Question about Dewalt DC920KA Heavy Duty Xrp 18V Cordless Drill/Driver
Dewalt dc926 hammerdrill chuck do not stay lock in reverse
My hammer drill works on forward but unlocks on revers
  • 18volt Aug 10, 2008
    drill does not stay in lock position in reverse what may be the problem. in the forward position has no problem.
  • Anonymous Mar 23, 2014
    Using the hammerdrill to remove thinset from concrete, just goes around and around like a drill.What am I doing wrong?
    Champion:
  • 313 Answers
Chuck should be replaced to parts # 33007575 newer style.
Posted on Aug 11, 2008
  • mr aicnelav Aug 16, 2008
    ya that is right needs chuck
The chuck on my Dewalt 18v hammer drill will not stay tight. it loosens whether I am in forward or reverse
the chuck on my dewalt 18 volts hammer drill will not stay tight it loosenss whether i am in forward or reverse
Oct 14, 2010 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
How to remove the chuck from a dewalt cordless hammer drill?
Remove the REVERSE-THREAD screw at the bottom of the chuck. Set the clutch collar to the highest setting, and set the gear to the slowest setting on the transmission. Remove the power source! Get the biggest allen wrench you can fit in the end of the chuck(the shortest leg) and tighten the chuck down around it, allowing the jaws to rest and tighten on the flats of the wrench. Lay the drill on its side(chuck toward you, handle to the left, and allen wrench to the left, horizontal to the deck. Then with a hammer(soft hammer if you care about the allen wrench) quickly and deliberately hit the allen wrench in an attempt to cause the allen wrench to spin counter clockwise. Let me know if this works for you!
Sep 19, 2010 | Dewalt DC925B Heavy Duty Xrp 18V Cordless...
How to--- chuck removal DC925 drill DeWalt
Open the chuck fully. Inside the center bottom of the chuck you will normally find a reverse threaded lock screw that you must first remove. If it is hard to loosen, you may need to heat it with a micro torch or a heat gun to make the thread lock compound slip. Then fasten the smaller end of an allen key firmly into the jaws of the chuck. Engage the low gear. Then hit the longer end rapidly with a hammer to unscrew the chuck by rotating it anti clockwise.
Sep 05, 2010 | Dewalt DC925B Heavy Duty Xrp 18V Cordless...
How do I remove a dewalt chuck
Remove the REVERSE-THREAD screw at the bottom of the chuck. Set the clutch collar to the highest setting, and set the gear to the slowest setting on the transmission. Remove the power source! Get the biggest allen wrench you can fit in the end of the chuck(the shortest leg) and tighten the chuck down around it, allowing the jaws to rest and tighten on the flats of the wrench. Lay the drill on its side(chuck toward you, handle to the left, and allen wrench to the left, horizontal to the deck). Then with a hammer(soft hammer if you care about the allen wrench) quickly and deliberately hit the allen wrench in an attempt to cause the allen wrench to spin counter clockwise. Let me know if this works for you!
Jul 23, 2010 | Dewalt DCD970KL XRP HeavyDuty XRP 12"...
How do you put the drill bits on this drill?
Grab hold of the sides of the check and run it in revers to open the chuck and then place the drill bit in the chuck and run it forward while holding the side of the chuck to tighten it on the bit...
heatman101
Jul 15, 2010 | Dewalt 18 Volt Xrp Heavy Duty Hammer Drill...
Dewalt chuck removal
there is a screw inside the chuck inline with it, I believe it has a reverse thread so turn it counter clockwise to remove
Jun 28, 2010 | Dewalt DCD950VX XRP HeavyDuty XRP 12"...
Removing the dewalt DC925 'rohm' chuck
I have a DC927 and a DC926 that I removed 1/2" Rohm Supra SK key-less chucks on. This process is pretty simple. Put the drill motor in 1st gear. Put the clutch ring in drill mode and not in driver or hammer. Reverse or open the chuck all the way. Hold the chuck firmly in a vise and give the drill a good POP counter clockwise. The last step can also be done with a pipe wrench by placing the drill on a work bench and turning the chuck counter clockwise. Continue to un-thread until the chuck is removed. The replacement chuck must have the same mounting process and mechanism. Put a few drops of locktite on the threads and thread the replacement chuck back on. Tighten the chuck using the vise or pipe wrench. Place the short end of an allen wrench in the chuck and tighten down on it. Placing the drill on a work bench, strike the allen wrench with a mallet to finish tightening and locking down the chuck. Congratulations, you have just changed out your chuck.
Feb 16, 2009 | Dewalt DC927KL Heavy Duty 18 Volt Cordless...
Dc926 xrp hammer drill
ya its a chuck problem wont hold in reverse
Aug 10, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Dewalt DC920KA Heavy Duty Xrp 18V Cordless Drill/Driver Logo
452 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
