Tray won't open in my MRX-530L CD/DVD recorder
Putting a paper clip in the hole doesn't work.
  • mwinte0467 Aug 20, 2008
    I push the button to open it and it remains closed, but makes the click sound like it is trying to open. Help. We have dusted out the unit with an air compressor, but have not actually touched the DVD.
  • 13,433 Answers
This is a computer drive right?
Is it still covered by warranty - if it is let the repair guys deal with contact the maker or your dealer for warranty service, should be free.
if the drive is out of warranty you can safely remove the drive from your computer, unscrew the generally 4 screws in the bottom, take the drive apart, remove the cd / dvd and see what is blocking the tray from opening. By the way does the tray try to open at all?
Posted on Aug 10, 2008
The disk tray on the recording side of the recorder will not open.
use a paper clip to open. first strighten out the paper clip. make sure power is off to the unit. then with the paper clip insert into hole on the player. the tray will eject out. good luck.
Oct 24, 2014 | Audio Players & Recorders
How do I open dvd tray on hp m8120n?
On all CD/DVD look for a tiny hole on the front tray.. use a paper clip ... insert the paper clip in the little hole... do it gently .. it will open the tray.. ALL CD/DVD have the little hole.. so look for it.. remember the hole is as little as a paper clip .. like a pin head small...
May 18, 2014 | HP Pavilion a305w (DM181AR) PC Desktop
Dell cd drive door won't open
CD/DVD Drive Tray problems
There are two ways to open the CD/DVD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD/DVD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD/DVD disc.
If you still having problem opening with the Eject button, then the CD/DVD drive is faulty and needs replacing.
Feb 22, 2013 | Dell Studio XPS 8000 (DXCWKW12) PC Desktop
CD DOOR WON'T OPEN
Just below the CD/DVD tray there is a tiny hole. Insert a straighten paper clip in this hole and gently push the paper clip until the CD/DVD tray pops out. You can now pull the tray out until it is in the fully opened position to remove the disc.
Try pushing the eject button to see if the tray closes, then push the eject button to see if the tray opens.
If this foes not work then the CD/DVD drive is faulty and it needs to be replaced.
Mar 06, 2012 | Dell Computers & Internet
My sony dvp-sr200p, disc tray is not opening?
Hello
Try the mechanical release;
Look for a very tiny hole in front of the drive; use a paper clip poke through that hole, apply a little pressure and push. The tray should pop open.
there might be a panel that covers the tray, and you won't see the tiny hole. If that's the case, just use your fingernail to pry open the panel, which most likely will pull out (not off), and you'll then see the hole. Once you push the straightened out paper clip into the hole, the tray should come out enough for you to pull it out the rest of the way.
Sometimes the CD drive doesn't open because the case is misaligned. Try pressing on the center portion of the drive when it is attempting to open!
Apr 11, 2011 | Sony DVP-SR200P DVD Player
DVD disc stuck?Press Eject, door won't open. disc spins up loads, then flashes fail
Find a paper clip. Unbend the outside piece of wire so you have a 1 inch or so pice sticking out.
On the front of the DVD, look for a hole about the size of the paper clip. Stick the long piece you bent out into the hole and push slowly but firmly until the tray just barely pops out. Slowly pull the tray the rest of the way out and remove the disc.
I've seen this caused by putting a second dvd/cd on top of one already in the tray, actually fairly common when you cant see the dvd drive tray from the top.
Aug 29, 2010 | Computers & Internet
I have a govideo dvd recorder model #r6740 and
Straiten a paper clip, find small hole in front of cd face. Push paper clip in, It should release the tray.
Dec 29, 2009 | GoVideo R6740 DVD Recorder
I cannot open the DVD drawer on my Philips DVDR3480 DVD RECORDER – it just won’t open? The screen display just keeps saying ‘Error’. Any help is appreciated.
I have two of these dvd recorders and both have the exact same problem where the drive won't open. It opens fine when there is a disc in the tray. So I just unscrewed the cover, press the white part which would be over the center of the disc as it's trying to open, it should then open. Then just make sure there is always disc left in the tray.
Nov 26, 2008 | Philips Televison & Video
Tray won't open on my MRX-530L CD/DVD recorder
leave the unit plugged off from power for one night and try to open.
else you will have to open the unit and force the tray outside.
Aug 10, 2008 | Memorex Televison & Video
Televison & Video Logo
105 people viewed this question
Top Televison & Video Experts
Electro Med Services...
