Question about Cobra 29 LTD CB Radio
No reception I get power and radio will key up, but will not receive. Had out of service for a while, worked before, but no longer receives.
    Problem Solver:
  • 12 Answers
Open it up,
check your speaker connections.
Check your antenna connections, Radio & Antenna
Check inside your mic connector for a broken solder joint on one of the pins. Otherwise, it could be a bad audio chip.
Maybe even a break at the antenna connector inside the radio.
If none of these, Radioshack has a reasonable repair service on many radios, cobra is made by uniden, who makes radioshack radios as well.
Posted on Aug 14, 2008
2003 grand marquis radio am does not work
Does anyone broadcast AM radio any more?
If you know you have a good AM station in your area, and you can verify its frequency, and your radio can't receive it but CAN receive FM stations... then that radio just isn't going to get AM. It's probably not worth fixing.
Aug 07, 2014 | Sony CDX-GT320 FM / AM / XM Radio / Sirius...
Boston Acoustics Recepter Radio HD stopped working - no power. The power supply is fine. is there a fuse in the radio?
There should be a fuse in the back but it would only blow if the wiring is funny because the car's fuses are closer to the power supply and should go first, but try anyway
Apr 24, 2014 | Boston Acoustics Recepter Radio(r) HD
Fm radio works fine but the dab will not find any stations, I have tried different aerials and still no good
What's the make & model of the radio?
Most DAB/FM radios work from the same antenna, so if you receive FM stations, you should receive DAB stations in your area.
It should be noted that DAB transmitters work on lower power than conventional FM transmitters, and so you may be in a weak reception area (for DAB). It should also be noted that DAB uses different frequencies than regular FM stations and household appliances such as laptops,WiFi, microwave ovens, etc can affect DAb reception.
Nov 18, 2013 | Audio Players & Recorders
I have an almost new Midland 75-822 that the WX works fine on, but the CB doesn't seem to receive, or transmit. It operates normally, but no reception, and no evidence of transmissions.
you'll need a schematic and some knowledge. there a two diodes that control the rx and two that control the dx.Check them to make sure they are producing the correct power out put if they are not you should replace all 4
May 10, 2012 | Midland 75-822 40-Channels Handheld CB...
I have a new Onkyo TX-SR508 receiver. When listening to FM radio the audio cuts out repeatedly for anything from a few seconds to a minute. Power fluctuation is very unlikely to be the problem. Signal...
Does the display show "tuned" or "FM Stereo"? This would normally indicate a good reception. The tuner has a signal level threshold and if the signal gets to week, the receiver mutes to prevent noise in the speakers. Swithing to mono make reception less intolerant. Does the problem also occur, when you switch to mono?
Jul 14, 2010 | Onkyo Audio Players & Recorders
The phono works, but i get no sound when tuner on
This usually means that the tuner is not getting sufficient reception for the station you are trying to listen to.
Receivers come with cheap wire loop antennas try upgrading to a powered FM antenna available online or at your local Radio Shack.
Hope that helps
Feb 15, 2010 | Pioneer VSX-D903S Receiver
Improve reception
HI there,
Well Yes you can improve the reception, please follow the below steps -
Improve FM Radio Reception -
1. If you don't have an antenna connected to your FM receiver, purchase a simple dipole antenna--a simple T-shape flexible wire-- and connect it to the FM antenna inputs on the receiver. Because FM signals are directional, you'll want to experiment with the positioning of the wire to find the best reception of the station you're trying to receive.
2. If you're still not getting a good signal, try an indoor amplified antenna, which you'll find at an electronics store. Don't buy one unless you get a guarantee that you can return it for full credit if it doesn't solve your reception problems.
3. If your signal is weak because you live a long way from the transmitter, install an outside antenna and mount it as high as is practical. If you're primarily interested in getting signals from one station or from a group of stations in one direction, get a directional antenna and point it toward the transmitters.
4. If you're using a portable FM radio where the only antenna is the power cord, stretch the cord as straight as possible and experiment with positioning again.
5. Temporarily switch to monaural mode to improve a weak signal on an FM receiver.
Improve AM Reception -
1. Gradually rotate the radio 360 degrees. Leave it in the position where it sounds best.
2. Reverse the AC plug if it isn't polarized. (If you can flip the plug over, then it's non-polarized.)
3. Plug the radio into a different AC outlet.
4. Move the radio closer to a window.
5. Experiment to learn if appliances and powered products in your home are causing interference: computer monitor, television, electric blanket, light dimmer, fluorescent light, hair dryer, air conditioner, smoke detector. If possible, turn off the offending item. Otherwise, move the radio to another room.
6. Upgrade to an external antenna if your receiver, tuner or radio has a place to connect one.
7. Buy a passive AM antenna that doesn't need to be connected to a radio or receiver.
Good Luck!!
Thanks
Dec 29, 2009 | RCA RP5430 Clock Radio
FM RADIO Reception
No, it should work, although it will depend on how good your reception is. This depends on how strong the signal is where you are trying to receive. If you have tried scanning for channels and all you receive is static, it's possible your tuner is bad. Have you tried to tune it to a known good station manusally?
Jan 20, 2009 | SanDisk Sansa e250 MP3 Player
My Sony DE 945 Blue LED light indicating digital audio reception
Does anyone have a solution? The authorized Sony repair center in my town is stumped.
Jan 16, 2009 | Sony STR-DE945 Receiver
Cobra 29 LTD CB Radio Logo
144 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
