Question about Frigidaire GLEQ2152ES Electric Dryer
Dryer not ressponding...
A week ago i used the dryer and took out the clothes before it finished, today I tried to run it. The breaker was in the off position, put it back on and just got a low humming sound, what's wrong with the unit... could you help me out? Thanks.
  • 639 Answers
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
This is an electronic problem and
for this is a situation that you will need service!
Here is the service company I refer my appliance customers too!
A&E Factory Service
A Nation Wide Company. / Available 24 / 7 for arranging appointments! In the USA.
1(800) 905-9505
If this dryer is 10 years old or more do not spend any money on it!
The new ones are much more efficient! If you have to replace it buy a Speed Queen , it will do 8 loads a week for 25 years!
It's the last washer and dryer I will ever buy!!!! And less expensive than a top of the line unit!
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Posted on Aug 28, 2008
Why does dryer continue running after dry cycle finished?
I would say this is in the control board but not 100 percent on this. If you go to an appliance store, not a big box, they will probably help you diagnose and order the part for you if you want to do this on your own.
Feb 09, 2016 | Dryers
Kenmore 110.66902690 electric dryer does not dry completely
Dear Barry,
Try 2 things.
One, be certain the clothes are very dry coming out of the washing machine.
If the washer leaves the clothes wet ( like the belt might be slipping), it can take the dryer forever to finish drying the clothes.
You can tell by hand-wringing them.
You should not be able to get any water out of them by hand-wringing after they have spun dry in the washer.
Two, try running a load with the vent hose unhooked off the back of the dryer.
If this fixes the problem, you are having a "clogged vent" issue somehow.
Be blessed.
Apr 16, 2013 | Dryers
A few weeks ago our kenmore dryer would only dry for 10 mins or so at a time, finally after about a week it wouldn't come on at all. Had a repair man tell us it was the timer. We ordered a new timer...
it it tried to turn on when you flip the breaker then the problem could be a loose connection more often than not dryers pull allot of amperage and if the wires are loose it will from an arc similar to welding and melt the wires the unit runs only when the wires make full contact.
1. turn your breaker off 2 remove the area where the connections come into the dryer check there if all is good there go to 3 3 check the plug 4 check the wall connector 5 check connections at the breaker
as always follow safety guidelines when working on high voltage this is 220 volts
Best of Luck
Jun 02, 2011 | Kenmore Dryers
I have have an older kenmore electric dryer that won't start. Let me give you some detailed information about the events that happened prior to the discovered failure. -This dryer hasn't been used for a...
The heat is not a factor.Make sure you do not have a tripped breaker. Otherwis if you had a power surge to the dryer, ther could be electrical damage.
Aug 11, 2010 | Kenmore Dryers
Whirlpool Imperial Electric Dryer wont heat up
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jul 22, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dryer won't turn on for 2nd load
A couple of things is to make sure you have 110v at the recepticle, if you do then it's with in the dryer. It could be the door switch wont close, thermal over load won't reset in your motor(if it got hot enough to open, you said it had been in use) , broken belt switch if your dryer has one, or even the thermal fuse (in series with L-1) opened up. Ohm out the door switch in the closed position, it should read 0 ohms, Same with the thermal fuse, should read 0 ohms, not an open read.Good Luck..MJE
Mar 25, 2009 | Dryers
Dryer starts when it wants too
you maby have a weak thermal fuse.
Mar 15, 2009 | Whirlpool GEX9868J Electric Dryer
Dryer
dryers take a lot of power to run.the circuit is tripping because it cannot take the load of the dryer.you may have to get a dryer line installed.check the value on the circuit breaker.u need to use twice that value on the dryer.with clothes added to the dryer the motor takes more current to spin.this extra current is greater than the circuit breaker value so it trips to prevent the house wire from going on fire.
Jan 07, 2008 | Kenmore 63942 Dryer
Dryer and breaker
you have a week breaker or a breaker that is to small you need a 40 amp breaker 20 on each side (two breakers locked into one) or worse you have a short in the dryer. If dryer runs for a little bit and then shuts down its the breaker.if it throws breaker as soon as you plug it in or start it then the short is in your dryer good luck
Dec 29, 2007 | Maytag HYE3658AY Electric Dryer
Dryer needs multiple cycles to dry
I would check on the outside of the building. anti pest screens usualy plug up with lint. from the discription you have made it is definatly having troubles venting some where. Check every thing because venting is usualy not covered under warranty.
Sep 15, 2007 | GE DBSR453EBWW Electric Dryer
Frigidaire GLEQ2152ES Electric Dryer Logo
51 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
