Question about Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser
Leaking my kenmore is leaking from the lightbulb socket. Water, electicity, not the best of friends. What do I do--Jeremy
  • 725 Answers
It is a plugged drain hose in the freezer remove the back cover and clean out the drain hose...it will stop your leak
Posted on Sep 01, 2008
Kenmore vacuum series 200 brush won't spin
Hi, it's Jeremy from Crucial Vacuum.
There are a few potential solutions you should try. First, check your vacuums brushroll. It may simply be jammed and if so just remove any debris that is preventing it from spinning. If that does not work the issue may be related to your brushroll bearings. Try removing the brushroll assembly and clean all the debris from the brushroll bearing.
If this does not work, the issue may be related to your vacuums belt. Over time the belt can become stretched out, broken, or simply fall off. If the issue is related to your belt, you will need to purchase a replacement belt.
You can purchase direct your replacement Kenmore vacuum parts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/kenmore.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Jul 18, 2014 | Vacuums
It says prime and won't do anything
There are a few potential solutions you should try. First, you should try to re-seat your water tank. Do this by removing the tank from the Keurig and then simply attach it to the machine again. Make sure there are no water bubbles in the tank when you reattach it because this can sometimes lead to a "prime" message. If this does not work, the problem may be that your tank is dirty. Remove the tank from the Keurig and empty it of all the water. Make sure to clean all of the outlets in the tank thoroughly. Then fill the tank with water again and attach it to your Keurig.
Jeremy Lerner
Jun 01, 2014 | Keurig B60 Coffee Maker
Looking up my friend jeremy
Try looking up people that also knows him on a service like Facebook. Maybe he's friend with them on the service. Hire someone. All else fails loosen your standards and settle for another Jeremy. :)
May 01, 2014 | google.com Computers & Internet
Kenmore ultra wash dishwasher leaks from the bottom of the door edge
You electic water valve is sticking open, they get sand etc in there, and can not close, and will not shut the water input off. Do you have city water, or your own well water? Very common problem with well water, sand will clog the return of the water valve from shuttin off the water. Easy to check if you can shut the power off, and water off. dis-assemble the water inlet valve( first thing the input warter goes to)
Dec 19, 2012 | Kenmore Dishwashers
I have a side by side with ice/water dispenser on the freezer side of the door. a couple of months ago the ice maker stopped working and just today the water stopped coming out the dispenser and none of...
1light not work , may lightbuld loose in the socket , or door switch
2 ice maker not work? may the ice maker arm shut-off. sut-off arm to be on(sure be down position)
3 is the ice maker switch in the off positio ( on some models)
4 is the freezer door not closed completely ? if it will not shut all the way,push the door firmly shut for the water dispenser poblem
5 check water filter. or water valve clogged or bad? replace them if necessary
good uck
Jan 11, 2011 | Whirlpool Refrigerators
Kenmore washer leaks after replacing water pump
front loader or top loader we can not guess
Sep 13, 2017 | Kenmore Washing Machines
Refrigerator caught on fire
you have to check the socket of the bulb on plug the unit before checking
Mar 31, 2009 | Kenmore 57029 Side by Side Refrigerator
Electric trips when switch on switch on socket
There is obviously an electrical problem that is causing the trip to operate try it in another socket, then check the plug , if o/k, then it is a case of open ing the washer up to try and locate the prob,
At this stage, it literally could be anything, from a faulty motor, faulty heater, faulty suppressor, the list is endless.
Plz rate my comments.
Thanks.
Jan 08, 2009 | Washing Machines
Kenmore 80 - water leak not from hoses - could it be the pump?
Hi Gleen you probably need to remove the rear cover to expose the in side of machine.
Note if you could post a model number I could tell you for sure what would be the best way get to the pump.
Dec 13, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore coldspot - How do you remove the ice maker box to clean
I have the exact same Kenmore and exact same model #77292798. It's the top freezer model with ice maker. Here's what I did:
Empty everything in the freezer.
Turn water to ice maker off from source behind unit.
Remove bottom panel (two screws)
Every screw in the freezer is the exact same size. I used a screwdriver style socket and, I think
this works the best.
Remove ice maker (4 screws) and unplug from socket.
Remove rear panel (2 screws).
My freezer was loaded with ice underneath the bottom panel. The ice scraped away easily. There is a tin pan underneath the coils that drains toward the middle where the drain hole is. Again, my freezer was full of ice beneath this tin pan and, I had to scrape away. You may be tempted to try and remove the coil because it would be easier to get to drain hole. I tried this and, it did no good. Don't try it. Once all the ice was scraped away, I realized that the drain hole was plugged with ice. I used boiling hot water and used a squeeze bottle to pour the hot water into the drain hole. I then wrapped a paper towel around a thin screwdriver and used that to soak up the now cold water in the drain hole. After doing this a dozen times or so, the drain finally cleared.
Then, reassemble. This was a much easier task than I thought it would be and, will take care of it much quicker next time.
Mar 18, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser Logo
51 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
