Mitsubishi TV Remote - QV button - black screen
There is a large black square covering most of the picture. When I press the QV button it goes away for about 2 seconds but comes back. How can I remove the black square permanently?
The remote is the original one that came with my Mitsubishi set.
sonysonyman
  • 68 Answers
SOURCE: Toshiba tv model 32A443
hi sir, it is quiet clear you have a dried up capaciters in the power supply board and the capacitors of the feeding volts 115v 12v 24v please refer to qualified person to replace them all and evrey thing will come to regular state please don't forget to rate and remember i am here just for help thx
Posted on May 08, 2007
CowboysFanZ
  • 99 Answers
SOURCE: Unwanted black rectangle on the TV screen
I'm not sure what type of TV you are using,, but most all Large Screens have a reset button someplace. You should be able to reset the TV and fix the problem. Its not the remote, making the image appear, but a command from it was misinterpeted. Sometimes turning the set off will work, but most often it needs to be reset.
EXCEPTION... if you are using a cable box. Disconnect it from power, wait 1 minute and then see if the problem exists. If the cable box is on even with the DVD you may still have this issue. Please reset the cable, and if that doesn't work, reset the TV.
Thanks! //D
Posted on Apr 27, 2008
SOURCE: black box in the screen
turn off closed caption text
Posted on Jul 12, 2008
SOURCE: Big Black Square
It turns out that the Closed Caption option was turned on somehow. When I turned that off the Black Square went a way and did not return.
Posted on Sep 15, 2008
  • 927 Answers
SOURCE: mitsubishi 1995 cs31205 32 inch tv
Good Day;
Sounds like you have the TV in the "close caption " mode (text), turn off. 2. Check batteries and the mode the remote is in; eg TV, VCR, Cable & ect. Good Luck, big IRISH.
Posted on Oct 10, 2008
TV picture has black square that covers 95% of the screen
some one has accidentally touch the text closed caption on the remote button. press the close caption button on the remote until it goes off.good luck.
Sep 23, 2011 | Televison & Video
I have a vs-60609 60"
Sounds like a Picture in Picture screen popping up, but if you do not have a signal from another tuner, it will be blank.
Try hitting the PIP button on your remote to see if it turns it off and on.
Plus go into the tv menu and find the PIP settings.
Apr 15, 2011 | Mitsubishi VS-60609 60" Rear Projection...
Black Square area on Screen
If you press display on the remote, it will go away. It will come back, it's a common fault for this set and theres a mod to be done to the eeprom.
Apr 24, 2009 | JVC AV-32120 32" TV
Mitsubishi CS-26201. Can't get clear image on screen
Hopefully you still have the remote.
On Remote, hold the Q.V. button down and press the number 9. That will bypass the lock
Then press the menu button on the remote - go to Advanced features, select Parental Lock - it should sho as on, hold the Q.V. button doown and press the 9 button again, and you will turn the lock off
Dec 31, 2008 | Mitsubishi CS-26201 TV
Mitsubishi 1995 cs31205 32 inch tv
Good Day;
Oct 05, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Big Black Square
Sep 14, 2008 | RCA T19408 19 in. TV/VCR Combo
Large black box keeps covering 80% of the screen
i have the same problem, when i turn the volume knob on hitachi remote it goes away. Anyone heard of thi s???
Aug 30, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Black square
Hello greeny11
get your remote and press menu and look for close caption. Turn off clase caption and this will go away. If you need close caption , set it to CC1
best regards
circuitcity
Apr 08, 2008 | Toshiba 50H72 50" Rear Projection...
Black squares or rectangles over picture
It's the closed captioning. The reason it doesn't go away when you press the "caption" button is because there are four option for closed captioning: Text 1, Text 2, Text 3, and Text 4. The fifth option, which has no designation, is the "off" option. Using the remote, just click on the "caption button until the option has no designation.
Mine was a large black rectangle in the middle of the picture. It's not like Nina3's problem.
Feb 01, 2008 | Polaroid FLM-3734B 37 in. LCD HDTV
Remote wont work TV goes off by itself
Hello, please take the batteries out from the remote. Best regards, Arpi
Jun 23, 2007 | Sony FD Trinitron WEGA KV-27FS200 27" TV
Televison & Video Logo
498 people viewed this question
Top Televison & Video Experts
