PICTURE RECENTLY SHRUNK ABOUT 2 INCHES FROM EACH SIDE
  • 1 more comment
  • WVCHARLIE Aug 10, 2008
    MINTEK 26 INCH LCD WITH DVD
    UNITS IS 1.5 YRS OLD AND DID NOT PURPOSELY CHANGE SETTINGS BUT KIDS AND GRAND PARENTS PLAY WITH REMOTE.
    HOW DO YOU CHANGE RESOLUTION
    Genius:
  • 2,920 Answers
Sounds like the picture tube or the vertical is going out on the tv.
Posted on Aug 10, 2008
    Master:
  • 848 Answers
Just try to change the aspect ratio ......
  • 6,487 Answers
There's a option on your remote to change the display settings of the screen , you can find it on the menu and look for display if aret adjusting that still not back on the same size if you have a option on the remote that you can reset the settings of the television try that one and it would be back to its default settings....
Good luck......
    Genius:
  • 2,035 Answers
Unplug the whole unit from the power supply for 30 min and then redo all the cables and check if its working properly ...
Good luck.......
    Master:
  • 763 Answers
Sir, try to configure the settings of your tv resolution. it must changed by someone. hope that helps!
CHARCOIS
  • 19,396 Answers
This is usually caused by a faulty IC or a burnt capacitor in main pcb board, you need having a technician testin component inside tv.
  • Ginko
    Ginko Aug 10, 2008
    Then it is just the video settings, go to menu / video or display / and try setting 4:3 or 16:9.
    Guru:
  • 1,894 Answers
Can you please post your make and model number.
and how old is this unit? did you change any settings in your remote??
  • dewan nafees ahmed Aug 11, 2008
    change it using the option in your remote for the setting for the display.
    it will help you resize the screen.
My sharp only has pictures like four inches from all corners
IF you are saying that there is a picture on all inputs and channels and it is shrunk, there is component on the neck of the CRT called a convergence yoke, it is supplied power by the horizontal section of the main board. It may not be getting enough power. What make and model
Mar 24, 2017 | Sharp Televison & Video
It has shrunk to about 6 inches all the way around the screen so the total picture sizr is 36 inches instead of the 42 inches otherwise clear picture little fuzzy when turning on but becomes a clear
Don't know what wires your using to connect to tv. It does matter, sometimes the connections go bad, either at the tv or cable box. Have you tryed to stretch picture in settings?
Feb 10, 2012 | Toshiba 42H82 42" Rear Projection...
My ilo tv picture is 1 1/2 inches. How can I fix this??
its a vertical problem could be bad cap or possible vertical i.c. okay take to tv shop is their still a warrany on this set sounds pretty new shad
May 14, 2009 | iLO IWT3206 TV
JVC D-Series TV top of picture shrinking
There are probably two capacitors that are bad in the vertical circuit. Not too hard to replace if you have any experience at all. Find the vertical output IC ( usually IC451 or similar ) and simply change the closest electrolytic capacitors. A professional can do this easily. Could cost up to $150.
May 13, 2009 | JVC AV-27D302 27" TV
My screen won't full size and everything is small
My microsoft VAIO laptop screen has shrunk 1.5 inches on left and right side. How do I return screen to full size?
Sep 14, 2008 | Computers & Internet
Shrunk picture?????
enter the service menu mode and adjust the v.line adjustments
Aug 27, 2008 | Sampo SME-34WHD5 34" TV
Toshiba 36a43 no picture
reset the settings using the user manual then the problem will be solved
May 13, 2008 | Toshiba 36A43 36" TV
Screen Problem
Unfortunately the fix is a new lcd. The tab welds at the top of the lcd are not allowing that portion to work correctly. As these tabs are fused to the lcd you will need to replace the lcd. My Toshiba M105 is almost the same.(I Have 4" Gone) on the right side. so to use it I clicked and dragged my system tray from the bottom to the side. And shrunk my web pages to utilize tthe good portion.
I suppose I should replace it but being only 18months old the LCD's run about 160.00 USD.(sometimes I just hook up an external monitor.
Apr 16, 2008 | Toshiba Satellite P105-S6207 Laptop
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
