Question about Sony KP-51HW40 51" Rear Projection Television
Sony projection tv convergence issue
I have 2 sony projection tv manuf date 2000
they both have convergence issues.......when i go to service menu the red is so way off you cant adjust it using any of the service menu choices.......and on the other sony its about the same thing except not as bad.......
if i replace the stk ic chip will that fix the problem...
  • 5 more comments
  • shelby50411 Aug 10, 2008
    how positive are you that this will fix the issue........yes i saw 2 stk 392 560 on the d board.,what does a pico fuse look like and where are they and how many........can i test ib blown using an ohmn meter on each end of fuse to see if continuity?????????
    thank you im working on it now however i cant get the D board out ....i unscrewed the 5 scres or the D board but it wont lift out because
    it is connected to the a/v board by some weird looking bridge like parts there are four of them that attach both boards........
    on my model i tried just takin the chasis out but under the chasisc is a plastic vent grill that wont let me get underneath the board
    do you know what im referring to?
    model is kp-53v80..and it used stk 392-150
    ....so i just have to lift the bridge connectors off the D board side and they will lift off???
    also would a convergence issue casue the number/letter display on the tv to wiggle ...when i go to service moce the letters/numbers on the screen wiggle and the colors are out of convergence...and withion the letters/numbers there are horizontal lines....
    i really appreciate your help..........you are awesome
    also i think i identified the pico fuses
    are they yellow with no band and also have a ps??? desigantion next to it??? mine say 2000 on the yellow in small lettering
    is this the pico?
    is there any way you would email me directly??
    my email is shelby50411@gmail.com
    if not i understand......
    thank you check your email
    jim
  • Tracy Lee Dec 23, 2008
    I can't adjust convergence through remote menu.  I can't find the ic's in the back of my tv to see if they are damaged where are they located
  • Sony Master
  • 8,617 Answers
You will need two STK392-560 Convergence ICs and you will also need two of the 3.5 amp pico fuses as Sonys will always blow at least two of the Pico fuses. You can get replacement ICs and Pico fuses at the fiollowing link and they provide free instalation instructions. Heres the link.
http://servicemanuals.vstore.ca/
Posted on Aug 10, 2008
  • Sonny Berry
    Sonny Berry Aug 10, 2008
    If you look at the heat sink that has the two Convergence Ics STK392-560 ICs you will see a row of small resistors all in a row. Within that row there will be 6 yellow picos that dont have color bands on them they will have PS stamed on the board next to them. You have to unsolder one end of the pico and lift that side out of circuit then test them for continuity if they dont have continuity they must be replaced, they are 3.5 amp picos. they look like this except yours are yellow.
  • Sonny Berry
    those are bridge connectors they just lift up from the side where the D board is and stay attached to the other board as hinges. So just lift up on the hinges on the side of the board youre removing and they will pop roght off the dboard. Sorry I thought your model was the 51HW40 thats why I said STK392-560 For the Ics. Thats why its always good to specify which model you have.
RCA D52W23: Only partial convergence menu. I can only access Autoconvergence, Red and Blue convergence options (not Level 1, 2, 3, etc.) in the service menu. The picture is only slightly off (i.e. green...
Please do us a favor and rate this by cliking the thumps up icon located here >>>>>>
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 31, 2011 | RCA D52W23 52" HDTV CRT TV
61swx01w with magic focus still has convergence issues after process finishes. How do i perform advanced alignment?
Goto TV Repair Kits website..and look on their Tips page for DCAM instructions....
For everyone else with this issue here is more info...
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 09, 2011 | Hitachi 61SDX01B 61" Rear Projection...
Picture is greenish / purplish and curved lines at top & bottom of screen. definitely not an input issue, distortion is the same on all inputs and even on the menu/settings...
Very common problem throught out ur DLP tv live,will happen again again many times for the tv life times.Ur tv have a problems known as convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts must be replaced on the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 05, 2011 | Sony KP-65WV700 65" Rear Projection HDTV
Will it be worth to hire a tech to fix the convergence problem on my TV or should I buy a new set?
You can adjust the convergence by press the flash focus button on the TV. If the issue persists, then try resetting the TV to the factory settings. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service. You can contact the service center and check for the cost of repair. It is just a small adjustment.
Jul 24, 2010 | Sony KP-51WS500 51" Rear Projection...
Convergence problem with sony
try to adjust the image revision on the customers menu.
Jun 13, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Convergence issue
Not sure how service menu will help you other then to do more adjustments such as 3D reform and such. Not real sure, just a long wild guess but the coils on the picture tube could possible be loose enough to change positions when heating up causing picture alignment to change. Might be a cheap service call.
Apr 23, 2008 | Sony KP-61HS10 61" Rear Projection...
Sony KP-51HW40 Convergence issue
Can you adjust the convergence by the convergence menu without going through the service menu? The settings through the convergence menu should save automatically. Have you replaced the convergence ICs? If so the settings should save, if not the D board will need to be replaced or at the very least rebuilt. Let me know if you need further assistance with this issue.
Apr 10, 2008 | Sony KP-51HW40 51" Rear Projection...
Sony KP61HS10 Convergence issue
u may purchase service manuals here/
www.servicemanuals.net
Jan 09, 2008 | Sony KP-61HS10 61" Rear Projection...
1080i connection has green hue
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 09, 2008 | Mitsubishi VS-60805 60" Rear Projection...
Converge problem on a kp-65ws500 sony rear proyection tv
You can download a copy of the service manual that explains how to enter service mode and perform convergence of the red/blue/green guns, but unless you are comfortable doing something like this, you may be better off calling a good shop familiar with rear projection sets and getting a quote to have a convergence service performed.
Dec 16, 2007 | Sony KP-57WS500 57" Rear Projection...
Sony KP-51HW40 51" Rear Projection Television Logo
884 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
