Question about HP Photosmart 3310 Printer
Printer que drops printing jobs
I will send a print job to the que and it sits for a while then says printing stopped without printing anything. What is causing this?
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
Sounds like your printer queue is clogged..it will need to be completely cleared.
Posted on Aug 19, 2008
Print que on hp 4300 says "printing" but nothing happens and I cannot clear que
This is a common problem with Windows machines. If a print job gets corrupted in the print que it will stop and block all other jobs from printing. It will also block the job from being deleted normally. You have to stop the print que service and then delete the print jobs from the que. Here is a link to a full article that shows how to stop the que, delete the print jobs and restart the que to restore printing.
http://www.ccl-la.com/blog/index.php/how-to-delete-print-jobs-that-are-stuck-in-your-print-queue/
Nov 29, 2012 | HP LaserJet 4300 Printer
Only prints first job - can't delete from que
Please try this approach instead:
1. Browse to Start -> Run... and type in NET STOP SPOOLER (this will stop the print spooler service)
2. Browse to your windows\system32\spool\PRINTERS\ folder. You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files.
3. Browse to Start -> Run... and type in NET START SPOOLER (this will restart the print spooler service)
4. Double click the printer icon in the lower-right corner of your taskbar to examine your print job queue and browse to View -> Refresh.
I hope this information has been helpful.
Dec 20, 2011 | Lexmark X6170 All-In-One InkJet Printer
My printer is plugged in, all of the software is installed, there is both color and black ink, the power is on and the test pages printed no problem, but it wont print anything else. it has a que set up...
It could be a print spooler problem. You have to clear the print queue first before sending out a new print job and make sure the print spooler service is running. Follow these steps on how to clear the print jobs stuck in the print queue:
1. Browse to Start -> Run... and type in "NET STOP SPOOLER" (this will stop the print spooler service)
3. You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files.
4. Browse to Start -> Run... and type in "NET START SPOOLER" (this will restart the print spooler service)
5. Double click the printer icon in the lower-right corner of your taskbar to examine your print job queue and browse to View -> Refresh.
Apr 28, 2011 | Lexmark Z2300 InkJet Printer
Won't work - just sits there - multiple jobs in que - que says nothing - when i pause one job they all pause - when i resume one job they all come off pause but don't say printing or waiting or anything?
Turn off the printer unplug the printer also unplug the PC from the wall or power supply if lap top. Then push the power button in on the computer with it unplugged. Now restart the computer and turn on the printer at the same time. I hope this assisted you. It was jammed with print jobs you will reset default this way. Start fresh if you have to reinstall the original software if this does not work. Thanks for using FixYa! John
Feb 22, 2011 | Office Equipment & Supplies
There has been a pending document in the que. I tried to delete the document but now it states deleting next to the document in the que. Can not print anything.
Open the Print Que and see if it will let you pause the print job. Then close the que and turn the printer off. Open the print que again and see if it will let you delete it. For some reason every now and again a que will hang. This process should reset the que. It will dump everything in printer memory and should release the document to delete the job. In any event pausing the job should release the printer to print other jobs.
Sep 05, 2010 | Office Equipment & Supplies
I stopped a print job and do not want it to continue.
Well, go on to print que on the bottom right side corner and look for the Printer Icon when found it double click onto it and delete the one you would not like to print..!
All the best..:D
Feb 13, 2010 | Brother HL 1440 Laser Printer
HP P1005 PRINT JOB SITS IN QUE, WO'T PRINT
Does it show "Printing" or "Spooling" in the job queue window?
Open the Job queue window, then highlight and cancel the print job. Send a small print job to the printer and make sure that the PC and the printer are communicating.
If the failure re-occurs, then clear the queue again and close it and restart i=the queue.
Don
Dec 14, 2009 | HP Hewlett Packard LaserJet P1005 Printer
Batch job printing not done and sitting in a que
In run window type services.msc and the go to print spooler option just stop and restart the service. and also switch off and switch on the printer and try to cancel all the documents form print spooler it will remove all pending jobs.
Nov 06, 2009 | Lexmark T644 Laser Printer
Intermec 3400 label printer
try here they oft times has a few good referance materials http://epsfiles.intermec.com/eps_files/eps_man/064678.pdf
Sep 06, 2007 | Intermec EasyCoder 3400 Thermal Label...
Brother mcf7220 will not print..says "cancel printing" "job cancel"
firest you swithc off all the printers and wait for some minute then clear all printers queue by going in to printer folder then restart your system.
Sep 01, 2007 | Brother MFC-7220 All-In-One Laser Printer
HP Photosmart 3310 Printer Logo
187 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
