If your Nokia C3 meet a permanent problem, you should reset your
phone. There are two ways to perform a reset on the device, the hard set
and soft reset.
1 how to perform hard reset on Nokia C3
To perform a hard reset on the C3, press *#7370# and press Dial. The phone will request the security code that is 12345
by default. Since the hard reset will erase all date in your phone, you
should backup important data before performing a hard reset.
2 how to perform a soft reset on Nokia C3
If you want to soft reset your Nokia C3, you need to press *#7780# and then Dial. The default security code is 12345.
When you do this, your phone will come back to original factory status,
but you will not loose personal data. It is better to make a backup
before performing any kind of reset.
Hope this helps.
Let me know if you need more information
Thanks.
I am using this great LCD for about an year. But few times in the past my LCD didnt show up the display though the Green light was still ON, turning off the LCD and opening it again always solved the problem. But now My LCD completely went blank. Turning off/on didnt work at all now. I've tried couple of other tweaks mentioned on this site but they didnt work. I am just seeing a blank screen with green light ON. and ya theres a very low hissing sound coming from the LCD.
