Question about RCA Universal Remote Control
Code i neede a remote code for my remote rca 4258
  • 2,071 Answers
Http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing thefollowing steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): code - clip_image001.gifWe could not find an exact match, we think this code will work. 10054 Setup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Aug 25, 2008
How do i connect my rcr remote to my oritron dvd player?
Your RCA remote may not have a code for your Oritron DVD player. You may have to try another remote.
Aug 01, 2014 | RCA RCR-4258 Remote Control
Could please give me the code for a sharp TV
there are many codes for the sharp... but this is the link to manual... it has all the codes for that model just click on the free pdf version... http://www.replacementremotes.com/RCA-Manuals/Download-FREE-RCR4258-RCR4358-MANUAL-Codes-OPERATING-MANUAL.html you will also need to have adobe reader... which you can download from adobe.com hope this helps
Jan 18, 2011 | RCA RCR-4258 Remote Control
Need a codefor the rca remote control for a Magnavox #h2160mw9a I am traying to program the rca remote and I need the code
Hello littlemoney, You can view and download your manual at the following link: It will be in PDF format. If this was not the manual you were looking for please post a reply. Thanks for using FixYa! Edward
Aug 26, 2010 | RCA RCR-4258 Remote Control
I need help to reprogram this remote. The
Hello, I am sorry i did not get back to you sooner!
I found the manual on the internet, you can just copy and paste into your browser to download a copy for yourself if you like.
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=rca&dv=universalremote&md=rcr4258rcr4358&kw=RCR-4258&st=&ar=&dt=&so=&pg=1&file=others/rca/rcr4358-manual.zip
Here is the simple way of doing it:
0) Turn on TV.
1) Press and hold the TV button, light lights up, continue to hold.
2) Press and hold the power button, light turns off, keep holding both buttons down until light comes back on, release both buttons, light stays on.
3) Point remote towards TV the entire time you are programming.
4) Press and release play button, wait 5 seconds, if TV did not turn off press and release play button again wait 5 seconds. Repeat until TV turns off. (When your TV turns off, it was in the last 10 codes sent).
5) Press and release Reverse button, wait 2 seconds, repeat until TV turns back on.
6) Once the TV turns back on press and release Stop button.
7) Your Remote is now programed! Test it by pressing the power button, volume, mute etc..
Cheers!
Apr 27, 2010 | RCA RCR-4258 Remote Control
How to key in a code crcr 4258
Hello Chicilot,
Here is a link for you I think it will be usefull.
http://www.universal-remote.net/rca.html
hope this helps you out.
Cheers Little Dish Fitter.
Nov 14, 2009 | RCA Universal Remote Control
Need code for RCA 4258 remote and instructions
click here
that link should take you to a user manual you can download if the link dont work then let me know and ill write the site down for you to copy into your browser.
You can also let me know what you want the control to work on and i can give you the codes and how to enter the codes making your life a bit easier ok.
Let me know how you get on or if you need further assistance ok.
Aug 11, 2009 | RCA Universal Remote Control
Need directions and codes for rca universal remote
I'm just going to buy another universal remote that matshs my tv. Thanks for your response.
Dec 07, 2008 | RCA Universal Remote Control
Big button remote rcr 4258
does not have all the codes for every product,
Please give me the model # for the cable box -scientific Atlanta and the model # for Magnavox T.V.
also goto www.replacementremotes.com (336)969-1842
They will find you REPLACEMENT remote control CODES, not remote control
Apr 12, 2008 | RCA Universal Remote Control
Televison & Video Logo
41 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
