Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
Wester Digital My Book 1 TB problems
I connected my WD My Book to a new computer I just got with an eSata input. The first time the new computer booted up with the drive attached it seemed to struggle a little but finally the boot completed and I was able to open the WD drive and view pictures I had on it. I then shut the new computer down and when I went to start the computer the next day it hung up during boot and I noticed that theis time the LED display on teh front of teh My Book did not illuminate at any time. After some time of being ung up I reboote the computer and then it came up but without the My Book Starting up.
Also now the drive won't respond even on the USB 2 port when I connected ti to another computer I had been using it with. Anybody got anyidea what happened?
  • Anonymous Dec 24, 2008
    I have the exact same problem, anyone got a clue whats wrong?
    Problem Solver:
  • 7 Answers
Try booting your computer first and then connect the usb cable to the usb port on the computer. Connect the power supply cord directly to a wall socket. Also try the usb cable on different usb ports on the computer. If possible also try it with a different usb cable. If nothing works, check the file format system under disk management, you might have to re-format it.
Posted on Sep 04, 2008
1 TB My Book Live Western Digital, light starts up blue then after trying to discover goes red, tried new eternet cable and still going red. Reset my router and have tried plugging hard drive right into...
I have SeaGate FreeAgent GoFlex 500GB external hard disk and it shows only 230GB. I formatted it many a time but still shows 230 Gb only..Please help me to fix the problem....
Sep 11, 2013 | Western Digital WD My Book Live 1 TB...
Why western digita my book elite is sooooooooooo slow coping the data
The speed of copying depends on the speed of the USB ports on your computer, which is either the original USB 1.1 specifications, or the newer USB 2.0 specifications, which is at least FIVE times faster.
So, if your (older) computer has a USB 2.0 interface, connect the W.D. to it, rather than to a USB 1.1 interface.
Oct 23, 2010 | Western Digital My Book Elite 1 TB USB 20...
WD 1 TB- WINDOWS can detect but cannot see in my computer
if the disk is not in Computer Management then the disk has a major problem. it should be there but in black because u need to initialize it.
Apr 14, 2010 | Western Digital My Book Essential 1TB...
My 1 tb WD hard drive isn't even being recognized
If the 1 tb is spinning up, which I assume it is, the new PC (assuming a Win 7 OS) should see it and mount a driver to be able to talk with it. I would double check all my connections at the drive and the PC, try different USB ports just in case one is dead.
Apr 11, 2010 | Western Digital My Book Essential 1TB...
Western Digital 1 TB External Hard Drive and BSOD
perhaps the new hard drive is bad western digital software is junk take it back and get seagate external w/freeagent on it
Dec 31, 2009 | Western Digital My Book Essential Edition...
MY Western Digital 1 TB drive operates fine with a USB 2.0 cable but won't even turn on when I connect an ESATA cable or my firewire cable. Am I stuck with USB as my only connection option?
Some of it may depend on the controler you are using. some of the VIA chipset ones are not all that good and overheat a little causing ptoblems.
Also make sure you do have the firewaire card in your computer.
Many cases have the connection on them but no card inside.
Same for E-SATA.
Double check inside first !
Sep 08, 2009 | Western Digital My Book Essential Edition...
Western Digital drive disappears
i heard that it must be installed under SATA 3 or 4 and only the c drive or system drives are to be under SATA 1 and 2. You change this in the BIOS i think.
Jul 04, 2009 | Western Digital My Book Essential Edition...
Input Voltage on WD MyBook and Elements
NO, they are not all multivoltage. Especially if you bough *** in the states as a 110v. You will need to have an external voltage adaptor in use.
Jun 13, 2009 | Western Digital My Book Essential Edition...
ESATA Connection problem with My Book & my laptop w/ Vista
Had the same problem with a WD esata 1TB drive and an HP DV6 laptop. Using Vista home premium. Lots of experimentation BIOS settings and driver update, and finally fixed it by trimming back a couple of mm of the plastic shoulders on each connector of the esata cable. A few depth measurements and it became clear that the connectors weren't going in deep enough otherwise. The cable was a Belkin of reasonable quality.
No problems now, but the drive is only recognized if it's connected at boot-up.
The core of the problem is the external casing of both the laptop and the WD drive enclosure. They're thick and keep the cable connector from going in far enough. Perhaps manufacturers of the cables or the esata devices are sloppy, or the standard isn't specified well enough. I've seen pictures of esata cables that have significantly different dept.
May 14, 2009 | Western Digital My Book Essential Edition...
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
240 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
