Question about Apple iPhone Smartphone
Iphone is disabled connect to itunes and when i connect to itunes it says "cannot connect since it is locked with a passcode. unlock the phone. what can i do?
  • 3 more comments
  • topiman Aug 15, 2008
    which version of itunes do I have to install in order to restore the iphone while its disabled and I dont have the code?
  • Anonymous Nov 27, 2008
    такая же хня... че делать?
  • Anonymous Dec 05, 2008
    lOCKED SAYS CONNECT TO iTunes
  • jun091472 Apr 15, 2009
    iphone is disabled connect to itunes
  • Anonymous May 13, 2009
    my friend found iphone at his house after i left it there and tried to get through my passcode and now i can use it for like another 2 days, and it wont connect to my computer it comes up connot conect to itunes becouse the iphone has a passcode, my pass code wont work and i want to connect to my computer :( please help me!!
    Sniper:
  • 64 Answers
To unlock iPhone, read the detailed solutions from http://tinyurl.com/Forgot-iPhone-Password
Posted on Apr 11, 2013
To get iphone to connect to itunes disconnect it from USB cord, press on/off button until you see slide to turn off, slide to turn iphone off. After iphone is off press and hold home button and reconnect to USB cord (do not release home button) continue holding button until you see itunes has detected an iphone in recovery mode then release home button. Proceed with restore.
Posted on Dec 06, 2008
Please solve my problem
Posted on Nov 23, 2008
5 Suggested Answers
Joed911
  • 4338 Answers
SOURCE: iphone disabled connect to itunes
Here are your instructions from the website below.
Reset your iPhone Passcode:
If you have forgotten your iPhone's Passcode you will need to restore your phone via iTunes.
But first you have to put your phone into the restore mode which is a slightly fiddly process.
Plug your iPhone into your PC or Mac with the USB cable
Press and hold the power button at the top and then slide to power off the iPhone
Press the power button to power the iPhone on and keep it held while simultaneously pressing the home button
After a few seconds a yellow alert triangle will appear and the iPhone will say it is iPhone Restore Mode.
Open up iTunes and click on the Summary tab
Click on Restore to restore your iPhone. This will reset all your iPhone's setting to the factory defaults, including the Passcode. You should then follow the steps above to activate the Passcode with a memorable number http://www.knowyourmobile.com/appleiphone/apple_iphone_userguides/4684/how_to_password_protect_your_iphone.html Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Dec 28, 2008
  • 173 Answers
SOURCE: My iPhone is disabled for 4,566,757 mintues, HELP!
The only way is to reflash a new firmware and wipe the code as well as the phone clean.
To do this start itunes on your computer. Then connect your phone to the computer. Once itunes detected your phone hold the POWER and the HOME buttons down at the same time for about 10 seconds. Once the phone flashes off, let go of the POWER button and keep holding the HOME button until you see a message on the itunes telling you that your phone is detected and needs to be RESTORED. Follow directions and it will do its job. I appreciate your positive vote. Thanks
Posted on May 23, 2009
  • 85 Answers
SOURCE: iphone disabled to "connect to itunes" but needs passcode
Turn your phone off and plug it into your computer holding the home button down. That will put your phone into restore mode.
http://www.mobileease.co.uk
Posted on Jul 26, 2009
whatcity225
  • 81 Answers
SOURCE: Iphone disabled, can't connect to itunes
You will need to do a reset. Hold the middle button(home key) while you plug it into the compter. Keep holding it until iTunes displays it found a phone in "recovery mode". You should then be able to do a restore.
Posted on Aug 30, 2009
My iPhone 6 is dsabled. How do I get my phone back
Hello Jabob. If your iPhone 6 is disabled, the only way to unlock it is to completely erase and reset it. If you have a backup, you'll be able to restore it, otherwise you'll lose all of your data. There is no way to unlock a disabled iPhone unless you use the correct passcode or you erase it. And the following guidance will show you how to unlock a disabled iPhone with iTunes.
Step 1. Connect your iPhone to the computer with via a USB cable that your iPhone has trusted.
Step 2. Launch iTunes. If you've synced your iPhone with iTunes, then no "enter password" is required.
Step 3. iTunes will automatically sync your iPhone and create a backup file. If it doesn't, you should sync your iTunes and create a backup file manually by clicking "Back up Now" in the Summary window.
Step 4. In the Summary window, you can see the option "Restore iPhone". Click it to reset your iPhone. Once the reset process is complete, you'll be taken through the iPod's initial setup process.
Step 5. Select "Restore from iTunes backup" during the setup process. This will load the backup that you created so that all of your data is restored.
http://www.leawo.org/tutorial/how-to-unlock-a-disabled-iphone-with-without-itunes.html
Apr 04, 2017 | Apple iPhone 6
Just got iphone back it says its diabled but for 23,685,670 minutes?
How to fix it if your iPhone is disabled?
If your iPhone is disabled and has to be connected to iTunes, you can connect it to an authorized computer, and the Enter Passcode window will show again. If you insert the right passcode this time, your iPhone will be all right again.
If you forget the passcode completely, I'm afraid that the only way to make it back to work is to reinstall.
Note, that the iPhone will erase itself after ten incorrect password attempts in a row. You can turn this off under Settings > General > Passcode Lock.
6 attempts: 1 minute
7 attempts: 5 minutes
8 attempts: 15 minutes
9 attempts: 1 hour
10 attempts: Erase data. If that option is off it will require connecting to iTunes to unlock.
Mar 04, 2015 | Apple iPhone 4S
How do i unlock my iphone 4 when its disabled
Does this copied and pasted advice help you?
iOS: Forgot passcode or device disabled If you set up a passcode on your iPhone, iPad, or iPod touch, and you or someone else then enters the wrong passcode too many times, your device will disable itself temporarily. Learn what to do if you have forgotten your passcode, or if your device displays a message saying it's disabled.If you enter the wrong passcode six times in a row, you'll be locked out and you'll see this message:
  • iPhone is disabled
  • iPad is disabled
  • iPod touch is disabled
If you can't remember your passcode, you'll need to erase your device using iTunes, Find My iPhone, or recovery mode. Then use a backup to put your data and settings back on your device. Here's how. Use iTunes If you have synced your device with iTunes, you can restore your device.
  1. Connect the device to the computer you normally sync with.
  2. Open iTunes. If iTunes asks you to enter the passcode, try another computer that you've synced with. Or try the steps below to use recovery mode.
  3. iTunes will automatically sync your device and create a backup. If it doesn't, sync the device with iTunes.
  4. After the sync is complete, restore your device.
  5. When iOS Setup Assistant asks to set up your device, choose "Restore from iTunes backup."
  6. Select your device in iTunes and choose the most recent backup.
Use Find My iPhone If you enabled Find My iPhone, you can use it to erase your device.
  1. Go to icloud.com/#find to see if you enabled Find My iPhone.
  2. Click All Devices at the top of your browser window.
  3. Select your device and click "Erase [device]" to erase your device and its passcode.
  4. Use the Setup Assistant on your device to restore the most recent backup of your device.
Use restore your device as new or from a backup.
  1. Disconnect all cables from your device.
  2. Turn off your device.
  3. Press and hold the Home button. While holding the Home button, connect your device to iTunes. If your device doesn't turn on automatically, turn it on.
  4. Continue holding the Home button until you see the Connect to iTunes screen.
  5. iTunes will alert you that it has detected a device in recovery mode.
  6. Click OK, then restore the device.
Last Modified: Jul 8, 2014
Aug 04, 2014 | Apple iPhone 4 Black Smartphone
I forgot my iphone passcode and its says disabled connected to itune how do i do it???
You're gonna have to plug it into the computer that you've been syncing it with previously to unlock it, or you can put it into restore mode by plugging it into a different computer with iTunes, and pressing the power and home buttons at the same time for about 5 seconds and holding the home button till iTunes dings at you and says that it's detected an iphone in recovery mode. !! Important note!!! If you're using ios 7.0 or above then you will still have to enter the previous Apple ID associated with the phone to remove the iCloud lock to be able to restore.
Mar 21, 2014 | Apple iPhone 3G
Iphone disabled connect to itunes
Thanks, Joe
Dec 28, 2008 | Apple iPhone 3G
Disabled iphone
my iphone show me iphone is disabled connect to itune when i connect itune show massege iTune could not connect the iphone
because it is locked with a passcode. i forgat
Aug 22, 2008 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
617 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
