K2 Zed 24 Boys' FrontSuspension Mountain Bike Logo
Posted on Apr 26, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do we raise the handle bars on the k2 zed 24
Arturs Kalnins
Level 3:
  • Master 2,338 Answers
  • Posted on Apr 26, 2011
Arturs Kalnins
Master
Level 3:
Answers
2338
Questions
9
Helped
1814051
Points
13579
The only way to do this is to get new stem with the bigger angle degree. If not sure, get the adjustable stem.
How do you raise the handle bars on the bike?
If it is an older bike, you loosen the bolt at the top of the handle bar shaft until it is about 1/2 inch raised. Take a hammer and give it a swift bump and it should drop into the shaft. Hold the front tire between your legs and the handle bar should raise up. Re tighten once every thing is lined up. If the bike has front hand breakes these may need to be adjusted.
you cant raise the handle bar but you can add spacers to increase the height.Wish we could be able to raise the handbar
Allen & Heath ZED 24 3 no. channel off what is fault
You may download the schematics for free from Manualslib com
Can not raise the handle bars on the Huffy Mojava Gulch?
You need to loosen the front bolt that holds the handle bars to the front wheel raise it to your desired position and then tighten it again, making sure that the handle bars are at the position you desire them. This will lock them in place so you can ride your bike and not let them fall back down deeper into the front wheel shaft.
My rear breaks aren't working. bike has been in storage for about 3 years
brake pads are most likely dried up. you need soft rubber for brake pads
1helpful
How do i raise the handlebars?
There are two bolts in the center of the handle-bars. One bolt (on some bikes this is actually 4 bolts) is used to clamp the handle-bars to the handle-bar-stem. You can see both ends of this bolt. If you loosen it, you can tip the handle-bars up and down, but not raise them. The other bolt you can only see the head of. Loosen this a couple of turns (don't unscrew it all the way) then give it a tap with a hammer. You will then be able to pull the handle-bar-stem completely out. Do this so that you can see the wedge-shaped nut at the other end of the bolt. You should also see a mark on the stem that indicates how high you can safely raise the stem. Put the stem back in to the desired height and tighten it back up. Good luck.
2helpful
Schwinn Impact MOS.....can the handle bars be raised? If so, do you loosen the small star nut on top, or the large nut at the base of the handle bars?
In order to raise the handle bars, you will need a hex key. Put it into the hex indentation at the top. Turn it left to loosen it. Then raise the handle bars to the desired height.
May 22, 2010 • Cycling
1helpful
Need to raise the handle bar on my 2007 Marin Argenta road bike.
The stem for the marin is fixed so you'd have to replace it with one that is higher if you wanted to raise the elevation of your handle bars. You can pivot the handle bars for your preferred angle of comfort though. Loosen the 4 screws on the top of the stem and then you can adjust the handle bars to the correct angle that is best for you.
Jan 09, 2010 • Cycling
I don't know how to raise the handle bars on the ccm vandal 24.
if there is any element holding it then loose it firmly and apply oil if coroid after that screw it slighly back when adjusted to the desired position.that is all and ride with pleasure.
Jul 09, 2009 • Cycling
Top K2 Cycling Experts
ADMIN Andrew
ADMIN Andrew
Kardoc
Tony Parsons
Tony Parsons
Are you a K2 Cycling Expert? Answer questions, earn points and help others
