Question about Sub-Zero Bottom Freezer Refrigerator
Subzero 550 coils
Hello, the coils in the back of the refrigerator keep freezing up. we have had both compressors replaced. also, the switches on top of inside door were not being pressed so had this addressed. what can cause the coils to freeze? i let it defrost for a few hours and then works fine for a few days. any thoughts?
  • kbonadonna Aug 17, 2008
    any comment on this problem?
  • byrddog Feb 24, 2009
    either this prob or not defrosting ,as ice builds up.???
WOW. I DISCOVERED THIS WELL. I HAD PROBLEMS FOR YEARS WITH THE DRAIN SYSTEM FREEZING UP. I DID THIS ALL WITHOUT PULLING THE FRIDGE AWAY FROM THE WALL. I DISCONNECTED THE DOWNSPOUT AND SNAKED/WRIGGLED A FLEXIBLE WIRE DOWN THE DRAIN AS FAR AS POSSIBLE. I THEN REPLACED THE DRAIN BRINGING THE WIRE UP THROUGH THE DRAIN AND BEHIND THE RUBBER SEAL SO IT IS IN THE UPPER PART OF THE FRIDGE(ABOVE THE CRISPER) AND TAPED IT TO THE BACK WALL. THERE IS ENOUGH HEAT CONDUCTION TO PREVENT FREEZING. IT'S BEEN OVER A YEAR AND NO FREEZE UP.
Posted on Feb 28, 2009
I had same problem very recently.  The problem with both the refrigerator and freezer on the 550 is that the drain line that takes condensation and water from the defrost cycle to the drain pan freezes up. Sub Zero parts suppliers will sell you a fix-it kit which I used for the refrigerator.  The kit is simply a heater wire that you plug into one of the existing circuits and runs down the length of the drain pipe to keep it from freezing up.  When my freezer started doing the same thing I ordered the kit for the freezer but the wire was too fat for the drain pipe so a Sub Zero rep gave me a better and more elegant solution.  You need a length of bare 12 guage copper wire, about 24 inches.  Run it through the drain pipe with about 6 inches exposed at each end.  On the underside of the fridge, wrap the end of the copper wire a few times around the black heater coil that you will see running back and forth.  At the upper end, wrap the copper wire around the black heater coil that defrosts the freezer coil.  The heat generated by the two coil will simply conduct heat through the copper wire and keep your drain line from freezing up.  There is a 90 degree bend in the drain line which makes it difficult to feed the copper wire through.  I suggest using guitar string or picture hanging wire as a snake.  Feed that through first, then us it to pull the copper wire through.  Good Luck!
Posted on Oct 07, 2008
3 Suggested Answers
Krazytech
  • 725 Answers
SOURCE: SubZero 550 Refrigerator Coils Freezing
defrost problem ... do you have frost or ice?
Posted on Aug 25, 2008
catriver
  • 878 Answers
donna, the model posted probably has a adaptive defrost board. You definitely have a defrost problem. I hate changing these out. They can be a challenge. It's located on the right side in back on the refer controls. You have to remove the control panel. There are 2 slots in back where you can get a finger in. Pull down on these tabs and pull out at the same time. The control panel housing will pull off. This can be a real bear to do as I always fight with them. Next you would remove the light fixture screw on the right side. A little farther back will be another screw holding the right side of the upper panel. Then there will be one on the back wall next to the filter holding the upper panel there. Now the right side of the upper panel will drop down enough to get at the adaptive defrost board. You should do a test on it by shorting between L1 and test that are marked on the board. When you do this the refer will go into defrost for approx 23 minutes. If you short between the 2 and it jumps right back out of defrost, then you can assume the board is bad. I really believe that this is your problem as I have had many of them in the past. The heater and bi-metal on the evaporator usually never fail. But to be sure, you can do the test I described above. Now some models do have a mechanical defrost timer, but on the msd2758gew it should be adaptive. You can get an idea of how this board looks by going to repairclinic.com, entering your model number and following the links to get the part you need. Catriver
Ice keeps forming inside on the back panel of mysubzero model 550
If the ice is on the back panel especially a block of ice in the middle left part of your panel, then you have a sealed system problem. Check to make sure that your condensor coils above the refer are clean, and if it continues to have an ice block then you have to have a technician come out an do a major repair. This is not something you can do yourself, most subzeros have a 6 to 12 year sealed system warrantee that covers either all of the repair or just parts. This is an expensive repair if it is not warranteed, but when the refers cost 8000 to 10000 new it is usually well worth it. Most often it is the result of a slowly leaking evaporator, though most inexperienced technicians replace the compressor first, so make sure you use an experienced Sub-Zero technician. Good Luck, Appliance Specialits
Nov 12, 2009 | Sub-Zero Bottom Freezer Refrigerator
My Subzero Condenser fan runs constantly - but coils are clean
If it is similar to mine at home (Model 550) the condensor fan is designed to run continuously, even when both the freezer and refrigerator are shut off. There is no control or switch in the fan circuit, so it just runs whenever the fridge is plugged in to the wall. It uses about 56 watts.
Oct 19, 2009 | Sub-Zero 611 / O Bottom Freezer...
Sudden loss of refrigeration
why does it need to be replaced but in south afrika it costs r400.00 and labour r400.00 total cost r 800.00 but what is the problem maybe i can assist
Jun 17, 2009 | Sub-Zero 690 Side by Side Refrigerator
My subzero 650 bottom freezer working top part not working (warm)
Make sure the condenser is clean. Instructions are in your manual or subzero.com. If cleaning it doesn't work call for service
Apr 04, 2009 | Sub-Zero 650/SRH Stainless Steel
Aug 25, 2008 | Maytag MSD2758GEW
Subzero Model 550, freezer not working properly
Blow out the condenser with an air compressor. Make sure the evaporator coil is not frosted up, if so, the drawer may naot have been closed properly, or you may have a defrost problem, (timer, terminator, etc). Possible freon leak in the high side drain loop. Compressor may not be pumping efficiently, could have a bad condenser fan motor.
May 28, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub Zero 550 Frost Build up in Refrigerator
This means you are low on freon. You will get an ice ball on the bottom left side in the back of refer.
dartmanc
May 27, 2008 | Sub-Zero 650 / O Bottom Freezer...
Hi...need help...subzero 550
Make sure the condensor is clean, blow some Air though the Condensor to make sure good Air flow towards Compressors. also, you might have a bad defrost timer or Freezer Control... worst case you might have a bad Compressor... hope I can help....
Jan 16, 2008 | Sub-Zero Bottom Freezer Refrigerator
SubZero 550 not cooling, ice film
1. check the comp. working touch the top of the comp. 2.if the motor comp. working touch the high side tube of the motor comp. if to hot the freon is ok. 3. check the cooling fan inside.
Sep 23, 2007 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero Bottom Freezer Refrigerator Logo
547 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
