Question about Hoover F7220900 SteamVac V2 Upright Vacuum
Brushes don't spin
Steam vac rug steamer, brushes don't spin--button switch is on, screen filter is cleaned, square port for brushes does not turn. how do i pull it apart & clean turbine or whatever, i how do i get schematic? thanks.
  • 1 more comment
  • Tish Teriaca Aug 10, 2008
    does the turbine come apart easy also? thanks
    thanks a lot. you offer 4 star help! i'll give it a try.
  • Tish Teriaca Aug 16, 2008
    very helpful! took it all apart, brushes now spin, but don't turn off, but that's better than nothing. thanks for all the help.
    President:
  • 1,673 Answers
Take out the screws from the bottom, there will 2 longer ones, they got into the turbine, turn it upright and take the top cover off. The turbine sits near the front, center, remove the 2 screws on the front of it, remove the hoses, then you can remove the turbine(#23).
Posted on Aug 10, 2008
  • Lauren Junge
    Lauren Junge Aug 10, 2008
    It has some screws to remove, make note of how the components and where they go. But I have found that replacing it is the best option.
SOURCE:
The spin brushes on my hoover steam And vac don't
Either the pin on the brushes that attaches to the motor shaft is broken, or the motor is dead. Did you check the switch on the front of the unit to make sure it wasn't turned off?
May 16, 2012 | Hoover Vacuums
Brushes won't rotate on hoover steam vac. I have removed them and cleaned.
The brushes turn by the airflow from the vacuum suction turning a turbine motor to spin the brushes. First try to spin the brushes by hand. If they won't turn it usually means the brushes are clogged with hair and debris or need replaced or the turbine could be seized up. If the brushes won't spin reach under the brushes and push the little tabs and remove the brush block asssembly from the machine. If the brushes spin freely after you remove them from the machine then that means that most likely the turbine is seized and will need to be repaced. If the turbine is not seized you may simply just have a clogged filter screen. Most steam vacs have a red screen filter either on top or underneath the machine. On the top it is under a little clear plastic cover that you have to pry off before you can pull the screen out to clean it. If it's underneath you can pull it out and clean it.
Jul 18, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
The brushes on my steam vac don't spin
(1) Assure the Brush Control on the hood is NOT set to the OFF position.
(2) Remove the brush assembly by pulling/unlatching it from base on each side.
(3) Does one of the brushes have the drive pin present? It should be about ¼ inch square, and two inches long. It attaches the brushes to the drive mechanism.
(4) Remove and clean the intake filter. One the base of the cleaner, behind the brushes, squeeze the two red abs together and pull the panel down to access the screen. Clean the hair/debris off the screen and reassemble.
Mar 10, 2010 | Hoover SteamVac F5914-900 SpinScrub...
My hoover steam vacs brushes will not turn . could there be a belt broken? I have misplaced the manual
For the manual:
http://www.hoover.com/pdfs/manuals/F5914900.pdf
For the brushes:
The gear box that drives the brushes is driven by vacuum air, running the turbine inside.
There are no belts, just direct drive.
Brushes on Hoover steam vac dual v do not turn
Nov 19, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover f5915
Since the Steam Vac does not have any belts... the logical issue is Switch setting (Hi, Low, Off) on the base cover. The only other is dirt collection on the air intake for the brushes (unit uses air passing over plastic fan blades to spin the brushes). To clear the dirt problem, remove the clear plastic cover located just in front of the brush Switch. You can now use your finger nail (or an old tooth brush) to clean the filter screen located just below the Switch. Don't tear it, just gently remove the accumulated dust/hair.
Brushes should spin once you reassemble and power it up!!
Aug 14, 2009 | Hoover F5906-900 Upright Steam Vacuum
Hoover all terrain dual v spin and scrub 12 amps
All of the hoover cleaners use air to spin the brushes the air intake is probably clogged. There is a Little clear window on the top of the machine pull that off and underneath is a little screen clean that out and that should fix your problem. If you need any parts or cleaner for your machine visit www.stevessewandvac.com
Aug 12, 2008 | Vacuums
The spinning brushes are not turning on my Model #F330-900 Steam Vac with rinse.... What could be my problem? Thanks MC [email protected]
Pull the brush block out, is the shaft still on the top of it or did it break off? If it is ok, then the turbine is most likely bad. The turbine is what drives the brush block. Also make sure the little screen filter is clean.
Jul 13, 2008 | Hoover Vacuums
Brushes not working
Check the filter from the bottom, it has a red frame, pull it out far enough to clean it, if it is clooged, then the brushes won't spin. If it is clean, pull the brush block out, make sure the shaft that goes up into the turbine is not brokked off, if it is replace thebrush block. With the brush block out, turn on the machine and look up where the brush block goes, there is a square hole, if it is turning, then it is ok, if not, then the turbine is either clogged up or the turbine has gone bad.
Jun 20, 2008 | Hoover F7220900 SteamVac V2 Upright Vacuum
Hoover steam vac model 7210-900
Did you clean both filters? There is one on the tank and the other is from the bottom, it ha a red frame, pull it out to clean. Pull the brush block out, is the shaft that goes up into the machine broken off? If so replace the brush block. While it is out, trn the machine on and see if the square hole up where the brush block goes, is turning. If not then the turbine has gone bad. You can sometimes clean the turbine out, otherwise replacing it may be the best option.
May 18, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover F7220900 SteamVac V2 Upright Vacuum Logo
205 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Kirk Thompson
Level 1 Expert
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
