Question about InFocus IN72 Multimedia Projector
Problem with the InFocus IN1 Gaming Projector (when recieved) - No red, constant yellow tinge and constant lines.
I ordered the InFocus IN1 Gaming Projector from the Dell website just over 2 weeks ago.
I connected my Xbox 360 to it and for some reason the image does not show any red at all. Everything has a terrible yellow/green tinge to it. There is constant lines jumping up the screen and it is almost unwatchable.
I read the user manual and saw that an s-video connection is better (I was using the usual AV connection), so I specially ordered one of these cables to see if this was the problem the whole time.
I received the cables yesterday and tried it out - the exact same problem occurred. There is absolutely no red and everything has a very strong terrible yellow tinge. The games are almost unplayable and there are still jumping lines.
It is because the xbox 360 is set to 60hz, change it to 50hz and it will be clear like it's meant to be. However, some 360 games are 60hz so for those games the quality is not good.
Posted on Nov 19, 2008
What kind of bulb do i need for it? What do i need to show movies ?
sp-lamp-030. you can try projector doctor. they may have it.
Mar 14, 2010 | InFocus Play Big IN1 DLP Projector
Infocus dlp 70+, there is a dark yellow line from
this is the light tunnel being out of adjustment or collasped.
Mar 11, 2010 | InFocus LP70+ Multimedia Projector
Why does my projector Infocus 7205 says constantly replace lamp and we have a new lamp? Thanks for helping...
On the projector you will see 2 buttons for adjusting the brightness, with the projector on press both the brightness up and down at the same time.
Hold them both pressed for 10 seconds. This will reset the lamp timer.
Take Care!
Nov 13, 2009 | InFocus ScreenPlay 7205 Multimedia...
Black and white stripes, no picture
just clean your projector board that connected to the main board, just clean the port.
Oct 08, 2009 | InFocus Play Big IN1 DLP Projector
My infocus IN1 projector won't turn on anymore.
It may be the lamp is out. Normally a projector will try & fire the lamp 3-5 times then shut down with a different color light like amber or red. If the lamp doesn't light then it could be the lamp or perhaps the lamp ballast that starts the lamp has failed. A stuck fan also causes similar symptoms. There's 2-4 fans in the projector if one is stuck or bad it will turn off within 5 seconds or so after the lamp lights.
Does your lamp light at all? Are the lights a different color after it shuts down? Answers to these questions help figure out what's wrong though it's impossible to say for sure without looking at it. I service almost all Infocus projectors if you would like a quote please reply with your email address or write me at prmhelp@earthlink.net
Good Luck,
Jim
Jul 24, 2009 | InFocus Televison & Video
InFocus LP 850 Projector, yellow spot on screen
Unfortunately the discoloration is caused by the extreme heat generated by the Lamp has burned the LCD optical polarization filter/elements.
The only solution for this is to replace the entire LCD optical assembly.
Sorry for the bad news, :(
Jan 29, 2009 | InFocus LP 850 Multimedia Projector
Infocus IN1 Gaming Projector
Hi, I just bought the same projector Infocus IN1 and after just 15 minutes of use it turned off due to overheating. It seems that the lamp is very ineffecient and produces too much heat. The ambient temperature in the room is only 16 deg. celcius.
The solution I came up with is to have a standing fan blowing air directly on the back of the projector from less than a foot away. The standing fan which we usually use here in summer was enough to keep the projector cool. The infocus IN1 did not switch off for the next 2 hours (the entire length of the movie), until i turned it off myself. I am not sure how this system will fare in summer when the room temperature reaches 30 deg. celcius.
Oct 21, 2008 | Compaq Microportable 2810 Multimedia...
I recently bought a infocus in1 audio projector and i cannot get sound and picture together. only seperately by pressing the input botton
Sounds like you have the video and audio plugged into different inputs. For example the video is going to video 1 and the audio is going to the audio input of video 2
If you get only video one input and only audio on another input... Then the above described connection is the only thing that would cause this to happen!
Cheers
Jul 29, 2008 | InFocus Play Big IN76 Multimedia Projector
Infocus LP240 Projector
The bulb won't do that. What you're describing sounds like a light tunnel failure.
Feb 05, 2008 | InFocus Lamp Projector Lamp for LP240 [...
InFocus IN72 Multimedia Projector Logo
222 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
