Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Not working I have a kitchen aid ksrs22qaal10 this morning water was all over the floor and nothing is cold in the fridge. Could the motor be gone!!
  • 2 more comments
  • sanquinn1 Aug 10, 2008
    there is a black casing next to the compressor, I took it off shook it and plug the unit back end nothing happen.
  • sanquinn1 Aug 11, 2008
    Catriver, thanks for your help. I did what you indicated but nothing happen
  • rmarko Apr 23, 2009
    model ksrs22qaal10 - this morning, water all over the floor - dripping from defosting ice in the ice maker - all frozen food soft. Refrigerator will not run - tried plugging/unplugging to no avail.
  • kathigarn May 04, 2009
    I have the same problem with my KitchenAid. When we turn it off and restart it, it seems to do okay. An easy fix is mentioned, but not told. Are there further instructions somewhere we could follow?
    President:
  • 878 Answers
Sanquinn, hopefully it's just the overload and relay. Remove the back cover in back by the compressor. On the left side of the compressor will be the overload and relay, connected to the compressor. If they are contained in a white casing, unplug the refer and remove it. Shake it and see if it rattles. If so that's probably your problem. This unit does have a electronic defrost board that could also be the culprit, but start with that overload and relay. You will save yourself a ton of money if that's whats bad. Easy fix. Post back and we'll take it from there. Catriver
Posted on Aug 10, 2008
  • Ron Marek
    Ron Marek Aug 11, 2008
    Sanquinn, ok, does the compresser start when you plug in the refer? Or does it just humm and the overload clicks about every 5 minutes. Can you use a meter? First I need to know if the compresser is running or not. If not the next move would to see if we have power to it. Post back, Catriver.
My Kitchen Aid Superba refrigerator Model # KSRS25FGWH01 stopped working. no fans come on no noise only fridge lights. working the other day but fridge was not cold enough freezer was fine now nothing
The machine goes into the defrost mode every day or two. During defrost mode you will see these symptoms. After an hour or two, it should return to normal. If not, the defrost timer may be stuck in the defrost position.
Mar 05, 2017 | Refrigerators
Refrigerator motherboard How can I tell if the motherboard of my kitchen Aid refrigerator went bad
Make sure your fridge doesn't have a recall for evaporator as is the case on my fridge I also thought it was electronic and first tech thought it was a leak in reality the evaporator was clogging and causing freon to not keep fridge cold or freezer to work properly but kitchen aid won't let you know you will have to let a tech look that info up for you.
Mar 15, 2014 | KitchenAid Refrigerators
Freezer not getting cold and dripping water
I own a similar Kitchen Aid fridge that had a defrost icing issue: Kitchen Aid KSRP25FNBL00
> Ice had plugged the drain hole at bottom of chill coil section inside the freezer compartment.
> I learned that the coil, circulation fan was not working, but condenser was working.
> I paid a tech to replace the circ fan, about $200, including a new swiss-made fan. He said it was unusual for these fans to fail, but not unheard of.
Expensive, but saved the purchase of a new fridge. Has worked great for 6 months since then.
HOpe that helps.
Al Zayha
Mar 09, 2014 | KitchenAid (KSRD22FKST) Side by Side...
I have a kitchen aid superba side by side black with ice maker and water dispenser. Questain is I have it outside plugged in, during the day sun is on it, will this affected the feezer side from keeping...
yes, the insulation in the fridge is not designed to handle that kind of heat, and it being black only compounds the problem. eventually the refridgerator will overheat and fail. it doesnt need to be in the a/c, but it does need to be out of the sun
Sep 26, 2013 | KitchenAid Kitchen Aid Superba Series...
KITCHEN AID REFRIGERATOR PROBLEM We bought a used Kitchen Aid fridge YKSRS22Q (1993), the ice maker is not working but water does work. What should we check to see why the ice maker doesn't work?
Ice makers work off of temperature. If it's not cold enough in the freezer it won't work. Check the temperature with a thermometer, it should be 0 to +10F
Jan 29, 2011 | Refrigerators
I have a kitchen aid superba ksrg22fkss15 side by side fridge. Last night the freezer stopped working and I am still trying to determine if the fridge side is working. I pulled off the front and back and...
Can you hear if the compressor is running? The high pressure side of the compressor should be too hot to touch, over 140 F. I assume you mean the condenser fan motor at the bottom of the unit. Try to feel how cold the evaporator coil inside the refrigerator box is. A small capillary tube enters one end of the evaporator. That is the coldest spot. It should still feel at least 35 degrees or colder at the other end of the evaporator where the larger suction line is located. The whole evaporator should be cold. A small portion or none of the evaporator is cold means it is not working. The freezer evaporator should be near -30 F.
Oct 11, 2017 | Refrigerators
My Kitchen Aid will refrigerator motor keeps running. Things are cold but the motor sense like it is always running.
If it is not freezing up or set too cold, you may be losing coldness somewhere. Are the seals all in good order? Do you open it very often and leave the door open? Do you put hot stuff in the fridge? All these things would contribute to that problem.
Sep 06, 2010 | KitchenAid KSRS25FG
KSRG25FKWH04 is not getting cold its a kitchen aid side by side
See if you can hear the evaporator fan motor running in the freezer, if not, you need to replace it because it forces the cold air from the freezer into the fridge section to keep it cold.
Nov 11, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Freezer has frost building and the refridgerator is too warm.
make sure the evaporator fan is working, open door and push switch in if fan works make sure opening from freezer to fridge is not blocked. if door was removed make sure light in fridge is shuting off if temp in fridge is in the 50 degree range your light switch is not being deactivated check spacers between door and hinge . sometimes when door is removed a spacer will fall on floor and light switch is not hitting door
Jan 26, 2009 | KitchenAid KTRC22EL Top Freezer...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
202 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
