Question about Dishwashers
Whirlpool dishwasher stopped mid cycle
It got through the wash cycle, stopped and didnt drain. It now doesnt have power on the panel. The thermal fuse was checked ok. The power was plugged into another source and was ok.
  • fireandnurse Nov 25, 2008
    same issue did not drain, lights would not come on, control board replaced, fusable link good, power coming in to d/w, power to micro-switches, door latch good, power to board, HELP PLEASE dont want to spend another 100 bucks if i dont have to, that would be the cost of a new one
My whirpool dishwasher model ADP4601 is flashing a green light three times and is not doing anything else - any suggestions
Posted on Aug 10, 2008
Kenmore elite dishwasher stops mid cycle
I assume you mean it stopped in mid cycle and is now dead. If this is the case you will need to turn off the power to the dishwasher and remove the screws holding the front control panel There is a thermal fuse clipped to the front of the control panel Check it using an ohmmeter or continuity tester If it is open you will need to replace it with a kit containing the fuse and wire connectors Do not replace just the thermal fuse the problem will surely return. Also inspect the control board for burned areas.If the control board is burned you should replace the wiring harness with the control assembly
Jan 25, 2014 | Kenmore 24" Built-In Dishwasher with...
Du1055xtvq stops mid cycle
This is a problem with the thermal fuse and will need to be replaced. Here is the part to order. The fuse is located in the console and the part comes with complete instructions.
Keep me posted!
Jan 21, 2013 | Whirlpool DU1055XTVQ Dishwashers : Built...
Dishwasher just stopped in mid cycle and does not show any signs of power getting to the unit. is there a fuse or a reset switch?
Yes their is a thermal fuse that clips onto the housing of the control board
To check it seperate the inner door panel from the outer door panels and use a meter and check for continuty..if it does not ahve continuty it is bad. Its part# 8193762 It can be purchased at your local applaince parts store or online at;
searspartsdirect.com
repairclinic.com
apdepot.com
apwagner.com
midwestapplianceparts.com
Thanks for using Fixya.com
Gene
Aug 24, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
8 yr old GU1200 stopped mid cycle - no apparent reason - no response to buttons - appears dead?
These dishwashers have a thermal fuse in the control panel. If it overheats for some reason (sometimes a bad connection on the fuse itself causes that)it will turn whole machine off.
  1. Disconnect power to dishwasher. Remove screws holding the control panel from the side of the inner door. Remove control panel. If it does not come off - remove all screws on the inner side of the door and separate the inner and outer door.
  2. Fuse is on the right side on top of the control board. it usually has tan or black or yellow wires to it. Disconnect wires and check fuse for continuity. if none - replace fuse. Here is your part
Good luck
Vlad
First Choice Appliance
Sep 11, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
No lights on, didnt complete the drain cycle, stopped working now
There is a thermal fuse located in the control panel inside the door. It could be blown, but if so what caused it. they come with a retrofit pigtail to prevent loose connectins on the fuse. You may have a short somewhere in the dryer, and just blow the fuse again. Could be bad motor,fill valve, or heater, or even the control board. I'd try one fuse first.
Jul 26, 2010 | KitchenAid 24 in. KUDP01IL - Multiple...
Dishwasher stopped mid-cycle
you have a bad thermal fuse in the control panel. it's the whit thing with 2 wires going to it
Sep 07, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
Whirlpool dishwasher stopped working...
It sounds like the thermal fuse in the control console has blown.
Turn power off to unit.
Remove the outer door panel and then the console.
Remove the black plastic cover from over the circuit board if it has one.
You should see the thermal fuse clipped to the circuit board housing.
If you have an ohm meter, check for continuity across it, it should read closed.
If you don't have a meter, unplug the wires from it and and hook them together.
Turn power back on to unit, hold door switches down and cancel cycle. The washer should drain the water.
If this doesn't work, check your door switches to make sure they are closing properly.
Nov 17, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
569 people viewed this question
Top Dishwashers Experts
