was bouncing a small ball against the screen and then it went to looking like a rainbow. Would this be the picture tube?
He may have caused some type of damage to the picture tube, but usually rainbow effects happen when magnets are present. Perhaps the ball became charged with a large amount of static, which then discharged across the tube, damaging the controlling circuits.
Jun 03, 2010 | Toshiba 36A43 36" TV
Only thin white line across my toshiba tv
This is an easy repair if you've ever soldered and would not be too costly for a repair shop to do it for you. The problem is a bad Vertical Output IC (usually mounted on an aluminum heat sink with the part on it labeled LA78?? ) and 1 or 2 bad capacitors. Some times you can even fix the problem by re-soldering the contacts of the IC- To find the IC follow the 4 wires that come from the Yoke (which is a contained coil of wires slipped over the neck of the picture tube(s)) back to the board. 2 of the wires go to the horizontal o/p and 2 to the Vertical o/p the thinner gauge wires are for the vertical.
Sep 28, 2009 | Toshiba 36A50 36" TV
No Picture On Screen
it sounds to me like your tube has gone , go to your local tv repair shop and order a new tube its quite cheap to do so and they should be able to get it you quite fast.
Mar 10, 2009 | Mitsubishi VS-60601 60" Rear Projection...
Toshiba CF36G40 36" TV Problem
IO board has bad solder joints or is bad if you tap the outside firmly it will come on for a while
May 28, 2008 | Toshiba CF36G40 36" TV
No Picture on my Toshiba television
Try hooking the tv up to the back with the right cords. Turn off 1st and replug the tv and turn back on.
Nov 26, 2007 | Toshiba 36A43 36" TV
Toshiba 36AF43 36" just has white line in the center
vertical output IC has loose solder joints.if you continue to let it operate this way it will etch a burn line across the face of the tube so discontinue use.
Aug 22, 2007 | Toshiba 36AF43 36" TV
Tosjiba cn32g90 no picture or sound
Timm,What you have Is Vert Failure,Toshiba is Noted for Bad Conns On the Vert Ic,Pull the Back off and Gently tap with a NonConductive Inturment and watch the Sceen Look for Heatsinks and Tap on those,If you know,or you caqn solder do so ,Do run the tv for a long time with no Vert or it will Cause BURN IN in the Phophurus
Jul 15, 2007 | Toshiba CN32G90 TV
Thin horizontal line across picture
I really dont understand the problem Could we see a picture of this please?
Jun 14, 2006 | Toshiba 35A44 35" TV
Toshiba 36A50 36" TV Logo
265 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
