Question about GPS
Garmin c340 will not turn on - GPS
  • celinstx Aug 10, 2008
    we finally got it to turn on but now it cant find the maps
  • 218 Answers
Verify that plug is inserted fully and that the outlet is live. If that is good, then try the reset button which is hidden under the faceplate. Unsnap and remove the trim ring from the front by pulling with a fingernail under the logo. Press the reset button. If still no joy, check fuse in power plug by unscrewing silver nut on end of plug. If none of this works, then you might have a battery failure or other internal failure.
Posted on Aug 10, 2008
Why does my c340 keep losing satellite reception
Hello there:
please follow these instruction and this should help if not let me know and i willcontinue to get you more information for you
nstructions
  1. Step 1 Calibrate the screen of the Garmin StreetPilot C340. If the touch screen does not seem to respond when you hit it with your finger or a stylus, you may need to calibrate it. To do this, turn the unit off and then hold down the "Power" key for approximately one minute. You will see a calibration screen come up that will recalibrate the GPS2_bing.gif unit.
  2. Step 2 Reset the Garmin StreetPilot C340. If your GPS unit is not responding or is stuck on a particular screen, it may need to be reset in order to operate. To reset, remove the face plate of the unit by gently prying it off. Locate the "Reset" button under the face plate and press down in order to restart the device.
  3. Step 3 Change the fuse of the Garmin StreetPilot C340. If the fuse blows on the GPS, you will need to make a replacement using an ACG/3AG 2 amp fuse. Unscrew the adapter cord at the end and remove the fuse found there. Put in the new fuse to see if this returns function to the unit.
  4. Step 4 Update the software for your Garmin StreetPilot C340. If the GPS is not providing you with correct directional information, you may need to update the software or download new maps onto the device. Connect the Garmin StreetPilot C340 with the USB cord to your PC and log on the Garmin website for available updates.
Jan 15, 2010 | Garmin StreetPilot c340 GPS Receiver
My Garmin Street Pilot c340 does not turn on
try calling Garmin and ask their tech department for help or go to their web site and explain problem they should get back to you right away.
Oct 03, 2017 | Garmin StreetPilot c340 GPS Receiver
Have a Garmin c340 and want to update maps. Have
go to the garmin site itself and answer a few questions about your unit and then follow the on screen instructions.
http://www.garmin.com/garmin/cms/site/us/maps/
Oct 09, 2009 | Garmin StreetPilot c340 GPS Receiver
Cannot turn the power on.
I have bot this Garmn c340 at year ago. I couldnt turn my Garmin c340 GPS , even i have pu on charger more than 4 hours. Please let me know what should i do?
May 24, 2009 | Garmin Nuvi 350 Car GPS Receiver
Update 2009 maps into c340 how to
Try Here for the updates,
You may have to add Garmin to your trusted web sites !!! Firewall.
In a web browser, tools, internet optoins, security, trusted sites, sites button, add it here.
hope this helps.
Regards.
Dec 06, 2008 | Garmin StreetPilot c340 GPS Receiver
My Garmin C340 is dead!!!!
I had the same problem on a trip. Required two fixes and once I did this the unit worked fine.
1. Replace the fuse in the car adapter (reason it wasn't charging when I used it in the car).
2. See the users manual on page 31 regarding resetting your C340.
http://www8.garmin.com/manuals/StreetPilotc340_OwnersManual.pdf
Jul 21, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin c340 user's manual
This should be available from Garmin. Check their website at www.garmin.com. Click on the C340. It may be available online.
May 10, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin Streetpilot c340 arrived dead
The battery symbol would show the charge, somethign doesn't pop up.
May 08, 2008 | Garmin StreetPilot c340 GPS Receiver
Charging unit with AC adapter
I have a 100v A/C power / charger unit for my garmin C340 GPS that I use to charge my Garmin's battery every day. I can use thj adapter to run the GPS, or just turn it off and let it charge the GPS. But it connects dirctly to the Garmin GPS unit, not to the cradle like the Cigarrette lighter unit does. .
Mar 18, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin c340 gps
It still should be under the one year warranty with Garmin. Call Garmin support and get a RMA.
Nov 25, 2007 | Garmin StreetPilot c340 GPS Receiver
GPS Logo
268 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
