Question about GE 24 in. GSD2000Z Built-in Dishwasher
GE Nautilus dishwasher won't reset
One of our kids opened the door in the middle of the cycle and now it won't reset. It was on Normal wash and now the light just flashes under the Normal button. When we push reset/start it just beeps continually but the cycle won't continue or reset. We can't use the dishwasher-help!!
  • mikendonna Aug 23, 2008
    Dishwasher will not reset. stuck on dry
    Dishwasher stuck on dry cycle
  • 351 Answers
SOURCE: fisher & paykel Nautilus dishwasher
pull the dishwasher out and push down on the top of the dishwasher were the door latch is ,its not making conntact with the microswitch.but you could also have a broken handle.these are both common faults on this model.hope this helps.
Posted on Mar 20, 2008
markevans
  • 148 Answers
SOURCE: Can't cancel cycle without it starting
you have a few choices if the factory says that this is normal. try shutting off the breaker or unplugging the dishwasher. we use plugs when we install them to make removal easier. with the power down for a few moments, it may reset itself if its a solid state board. otherwise, let it run and then start it over again to do what you intended. its not a big problem if that is what you are stuck with for functionality. it is not a common need to reset, i would expect. check the manual too, you may need to hold the reset button for a few seconds or more.
good luck
mark
Posted on Dec 28, 2007
SOURCE: GE Dishwasher Problem
Here is a link with solutions that for the water draining issue. http://www.myhomestyle.info/how-to-repair-your-dishwasher/
Posted on Apr 26, 2008
SOURCE: blinking lights on control panel
Same issue, machine is about 30 days past waranty. Door switch broke, but of course they (GE repair) do not fix the switch, you have to order the Escutcheon Body (whole panel) to fix ~$350 total.
Posted on Aug 04, 2008
rickzilla
  • 706 Answers
SOURCE: After a power outage, my
Unfortunately, if you lost power as a result of a lightning storm or a power surge, there is a good chance that your dishwasher was exposed to a power surge that may have damaged the control circuitry. During these types of events, there is no way of knowing which device was affected unless there are visible signs of carbon or a burnt smell on the ircuit boards... so it will be a hit or miss proposition to repair it. You may have no choice other than to have an appliance person come in and diagnose the problem. Assuming they have a full complemnent of hardware with them, they might try swapping out individual piece parts until the right one is found... Good luck...
Posted on Sep 18, 2008
Updated details: Normal cycle keeps blinking
Have u tried unplugging it for about 2m and plug it bk in that will master reset everything like u just bought it and see how that's works out
Sep 18, 2015 | Dishwashers
Door latch
The safety latch needs adjustment or is loose or worn out if you open the door on door side top you would be able to feel the the safety switch with your finger click on and off it should click very easy if not replace it make sure Dw is off or disconnected.good luck
Oct 14, 2013 | GE Nautilus 24" Built-in Dishwasher
HNL 6146 door won't open
Has it emptied all water out ??
Jun 18, 2013 | Hoover Washing Machines
Does my whirlpol du1145xtpb1 dishwasherr need to be reset
SERVICE DIAGNOSTICS CYCLE
To start the Service Diagnostics Cycle, press the
following keys, in order, in less than 6 seconds, while in standby(power on but unit off):
Heated Dry, Normal, Heated Dry, Normal
To Rapid advance one interval at a time, press the Start key, noting that
unlike Standard cycles, the Diagnostics Cycle automatically resumes
after door openings and does not require pressing Start to resume.
Once the diagnostic cycle has run and shut off, run a normal wash cycle, empty and with no detergent, to reset the control to factory "normal" operation. Make sure there's plenty of hot water.
Read more: http://forum.appliancepartspros.com/dishwasher-repair/261055-whirlpool-quiet-partner-ii-clean-light-flashing-have-reset-still-flashing.html#ixzz2UOcsE2Yg
May 25, 2013 | Whirlpool 24 in. GU3200XTP Built-in...
Water fill solenoid receives only 10 volts on normal cycle-not enough juice to open solenoid. Dishwasher does not fill. Dishwasher works fine on short cycle because on that setting the control panel...
It's most likely the timer set the timer to when it is gonna fill to a normal wash hook up a volt meter when it is in its fill stage make sure it is putting out 120 volts
Mar 18, 2013 | GE Nautilus 24" Built-in Dishwasher
Maytag maxima door locked
Similar problem here - pump was set for a 58 minute normal cycle, I look in and see it is now showing 67. Hmm. Attempt to shut it off because it is just sitting there pumping and pumping. Power shuts off but pump keeps running and add garment light flashing red. Cannot open door (to add garment or not) Unplug the unit and the door will not open. Anybody got a clue what's up? I have a wash in, service is closed due to a storm today. Just bugs me that it is 6 months old and seems to act up a fair bit electronically.
Dec 09, 2011 | Maytag Washing Machines
My magtag 5000 series washer is flashing error code F21, It was in the middle of a wash cycle and now the door is locked and it won't open. How do I at least get the door open. I have unplugged the
Unplug the washer. Then plug it back in and press the button that turns it off. This should unlock the door. Same thing happened on mine and there was a kink in the drain hose. Once I unkinked the hose, unplugged it, plugged it back in, turned it off, then I was able to run a drain & spin cycle to get the water out of the load that was in the washer. I then ran a full wash cycle (they'd gotten stuck in the first drain & spin cycle of a wash) and everything seems to be fine now.
Dec 04, 2011 | Maytag Washing Machines
Door won't open on whirlpool duet washer frontload
Press the cancel button twice to cancel the error code. There should be an error code flashing -- for example 'F02'.
Nov 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
When/where on the washing cycle does the detergent cup open?
normal wash does not open, will open on pot scrub
Please rate this response with thumbs up thanks
Dec 19, 2010 | GE Nautilus 24" Built-in Dishwasher
GE 24 in. GSD2000Z Built-in Dishwasher Logo
354 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
