Hi, best thing is to get the tyre removed and fitted at a reputable garrage, not sure if you have a brand new wheel, in which case you will need to remove and replace the bearings and seals from the wheel, seals just push in and bearings are a tight fit and often need renewing when removed, fit into new wheel in the same way, using a lite grease when re fitting, most discs are handed left and right, locate the direction of rotation markings which you will find on one of the spokes on the wheel, remove discs 1at a time and replace on to new wheel on the same side as that it was previously fitted on the old wheel, good luck
Testimonial: "Thanks it is an old wheel with the old bearings. That helps because if I would have tried to take them out of the both I would have ruined them both."
