Question about HP Pavilion F1703 17" LCD Monitor
Hp pavilion f1703 17"
I am having problems with my monitor it has a red tinge to it and i cant figure oiut how to fix this
ive tried adjusting color in the menu my speakers never did the magnet thing before this so i am stuck
  • 37 Answers
The magnets in the speakers will not effect the LCD monitor. If it is an LCD the problem in internal to the unit. You need skematics, trouble shooting skills, test equipment to repair this. If your menu can't fix it then your going to need lots of help with this one. Good luck
Posted on Aug 26, 2008
Crt monitor gradually develops a yellow tinge after being turned on for a few minutes. It fluctuates annoyingly. It is about 4 years old. It is a Samsung SyncMaster 753DFX Crt monitor.
CRT monitors have three color "guns" in them - Red, Blue, & Green. If one of them is starting to go south you will have a tinge as you describe. To make sure it's the monitor, try connecting a different monitor. If the monitor is the problem, it's not worth fixing. Replace it.
If, after changing the monitor you still have a color tinge, you have a problem with your video device in your PC and you need to have it checked out by a PC Technician.
If you have any additional questions contact me by clicking on the "Add a comment" link located under your problem description on FixYa. Also, if you believe that this information was helpful to you, please return to the FixYa website and rate my response to your question.
Best regards,
Yavacotech
Jan 22, 2011 | Samsung SyncMaster 753 DFX 17" CRT Monitor
The color is "off" on
ladywoman197, 2 things for you to do. 1. disconnect-reconnect vga cable a few times from the DB15 vga port on the pc. If problem (pink hue) persists then try here: http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-blackout-solution/ Your unit may need some new capacitors installed on the power supply printed circuit board. Read fixya profiles of "budmrtn" "12fixlouie" and also visit youtube for video clips of lcd monitor repair. Do the vga cable thing first!!! Could also be vga graphics card inside pc not making good contact with monitor cable. 12fixlouie
Nov 08, 2010 | HP W2007 LCD Monitor
Hi there i am having a HUGE problem with my hp pavilion F1503 and was wondering if i could get some help...This monitor is for some odd reason not submitting colours, there is a colour imbalance...at one...
Components assembled in China are rated for 1000 Hrs. and 85C. Using a Fluke 16 or other Capacitor tester; you will find that the Video Controller has blown SMD Caps. You can get these passive components at Digikey.com. Be very careful when soldering these in. This will solve your problem. I also drill several additional holes in the heat shield and back cover to help dissipate heat from the inverter board. If you are not technically savy in component testing I would recommend purchasing a different model /monitor.
Sep 24, 2010 | HP Pavilion F1703 17" LCD Monitor
Hp lcd f1532 h
This can happen if the minus button which happens to also be the auto image-adjust button is effectively grounded due to some internal fault or
if the switch itself has got jammed internally. In this case, if video signal is present, the motitor reproduces the image but continuously displays "adjusting" as osd message. If video signal is missing, the monitor cycles through solid colors in the black, red, green, blue, white sequence. I think this is part of the hp f1532 design to help the service
engineer( though I have not found any reference to it in official documentation yet). In this special case( minus button grounded), the
menu button is ignored by the monitor.
Kumar Talreja
Jul 26, 2009 | HP Pavilion F1523 15" LCD Monitor
Possilbe to reset monitor?
This document pertains to MX50, MX70, MX75 and MX90 CRT monitors.
NOTE: To reset the monitor to factory settings:
  1. Turn off the monitor by pressing the POWER button.
  2. Press and hold the plus (+) button and then
  3. Whith the Plus (+) button pressed, press the power button to turn on the monitor.
  4. Release both buttons.
Jan 01, 2009 | HP Pavilion MX70 17" CRT Monitor
ViewSonic VE710b 17 inch yellowed photograph look
Check and make sure that there is no speaker, power supply or UPS around your monitor.
Mar 16, 2008 | ViewSonic VE710b 17" Flat Panel LCD...
Permanent Red Line Down the left side of the screen
This can't be repaired, the LCD panel is a sealed unit. if you can't live with it then you need a new monitor
Feb 20, 2008 | HP Pavilion F1703 17" LCD Monitor
Printing Problem With My HP cp1700D Color InkJet Printer
First clean the cartridge and then go to toolbox and give test print.
Feb 17, 2008 | HP cp1700 Color Inkjet Printer
HP Pavilion F1703 17" LCD Monitor Logo
82 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
