Question about Samsung HL-P5063W 50" Rear Projection HDTV
No picture replaced lamp twice and still get three blinking lights in front of the tv. The fan goes on but the lamp doesn't
  • 2,071 Answers
  • Samsung Master
  • 6,487 Answers
You need to make sure that the lamp is connected properly , so better take it out again and make sure when you put it back in its properly connected , because if you replace it twice already that cannot be a bad lamp..
Good luck.....
Posted on Aug 10, 2008
  • Samsung Master
  • 19,396 Answers
Check the lamp contacts, eventually remove lamp and fit back in, chack that you did not burnt new lamp when mounting it in, you need a multimeter to test lamp.
  • Ginko
    Ginko Aug 10, 2008
    New lamp is quite easy to blow while you mount lamp inside TV, you must grab a multimeter and test lamp for continuity, if there is no continuity (multimeter returns infinite resistance) the new lamp has blown, in this case is better checking also the voltages out from small pcb powering the lamp. This is a job that is better done by a technician.
    All you can do at home is taking lamp off and putting it back in place, to see if it is fitting problem. If you know how to use multimeter test lamp for continuity to see if it has blown or is faulty. If lamp is faulty (no continuity and no sign of external damage) get a replacement or refund.
My ws-65615 tv blinks AND GOES BLACK
It may indicate the lamp needs replaced, or that the cooling fans are not turning. When the controller senses too much lamp current, or dimmer than minimum light output, the controller will shut down the lamp to prevent damage. Replacing the lamp fixes that. Over-heating, or fans not rotating will cause the controller to shut OFF the TV. Clean and lubricate the fans with a vacuum and a tiny drop of lubricant on each motor bearing. Also clean and vacuum the air filters. Dust and dirt are the enemies of fans and lamps. Regards.
Aug 13, 2015 | Mitsubishi WD Televison & Video
I just replaced the bulb last week, yet this time the TV will still not turn on and all three lights are still blinking.
It is possible that the replacement lamp is bad but more likely the TV has a protection mode that triggers wen the lamp goes out. Check the manual for ways to reset the lamp usage back to zero or a function that needs to be manually reset when the lamp is changed.
May 02, 2015 | Televison & Video
Sony kds-rx60xbr1 red light blinking turn it on and off and tv goes on
The lamp for this model number is XL-5100
Before ordering the lamp, I would inspect the inside of the TV, be certain that the three fans are clean and free from dust. Often if a fan does not start the first time it may start on a restart. Due to the nature of televisions operating, dust seems drawn to these TV's. Cleaning the fans might correct your issue.
Oct 12, 2017 | Sony KDS-R60XBR1 60" Projection HDTV
My HL-P5063W won't power on. I replaced the Digital Video Board and the lamp. When I power up the the TV, there are several clicks and never a picture. The lamp does not appear to getting any...
Did u ever replace the Ballast board for this tv?No?,that ur tv problems.The Ballast board only job are to ignite the tv projection lamp to make it work.U hearing multiple clicks,lamp never ignite up the Ballast board.
Jul 29, 2011 | Samsung HL-P5063W 50" Rear Projection HDTV
Rca HD61LPW42 -- we just replaced the color wheel. now we get a picture but only for a few seconds. then it turns off and after a few seconds restarts. this goes on indefinitely. a couple of times...
Hello
If the power light blinks slowly,
you've tried to turn on the TV during
the lamp cooldown cycle. Wait
approximately 30 seconds, and the TV
will turn on automatically.
If light blinks, pauses for about a
minute, and blinks again: the lamp is
trying to turn on (TV will turn on
when successful). If TV doesn't turn
on and sequence continues, the lamp also
needs to be replaced.
To order lamp call 1-800-338-0376.
Have your TV serial number
and lamp type available (you'll
find this information on the
sticker that's on the right side of
the TV).
OK.
Jul 24, 2011 | Televison & Video
Samsung HLN5065W..no picture, TV won't stay on, 3 flahsing LEDs.
Lamp Fan, make sure all fans are running if they run for alittle while and stop Fan is defective.
May 01, 2010 | Samsung HLN5065W 50" Rear Projection...
No picture on tv all three lights flashing on front of tv.
Three blinking LEDs mean lamp may be defective replace the lamp.
May 25, 2009 | Samsung HLR5667W 56" Rear Projection HDTV
No picture on my samsung 61" dlp.
The color wheel if bad enough, will cause the lamp not to light. If the lamp is truly bad, you can't usually tell by just looking at it unless of course it is broken.
May 18, 2009 | Samsung 61" Slim-Depth DLP HDTV
Tv not working after lamp replacement
CK Fan if it is going bad set will shut down.
Feb 06, 2009 | Televison & Video
Panasonic PT-53WX42 - When I turn the TV on, the red light comes on but, no sound or picture.
Does the light blink? If it is blinking a 3 code, the IC's need to be replaced. Those three lamps as you called them are not lamps, they are the three picture tubes.
Jan 08, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Samsung HL-P5063W 50" Rear Projection HDTV Logo
256 people viewed this question
Henry  Thomas
Henry Thomas
