Question about Kenmore 24 in. 15142 Built-in Dishwasher
Dishwasher is leaking I noticed a pipe downstairs leaking and realized it is from the dishwasher I noticed the seal is wrecked
Kenmore dishwasher
  • Amanda Drew
    Amanda Drew Oct 12, 2017
    My dishwasher is also leaking. Well, it's more like having bubbles and soapy water exploding from it whenever I use it. So, I haven't been using it for about the past week. My husband started it, though, and said that we had to do something about it. You and I should probably just both find a good residential plumber to come and help us with our pipes.http://1stclassplumber.com/residential-p...
  • 734 Answers
Must need a new air tube or worse still the air chamber has a split in itclean machine out in w/shop and with sides off check out with a light to see where the leak is realy comming from it may be leaking from the top wash feed pipe leaking around pipe to tub
these do fracture there and water running down to base
if so replace feed pipe
Posted on Dec 02, 2008
I can't get water completely shut off on downstairs kitch faucet. All valves shut off, everything but bypass valve on wtr sftner. Still steady trkl on downstair fauc. Am I just not patient enough?
You might try opening all faucets and outside silcocks after main shut off valve to make sure you aren't just pulling a partial vacumn which can cause some water to be trapped in pipes and very slowly leak out.Thank you.
Mar 10, 2011 | Garden
Toilet leaks into floor and lower level ceiling, no water on bathroom floor.
Either wax ring or sewage pipe is leaking. If you cant open the ceiling from below to look for leak you may have to remove toilet inspect pipe and look to see if it was leaking from wax ring and if it could have gone downstairs without leaking out too. If leak couldn't have come from wax ring the leak must be coming from a pipe in the floor. Find the simplest way to access it to repair it.
Sep 14, 2010 | Toto Round Carusoe Two Piece Toilet, 1.6...
Leaks water from under dishwasher, some one suggested the fill valve assembly needs replacing???? kenmore
Hi
Thanks for using FixYa. If your dishwasher leaks, check these:
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
Lower rack
Spray arm
Spray arm support
Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Nov 03, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore Dishwasher leaking from bottom but not while draining....
Leak is associated with the water pump, either a hose or seal
Sep 29, 2009 | GE 24 in. GSD4020Z Built-in Dishwasher
Leaking dishwasher
HI, i would inspect the door seal. make sure there isn't any foreign objects that are getting stuck in between the door seal and tub housing. if the seal is clear of any objects(small objects), this will confirm door seal failuer.
simply replace the bad door seal in this case.
Jun 16, 2009 | Kenmore Dishwashers
Water wont stop going in
You stated that your house is new. I see this frequently and what has likely happened is the installer used pipe dope to seal the elbow that screws into the bottom of the dishwasher water valve. They should have used Teflon thread tape instead as the pipe dope will get into the diaphram in the water valve, clog the tiny holes in it and ruin the water valve. The valve on the dishwasher will need to replaced. Hopefully the company that takes care of the warranty doesn't charge you for it. They should back-charge the installer.
Jan 01, 2009 | Dishwashers
Dishwasher leaking on florr
Hi.
It could be:
a dirty door seal
a clogged pipe on the pressure sensor causing it to overfill
a genuine leaking hose
Much depends on where it is leaking from. The door seals can be cleaned with a detergent laden cloth, hard grime removed with a plastic scouring pad or a blunt knife (with care)
A clogged sensor pipe needs to be removed and cleaned out - access will most likely be from beneath. While you are there you can check the hoses for leaks too!
As a starting point I would put a kettle or two of very hot water and a generous dose of detergent into the machine and try to let it clean itself. While it is doing that try to spot where the leak is. There may not be one if it was overfilling.
I hope this helps.
If these suggestions do help you solve the problem, please give my reply a rating to help others judge my knowledge / guessing skills. If they do not, please add a comment with more details so I can try to help you further. Cheers, D
Jul 01, 2008 | KitchenAid KUDS01DJ - Multiple Color...
Bosch Dishwasher Door Leaking Steam
Pull the seal that is on the tank 1/2 way out then close the door. This will make sure the door is tight to the seal. This happens sometimes that the seal becomes flattened. I have been using this trick on Bosch dishwashers since this series came out in 1997.
Jan 06, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Maytag dishwasher mdb5000awa leaking
Well did you check to see if the door seal is ripped or not on tight??? The door seal is the rubber strip that is used to seal the door shut tight, if this is wrecked in any way that might the the answer to your solution?
Dec 20, 2007 | Dishwashers
Kenmore 24 in. 15142 Built-in Dishwasher Logo
178 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
